Matt120y Samba Member
Joined: April 17, 2008 Posts: 7 Location: Perth, Australia
Posted: Fri Aug 22, 2014 10:49 am Post subject: |
Ok then, I've got dropped spindles to put on it too, but are they nessasary to have? I want to be able to make the car super low for shows etc, but lift it up a little for daily driving, and to keep the cops off me a little! |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Fri Aug 22, 2014 11:30 am Post subject: |
Matt120y wrote: |
You don't really need to put them on, but IF you do, take into account that they might help push the tire out toward the fender lip, and could cause a fitment problem with your desired tire and rim choice. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Fri Aug 22, 2014 1:02 pm Post subject: |
Matt120y wrote: |
You have to buy the wheels first! Then you can test fit/measure & determine what size air-beam 2-4" max to buy. You do want disc brakes on the front, but not the rear so it stops good. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
luckystiff Samba Member
Joined: September 28, 2005 Posts: 2252 Location: hickory,nc
Posted: Fri Aug 22, 2014 5:56 pm Post subject: |
radars i'd say 3-4" narrowed with wide 5 disc set up on drop spindles. my square is 5" with repop sprints and disc brakes on dropped spindles and it actually rubs the inner fenders quite alot with 145/65/15s. i went balljoint set up on my swap mostly because i had a balljoint donor beam for the arms and springpacks. and i for a good deal on a set up CB drop spindles with 5x130 disc(i ran fuchs on my square before the sprints) so i went balljoint. truth be told i can only get 3 or so inches lower than i could with t3 beam. i ran 4 notches down up front before the swap and my ride height now may be 2" lower at the current ride i have set.
DO NOT go more than 4" narrowed if you intend to run shocks which i'm sure you guys have to over there. you could probably squeeze a 4.5 in there but i can tell you my 5" was a pain in the ass with shocktowers. _________________ ITMC
Secret Service |
Posted: Sat Aug 23, 2014 1:44 am Post subject: |
Cheers for the input fellas. I've got the raiders already, so it's either those, beetle 15" or type 15" wheels.
I'm building the beam myself as I've done a copls of bus ones and beetle ones in the past.
I intend to run shocks, as it will be used a fair bit out on the open roads. Sounds like the disc's are the way to go, and 4" max narrowed by the sounds of it. |
OhHerrooo Samba Member
Joined: September 12, 2010 Posts: 1291 Location: Costa Mesa, CA
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4189 Location: Pasadena CA/DTLA soon China
Posted: Thu Aug 28, 2014 1:09 pm Post subject: |
Look how nice they look without being super narrowed.
_________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
NON INFLUENCER APPROVED |
type3nut64 Samba Member
Joined: September 25, 2000 Posts: 347 Location: Yucaipa Ca.
Posted: Thu Aug 28, 2014 1:17 pm Post subject: |
Yep! |
Deluxe Lowlight Ghia Samba Member
Posted: Thu Aug 28, 2014 10:30 pm Post subject: |
OhHerrooo wrote: |
Lowered my car a bit more. Need smaller rear tires.
The rear tires look perfect _________________ These vws are cool but the people who own them are far more valuable. Keep friends close they can be taken away overnight.
57 ghia
59 patina ghia
61 patina Ghia
71 bus
73 super beetle
74 thing
75 half bug |
Posted: Fri Aug 29, 2014 3:08 pm Post subject: |
Deluxe Lowlight Ghia wrote: |
OhHerrooo wrote: |
The rear tires look perfect |
Thanks. They're so close to rubbing, but just barely don't. A slightly less beefy tire might be in order, but they're good for now. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
OCT3 - Orange County Type 3's
www.evenkeelsurfshapes.com |
TMI Products Samba Member
Joined: February 14, 2014 Posts: 744 Location: Corona, Ca
Posted: Fri Aug 29, 2014 4:06 pm Post subject: |
OhHerrooo wrote: |
OhHerrooo wrote: |
Thanks. They're so close to rubbing, but just barely don't. A slightly less beefy tire might be in order, but they're good for now. |
Is the tire close to the fender lip?
I was able to roll my fender and "gently" pull the fender out, gained almost 1 1/2" by doing that. _________________ Mario De Leon
1965 Turbo Mustang Fastback
1966 Type 3 Fastback
VW Division Sales Manager
[email protected]
TMI Products
1493 Bentley Dr.
Corona Ca, 92879
1-800-624-7960
951-272-1584 FAX |
JWDW Samba Member
Joined: August 08, 2009 Posts: 174 Location: Phoenix Area
Posted: Thu Sep 11, 2014 5:23 pm Post subject: |
Bunch of my type 3's
fuhq64 Samba Member
Posted: Thu Sep 11, 2014 9:15 pm Post subject: |
^so that's where all the Notches are hiding... _________________ 69 Squareback
Still a n00b
www.instagram.com/fuhq64 |
marchi Samba Member
Joined: August 10, 2005 Posts: 646 Location: Abilene, Texas
Posted: Fri Sep 12, 2014 6:30 am Post subject: |
colineunson wrote: |
3'' narrowed air beam
ummm, SEXY!!! _________________ I drive my VW or I walk
'70 Squareback
'21 Tiguan (daughters)
SOLD
'69 Fastback (Flamer) |
Posted: Fri Sep 12, 2014 9:56 am Post subject: |
JWDW wrote: |
I have to agree with fuhq64 though, as that's a nice group you have hiding there.
Where I live, they'd have to be stored inside, or they would rust away (too much rain). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
eastcoast63 Samba Member
Joined: April 29, 2004 Posts: 1424 Location: Ft. Lauderdale
Posted: Thu Dec 04, 2014 4:19 pm Post subject: |
JWDW wrote: |
Love the collection...if you dont mind....do you have short axles in the rear and what tire size please..(Black Notch)...
Ant _________________ Fort Lauderdale, Florida
1967 Standard Microbus
Wide 5 Vintage Volkswagen Club |
cgallman Samba Member
Joined: December 28, 2014 Posts: 6 Location: Orangevale, Ca.
Posted: Sun Dec 28, 2014 6:36 pm Post subject: |
Brand new here, but Ive had a few squarebacks over the years. I have a chopped 69 squareback now, that I'm working on. I have a set of old school two piece aluminum race wheels that I want to use. The wheels rubbed the calipers so I put spacers on to solve that problem, which now makes the wheels rub the fenders. Any suggestions other than a narrowed beam, or is a narrowed beam my only option? Im in Nor. Ca. who make the best beam packages? I need at least 2 inches to clear everything. |
Posted: Sun Dec 28, 2014 8:46 pm Post subject: |
russel at Old Speed was doing narrowed type3 control arms. from memory i think they are 1" per side. best bet might be to contact him unless you want to go narrowed beam.
could you "clearance" the calipers and run a thinner spacer to avoid some of the width. _________________ ITMC
Secret Service |
Posted: Mon Dec 29, 2014 9:06 pm Post subject: |
Yes i could clearance the calipers, Cut the bolts that hold the wheels together, and run a thinner spacer. I think I would still need a little more room too. Control arms may be the answer. Thanks. |
makinbakin Samba Member
Joined: July 24, 2004 Posts: 393 Location: Greensboro, NC
Posted: Sun Jan 04, 2015 1:45 pm Post subject: |
_________________ OST KÜSTE |
