Re-gluing Vinyl to Masonite on inside door panels
PSScoots
PSScoots is offline
PostPosted: Sun Jul 06, 2008 12:36 pm    Post subject: Re-gluing Vinyl to Masonite on inside door panels Reply with quote
The vinyl coverings on my inside door and quarter panels are coming unglued from the Masonite backer board.
I'm looking for a glue recommendation to reattach it. Will hot glue work?
I'm looking for something that won't destroy the vinyl, adhere to the Masonite and withstand the tension.
Thanks.
Rebuilt to drive not decorate. -VOLKSWAGNUT
"Service the car and it will give you good service."
67 Florida Deluxe
Samba Purist
67 Florida Deluxe is offline
PostPosted: Sun Jul 06, 2008 12:46 pm    Post subject: Reply with quote
The quarter panels inside my '65 are in phenomenal condition, except they were coming unglued around the edges, causing the covering to shrink and winkle. I used a hair drier to heat the covering a little so that it was more pliable. I, then, used Gorilla Glue on the vinyl tabs that attached to the backside of the panel - a little dab per tab. I took two rulers (or any kind of straight edge) and sanwiched the panel in between each straight edge. I took lots of binder clips to hold everything in place until the glue dried. On the curved parts of the panel, it did it in stages, allowing one section to dry before moving on. It was rather tedious, but they came out fantastic and look just as they should.
Wanted:
Atlas Motors and Brundage Motors license plate frames.
A few of my toys
garykohl2
garykohl2 is offline
PostPosted: Sun Jul 06, 2008 12:47 pm    Post subject: Re: Re-gluing Vinyl to Masonite on inside door panels Reply with quote
I used hot glue to recover my doors and it worked just fine. It didn't hurt anything and it holds it tight.
1958 Bug aka Scar (o\ /o)
https://www.facebook.com/#!/pages/Aircooled-Addicts/115021415216112
Aircooled Addicts
http://georgiadubs.forumotion.net/
[url=http://www.vw-mplate.com/mplate2-15841.png]Click to view image[/URL]
BarrettBug
BarrettBug is offline
PostPosted: Sun Jul 06, 2008 2:51 pm    Post subject: Reply with quote
Uh..thank ya very much..
Bugs & flying RV's only way to go!
bill may
bill may is offline
PostPosted: Sun Jul 06, 2008 4:34 pm    Post subject: Re: Re-gluing Vinyl to Masonite on inside door panels Reply with quote
is that glue bleed thru' or pictures of some hippy???
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
Steve.
Stinger Specialist
Steve. is offline
PostPosted: Sun Jul 06, 2008 4:48 pm    Post subject: Reply with quote
3M makes a good adhesive spray, works well also
'64 Java
'66 Deluxe
Samba member # 6216
Wanted! East LA Atlantic VW license plate frame!
View user's profile Send private message Send e-mail AIM Address Facebook Gallery Classifieds Feedback
iaccy
iaccy is offline
PostPosted: Sun Jul 06, 2008 5:19 pm    Post subject: Reply with quote
i actually had the same problem, lucky for me my neighbor does upholstery and had some extremely short staples he used for automotive interiors. He shot a few staples around the edge of my panel and it worked great. Cool
PSScoots
PSScoots is offline
PostPosted: Mon Jul 07, 2008 7:55 am    Post subject: Reply with quote
Thanks for the input guys, much appreciated.
