The Easy Way To Build A Trike Frame
Forum Index -> Other VW Vehicles Share: Facebook Twitter
uncle frank
uncle frank is offline
PostPosted: Thu Jul 17, 2008 8:14 am    Post subject: The Easy Way To Build A Trike Frame Reply with quote
Arrows indicate stock mounting points
Five stock body mount points are an excellent way to attach the trike's body.
The whole wishbone just unbolts from the early Type III pan as a unit, engine, transaxle and suspension all in one, simply reuse the stock rubber donuts, nuts, bolts & washers.
Notice the built in stock sway bar (can't beat the price). This unit simply unbolts from the pan in certain year models of the Type III and is the basis of my Type III trike.
It's almost embarrassingly easy to build a trike this way, notch the front of the wishbone and weld the frame neck in.
If you do it right and use the stock mount points, the entire body and seats will also be rubber mounted.
Add some chromed swing plates and cheap coil over shocks, a disc brake motorcycle front end, seat, gas tank, wheels and tires and you've got so much fun it ought to be illegal...
Wishbone: Buffed, puffed, fluffed & stuffed (or something like that)...
My Type III Trike (sketch shows the final project)
Reply to topic    Forum Index -> Other VW Vehicles All times are Mountain Standard Time/Pacific Daylight Savings Time
