curtis4085 Samba Member
Posted: Tue Feb 19, 2013 9:42 pm Post subject: |
Anchovy wrote: |
itlives wrote: |
All those cracks in the steering wheel are usually from someone trying to take off the horn button from the silver ring up (ask me how I know!).
This pic is the best one of the bunch as it shows how the black button comes off with out cracking the wheel.
Good job! |
Thanks guys, I am glad you think the thread is useful.
Another tip: If the horn button is tight in the assembly, use a loose dull utility knife blade to get it started. The thin edge of the blade should wedge under the button easily. |
Curious who you purchased your steering wheel from and how its holding up, cracks, breaks or any fading. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22461 Location: Escondido CA
Posted: Tue Feb 19, 2013 11:06 pm Post subject: |
Im curious as well. And its funny that this post pops up just after I had to figure out how to pop the wheel loose on the 74.
Ive never owned an ACVW that the wheel didnt come loose after the nut was removed? The wheel on the 74 took some torque to get it to pop!
What gives? Or in this case - why dont it give? _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Wed Feb 20, 2013 12:06 am Post subject: |
Jason,
Have all yours been the factory wheels' first removal? I've heard horror stories of getting the wheel off the first time, then easy sliding after that. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Wed Feb 20, 2013 7:15 am Post subject: |
I have a special made bus steering wheel puller that I paid $100 for. There have been times when it sounds like a gun going off when the wheel finally lets go. These wheels are just too delicate (and expensive) to damage using crappy tools so I invested in a proper one. It's just one of those tools that you don't use very often but is nice to have for those times when you really need it. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Wed Feb 20, 2013 8:18 am Post subject: |
notchboy wrote: |
Im curious as well.
What gives? Or in this case - why dont it give? |
Early buses had a taper in the splines. They build up serious clamping pressure very quickly as you tighten the nut. The later buses have a simple straight cut to the splines.
Colin _________________ www.itinerant-air-cooled.com
asiab3 wrote: |
Jason,
Have all yours been the factory wheels' first removal? I've heard horror stories of getting the wheel off the first time, then easy sliding after that. |
Yes - factory fit - fist time removal.
And that sucker did pop when it came free. _________________
t3kg wrote: |
1964 1500 S
Tcash Samba Member
Posted: Thu Apr 11, 2013 8:40 pm Post subject: |
Loosen the nut, spray some penetrating oil in there. Drive it around for a few days and it will come loose.
I said loosen the nut, I did not say take it off. |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Thu Apr 11, 2013 9:10 pm Post subject: |
I pulled a tight one yesterday on my 69, it was a whore but my home made pulling washers worked again.
_________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
stevespeirs Samba Member
Joined: June 10, 2008 Posts: 310 Location: Virginia Beach, VA
Posted: Fri Apr 12, 2013 3:46 am Post subject: |
Thanks for the great tutorial. Finally managed to pull mine this week too, using a 3-arm puller, home made washers and heat from an old hairdryer. Would never have guessed how tight that wheel could be! |
Bansheelos Samba Member
Bret Young Samba Member
Joined: August 26, 2006 Posts: 756 Location: Turlock, CA
Posted: Thu May 16, 2013 10:32 am Post subject: |
Used this method yesterday to get a super stubborn wheel out of my 64 bus. Thanks to the guy who thought this idea up. It was a huge help! |
tinygiant Samba Member
Joined: May 29, 2013 Posts: 148 Location: Traphill, NC
Posted: Sun Jul 28, 2013 4:05 pm Post subject: |
anyone know if there is an aftermarket quick disconnect available for the bus steering wheel?
i installed some fold flat minivan seats up front and if the steering wheel was removed the driver seat could fold flat also allowing me to utilize the space up front for another sleeper... _________________ [URL="https://forums.vwvortex.com/showthread.php?9386545-TinyGiant-1985-Cabriolet-Build-Thread"]1985 cabriolet build thread [/URL] |
christine72 Samba Member
Joined: August 31, 2014 Posts: 84 Location: Portland, Oregon
Posted: Sun Mar 01, 2015 12:13 pm Post subject: Re: Steering wheel removal - tutorial (1971 bus) |
Anchovy wrote: |
Place the wheel on the steering shaft making sure that the front wheels are straight and the steering wheel is properly oriented. Install the 27mm nut.
Is it that easy to re-install? Just tighten that nut down, and it'll serve as a puller? _________________ '74 Bay - ASI camper body w/'72 Bay - undercarriage and a '76 2000cc rebuilt engine
Past VWs
1967 Fastback (my first car); 1971 Square back; Several Jettas '88 -'97
The one I regret not buying:
72 Karmann Ghia, with autostick. |
Posted: Sun Mar 01, 2015 12:25 pm Post subject: Re: Steering wheel removal - tutorial (1971 bus) |
christine72 wrote: |
Anchovy wrote: |
Is it that easy to re-install? Just tighten that nut down, and it'll serve as a puller? |
Yes. Remember to avoid using the sterling lock as leverage. Rather, use your fingers pulling against one spoke of the wheel to get tightening torque. _________________ Learn how your vintage VW works. And why it doesn't!
Posted: Sun Mar 01, 2015 12:43 pm Post subject: |
I'm not sure what you mean by this? If you mean that somehow the 27mm nut can be used to remove the wheel then I'd be learning something. I spent over $100 for my VW Bus specific steering wheel puller and have found it worth every penny.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Sun Mar 01, 2015 1:02 pm Post subject: |
I think he means pressing the wheel back onto the splined shaft. In that case the 27mm nut will press the wheel on past where we can push it with our hands. _________________ Learn how your vintage VW works. And why it doesn't!
Posted: Sun Mar 01, 2015 1:07 pm Post subject: |
Ahhh _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
spanglerls Samba Member
Joined: November 24, 2012 Posts: 5 Location: United States
Posted: Mon Mar 02, 2015 10:30 am Post subject: Bay Window Steering Wheel Removal |
I used the gear puller and washer technique and the old wheel came off no problem. New wheel installed no problem! Finally a small fix to my bus that was not a battle! |
EssexaviaTTor Samba Member
Joined: September 06, 2015 Posts: 1 Location: Southend on sea, Essex
Posted: Sun Sep 06, 2015 9:50 am Post subject: Re: Bay Window Steering Wheel Removal |
spanglerls wrote: |
Wheel installed using this very helpful how-to as suggested by someone on here you don't need a puller as wheel came off with no effort. Result lovely jubbly. Notice added matching tacho
Steve
[/img] |
MonkeySee Samba Member
Posted: Fri Feb 26, 2016 6:42 pm Post subject: Re: Bay Window Steering Wheel Removal |
EssexaviaTTor wrote: |
"Notice added matching tacho"
What tach did you use to achieve this feat? |
