Steering wheel removal - tutorial (1971 bus)
airschooled
Air-Schooled
airschooled is offline
PostPosted: Fri Feb 26, 2016 7:09 pm    Post subject: Re: Steering wheel removal - tutorial (1971 bus) Reply with quote
It looks like the JustKampers matching tach that they sell for early (grey) and late (black) instrument clusters. They're pretty nice.
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
Tom Mohr
Tom Mohr is offline
PostPosted: Sat Mar 26, 2016 3:04 pm    Post subject: Re: Steering wheel removal - tutorial (1971 bus) Reply with quote
So.....trying to get a 71 out of a field. No keys and steering wheel locked. What is the next step or choices.
airschooled
Air-Schooled
PostPosted: Sat Mar 26, 2016 3:07 pm    Post subject: Re: Steering wheel removal - tutorial (1971 bus) Reply with quote
Easiest to most difficult:
- Look for a hide-a-key
- Remove drag link
- Remove both tie rods
- Remove steering coupler
- Read the key code off of a few locks. If they match, have steelersbus make you a key by the code.
Good luck,
Robbie
www.airschooled.com
larryducas
larryducas is offline
PostPosted: Sat Apr 09, 2016 2:32 pm    Post subject: Reply with quote
Red Fau Veh wrote:
Yea, I made this setup today and it wasn't up to the task, I may try again. I made the washers out of 3/8 steel plate by mounting a 3 1/2" hole saw in the drill press and then I notched the discs with a cut off saw and a angle grinder to be able to snap the tap out of them. I really think I may just build a puller. I havn't designed it yet but I can weld up a super strong contraption I'm certain. Rolling Eyes Very Happy
[/img]
It didn't work for me either, just bent the washers. I made more out of a pulley and bent that too.
This is the tool to use. HF bearing puller kit, use the large one, tighten. 3 wacks on the bolt with a hammer and pop. This is what worked for me:
This picture is after it popped.
tool:
[/img]
71 deluxe, 1968 type 1 engine rebuilt, 009 distributor, pertronix module, Empi 38 EPC / DGES carb
pjalau
pjalau is offline
PostPosted: Sat Sep 10, 2016 6:28 pm    Post subject: Re: Steering wheel removal - tutorial (1971 bus) Reply with quote
Well, Here I am again... dealing with a steering wheel, but I'm doing a lot this time so bear with me.
The ignition switch fried last weekend at Bug O Rama in Sacramento. With the Help of Steve from Wolfgang International, I was taught how to hotwire it. I'm a little disturbed at how easy it is.
I got home, bought a new ignition switch, and figured that since I'm taking a few thing apart, I might as well fix the horn - it's a safety thing regardless.
Horn cap off.
Found a big ass washer and got the steering wheel off.
Removed the circlip and washer so I could remove steering column.
Removed the steering box coverplate.
Removed the steering bushing and the steering shaft.
*Good thing I did this - the wire that goes down the steering shaft had no connector at the end of it.
What to fix:
The ground tab on the inside of the column is broken - need to replace that.
They sell these at O Reilly
And as long as the cover plate is out, I might as well hit it a few times with the rattle can.
So the Question...
This wire hanging out here:
...is the one that connects to the steering column. right?
so... where does the wire that runs down the steering shaft connect. It connects to the horn tab at the top, but where is the bottom connect to?
I need to remake a wire anyway, this is it currently:
And just in case anyone wanted to know the part number for the column:
Thanks. I'll take pictures as this rather large project progresses.
pjalau
pjalau is offline
PostPosted: Sat Sep 10, 2016 6:33 pm    Post subject: Re: Steering wheel removal - tutorial (1971 bus) Reply with quote
Update on above... I just remembered. And perhaps someone can confirm for me.
The tab on the steering column is the actual power for the horn. The Ground runs down the column and the wire is connected to a round tab which doubles as a washer on the steering bushing.
The screw connecting to the steering bushing must be connected to one of the two metal tabs so the ground is solid to the steering box.
From 2006.
http://www.thesamba.com/vw/forum/viewtopic.php?t=176338
Looks like I got it right.
-P
Tcash
Tcash is offline
PostPosted: Sat Sep 10, 2016 7:29 pm    Post subject: Re: Steering wheel removal - tutorial (1971 bus) Reply with quote
Horn All
Bulli Klinik
Bulli Klinik is offline
PostPosted: Wed May 10, 2017 8:06 am    Post subject: Re: Steering wheel removal - tutorial (1971 bus) Reply with quote
This could be helpful to some of you resourceful owners. I recently made this puller out of an old C-clamp and the hub of a bent pulley. The hub fits and works great!
Hope this helps!
I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs
pvlocal
pvlocal is offline
PostPosted: Sun Jun 11, 2017 7:15 pm    Post subject: Re: Steering wheel removal - tutorial (1971 bus) Reply with quote
Awesome write-up. Thanks!
jtauxe Premium Member
jtauxe is offline
PostPosted: Tue Jul 11, 2017 1:45 pm    Post subject: Re: Steering wheel removal - tutorial (1971 bus) Reply with quote
It seems to me that an important difference between the washer system and Aeromech's fancy puller is that the washers pull on the plastic (which is OK if you don't want to salvage the wheel) and the fancy puller pulls on the metal, not stressing the plastic.
Is that the case?
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
busdaddy
busdaddy is offline
PostPosted: Tue Jul 11, 2017 2:26 pm    Post subject: Re: Steering wheel removal - tutorial (1971 bus) Reply with quote
Is that the case?
Not if you do it right, the washers should bear on the metal area just like the purpose made tool.
Слава Україні!
larryducas
PostPosted: Tue Jul 11, 2017 3:44 pm    Post subject: Re: Steering wheel removal - tutorial (1971 bus) Reply with quote
Is that the case?
FYI, the harbor freight bearing puller does not damage the plastic, only pulls on the metal parts. I have used this several times, very successfully.
The damage in the picture was from the washer method. My washers were inferior.
bikeboy480
bikeboy480 is offline
PostPosted: Sat Nov 11, 2017 3:00 pm    Post subject: Re: Steering wheel removal - tutorial (1971 bus) Reply with quote
Does anyone know the size of the retaining nut? I managed to damage the threads on mine trying to remove the steering wheel and I need to replace it.
turbobrian
turbobrian is offline
PostPosted: Wed Jun 06, 2018 4:45 pm    Post subject: Re: Steering wheel removal - tutorial (1971 bus) Reply with quote
Anyone have a horn button and ring for this steering wheel for sale? Cant seem to find one anywhere and am in desperate need. I can be emailed at
[email protected]
I think this is a 74-78 wheel?
busdaddy
busdaddy is offline
PostPosted: Wed Jun 06, 2018 5:17 pm    Post subject: Re: Steering wheel removal - tutorial (1971 bus) Reply with quote
[email protected]
[img]pic]
https://www.thesamba.com/vw/classifieds/search.php...ton=Search
Слава Україні!
turbobrian
PostPosted: Wed Jun 06, 2018 5:30 pm    Post subject: Re: Steering wheel removal - tutorial (1971 bus) Reply with quote
ty I didnt even think to look for classifieds. can anyone tell me what year wheel that is?
Tcash
Tcash is offline
PostPosted: Wed Jun 06, 2018 5:38 pm    Post subject: Re: Steering wheel removal - tutorial (1971 bus) Reply with quote
Horn All
turbobrian
PostPosted: Wed Jun 06, 2018 5:41 pm    Post subject: Re: Steering wheel removal - tutorial (1971 bus) Reply with quote
so i need this
https://www.thesamba.com/vw/classifieds/detail.php?id=2128446
and all horn buttons will fit?
Tcash
Tcash is offline
PostPosted: Wed Jun 06, 2018 5:55 pm    Post subject: Re: Steering wheel removal - tutorial (1971 bus) Reply with quote
They list the horn button from 1968-79
https://www.justkampers.com/211415671-043-horn-pus...-1979.html
Thnx to mayor ratwell
Thnx to jersey
turbobrian
PostPosted: Wed Jun 06, 2018 5:59 pm    Post subject: Re: Steering wheel removal - tutorial (1971 bus) Reply with quote
ok so buy this
and i can buy any horn button to fit.
sorry im not a vw bus guy fixing this bus for someone and this is all new to me.
Page 7 of 8
