werksberg Samba Member
Joined: February 08, 2005 Posts: 2151 Location: Prescott Valley, AZ
Posted: Tue Jan 27, 2009 8:06 pm Post subject: |
Nice write up.....for a really locked on one.
But I have never ran across a steering wheel that needed a puller and I used to sell the Formuling France steering wheels by the gross.
Loosen but leave the nut on the shaft to prevent it pop of big time.
After the nut is lose, with one hand slightly pull up and the other push down. Don't over do it, just slightly.
Then switch direction and back & forth...should come off without any damage. _________________ Werksberg Products....Products that work!
Follow my new products on my Facebook Werks Berg
Click the below ADs link for products & feedback.
Search "werksberg" on Photobucket for products photos & Please remember to buy "American made products!" |
superman73 Samba Member
Joined: December 21, 2006 Posts: 2032 Location: Crystal Springs, Mississippi
Posted: Tue Jan 27, 2009 8:24 pm Post subject: |
panicalum wrote: |
What did you use to cut the washers?
What is the distance between the two cuts? |
i used a side grinder with a thin cut off blade in it. i just eyeballed it after reading this thread. _________________ Chuck
Jesus Saves
70 deluxe bus
74 ghia 1776 dual carb
67 manx clone
various other parts cars.
http://www.thesamba.com/vw/forum/viewtopic.php?t=228364&highlight=superman73sb+bellsouth |
Jeff Geisen Samba Chaplain
Joined: December 21, 2004 Posts: 1882 Location: N.W. Georgia
Posted: Wed Jan 28, 2009 6:13 am Post subject: |
...sometimes turning one spline will not straighten the steering wheel spokes, it'll be off to one side or the other but never align straight. If you run into this problem, you may have to make a fine adjustment to the Pitman arm by loosening the clamp and turning the connecting rod. _________________ I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab |
Justin Samba Member
Posted: Wed Jan 28, 2009 9:13 am Post subject: |
I haven't had to take mine off yet (knock on wood) but this will come in handy when/if I do. Thanks.
-Justin _________________ "I am convinced that [nothing] in all creation will be able to separate us from the love of God that is in Christ Jesus our Lord."
-Romans 8:38-39 |
Bookwus Samba Member
Joined: August 30, 2003 Posts: 1786 Location: City of Roses
Posted: Wed Jan 28, 2009 9:55 am Post subject: |
Hiya Anchovy,
So.......is Koch now offering rebuilt early Baywindow steering wheels? Or was this a special job for you?
Itried the Koch website but it leaves a good deal to be desired. _________________ Mike
1970 AS Bug
1970 Bus - The Ruptured Duck
Have an AutoStick? Check out www.auto-stick.com |
cool karmann collected Samba Member
Joined: November 23, 2008 Posts: 631 Location: Oxford, U.K.
Posted: Wed Jan 28, 2009 2:36 pm Post subject: |
OK bus types, here's a question,
In the picture below it is just possible to make out a small split collar on top of the spring that goes over the column. Now my 71 has this spring and collar arrangement but the collar is UNDER the spring. I pondered which way round the two parts should go (thinking that a PO may have had it apart at some stage) but I found that the collar was required to be under the spring or there was very noticable play in the column otherwise.
Unless of course there should be a collar above and below the spring...
Any thoughts on this?
Ant |
Anchovy Samba Member
Joined: August 05, 2000 Posts: 2922 Location: San Diego, CA
Posted: Wed Jan 28, 2009 3:22 pm Post subject: |
Bookwus wrote: |
Hiya Anchovy,
Itried the Koch website but it leaves a good deal to be desired. |
Yes, his web site is pretty weak.
I saw him offering them at the VW shows and bought mine from a customer that got it from Koch but never took delivery. (It was shipped to me by Koch's). When I got the wheel it was very poorly done. There were cracks near the horn button and big drips in the paint. I sent it back and Koch's crew took care of it. It looks very good now.
I think, however that the color is not correct. The wheel should be gray/black but the wheel is painted gloss black. It still looks good but I think originally the wheel matched all the other gray/black painted parts. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Jan 28, 2009 3:31 pm Post subject: |
cool karmann collected wrote: |
Ant |
Collar goes under the spring, Bentley: section 2, p27. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Jan 28, 2009 3:37 pm Post subject: |
superman73 wrote: |
panicalum wrote: |
i used a side grinder with a thin cut off blade in it. i just eyeballed it after reading this thread. |
I used an abrasive chop saw and just cut the sides parallel and about the width of the hole in the washer. A hack saw with a fresh blade would also do the trick. |
Orangeena Samba Member
Joined: February 06, 2008 Posts: 133 Location: Berkshire - UK
Posted: Mon Feb 02, 2009 3:34 am Post subject: |
werksberg wrote: |
Then switch direction and back & forth...should come off without any damage. |
Hey werksberg, thanks for the tip! I had been hauling on my wheel for ages with no luck for ages. I was planning to build the jig mentioned here and read your post. I soaked the thing in WD40 and left it over night and it came off after 5 minutes of wiggling as you suggested. And no damage.
Appreciate it.
Max _________________ 1973 Bay in L20B
- Originaly a panel van
- Partial Westy Interior
- Viking Spacemaker roof
- Slider of a donor bus
- Doors imported from Australia
- 22nd Owner ! |
Posted: Mon Feb 02, 2009 10:56 am Post subject: |
Your welcome. It is a rocking motion to get them lose but leave the nut on it so you won't get smacked in the face..... _________________ Werksberg Products....Products that work!
Ian Samba Moderator
Posted: Tue Apr 21, 2009 4:42 pm Post subject: |
I just took the steering wheel off of my '66 Splitty using this method, the washer method, and it worked a charm! I had to stand outside of the Bus so that when it popped off I wouldn't get hurt. When it finally popped the washers went flying but the wheel was off.
Splendid! _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012 |
Ian Samba Moderator
Posted: Mon Apr 27, 2009 11:02 am Post subject: |
I would like to add that I also did a 59 Panel using this method. My friend was shocked when I told him what we had to do to get his steering wheel off. Once you tighten the puller all the way, give it that last final tighten and the whole contraption goes BOOM, be sure to be standing OUTSIDE of the Bus. This is probably the craziest thing I've ever had to do with a Bus, definitely the most violent. The puller was light on the threads and didn't mar them at all.
Props for this method. _________________ All your Buses are belong to us.
camit34 Samba Member
Joined: January 14, 2006 Posts: 1567 Location: Commerce City CO
Posted: Fri May 22, 2009 9:20 pm Post subject: |
Thanks for the write up on this. Found it through the search and it helped greatly. _________________ In search of a Vanagon
1971 Westy (SOLD)
1971 Deluxe (SOLD)
1967 Freedom Camper (SOLD) |
pjalau Samba Member
Posted: Sat May 23, 2009 1:42 pm Post subject: |
Very helpful write up. I installed my new one from Just Kampers:
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sun May 24, 2009 10:32 am Post subject: |
Damn, That's pretty! |
mygreenbus Samba Member
Joined: February 14, 2007 Posts: 1154 Location: Palm Coast, FL
Posted: Sat Jun 20, 2009 1:02 pm Post subject: |
Anchovy. I used the big washer trick today. Loved the "pop" as the wheel came off. Off, recentered and on in about 10 minutes. _________________ '72 Bus |
Desertbusman Samba Member
Posted: Sun Jun 21, 2009 3:42 am Post subject: |
Sure hope people arn't removing the wheel to reposition it level when driving straight ahead.
As compared to-
Repositioning the wheel level when the steering box is centered per the manual. And then adjusting the draglink so the bus goes straight ahead when the box is centered.
If you are removing the wheel to reposition it level, either you are screwing up or the prior owner screwed up. Him or you, which one? There is nothing that would ever require the steering wheel to be repositioned from it's original position on the steering column except for someone changing out the steering box.
If you are changing the wheel to get it level, don't. Until after you have determined that the steering box and drag link are correct. If those arn't correct you will have sloppy steering and also damage the steering box. And don't just assume that yours is correct. If it is correct you have a rare bus that has never been touched since new or else it has only been properly worked on. _________________ 71 Superbug
71 Westy |
Posted: Sun Jun 21, 2009 4:02 am Post subject: |
The PO had a new (rebuilt) steering box put in and it got out of whack then. All else is good and now my turn signals cancel again. _________________ '72 Bus |
cyberdyne systems 101 Sambanator
Joined: September 03, 2004 Posts: 415 Location: in my own little world
Posted: Tue Sep 08, 2009 12:04 pm Post subject: |
superman73 wrote: |
panicalum wrote: |
It only bloody works! I thought it will never come off and I was huffing and puffing, but then it just came away _________________ When I think of something to say - I'll be the first to know
56' Oval
71' Westy |
