Steering wheel removal - tutorial (1971 bus)
crushie
crushie is offline
PostPosted: Sat Nov 10, 2012 9:27 pm    Post subject: Reply with quote
You took way too much metal out of your so called washers. They bent right where there was the least amount of plate. Use some penetrant on the wheel also.
1974 VW Combi 1800 Auto. Weber 32/36
Red Fau Veh
Red Fau Veh is offline
PostPosted: Sun Nov 11, 2012 5:42 pm    Post subject: Reply with quote
Well my "so called washers" worked, I had to align them better but the steering weel came off this morning. Now I need a lock housing to replace this old one, and I have had zero luck finding one. I found newer bus ones and old bus ones, but none like this. Confused
1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote:
Swivel Seat panels are for people with no friends Crying or Very sad
busdaddy
busdaddy is offline
PostPosted: Sun Nov 11, 2012 5:57 pm    Post subject: Reply with quote
Good to hear it finally worked, I agree on the over relief of the washers, sometimes they are stuck like a Mofo as you discovered, hope you kept all the chunks to glue back in to the wheel hub.
For the lock contact Steelersbus or Gabvwkey, both have ads in the classifieds.
Слава Україні!
GeorgeO.
GeorgeO. is offline
PostPosted: Mon Nov 12, 2012 8:17 pm    Post subject: Reply with quote
Where did you get those washers?
Red Fau Veh
PostPosted: Mon Nov 12, 2012 10:35 pm    Post subject: Reply with quote
The real deal washers are 3.5" and that is not always easy to find, but Fastenal is a good place to try or a Fleet supply something like that, maybe Lowes. I made mine.
bigbore
bigbore is offline
PostPosted: Mon Nov 12, 2012 10:59 pm    Post subject: Reply with quote
what is wrong with this one? and what year is it for?
where its cold and snowy
Red Fau Veh
PostPosted: Tue Nov 13, 2012 8:28 am    Post subject: Reply with quote
Well it is a 1971 bus igniton lock housing, I am not sure if it is usable now because 2 very small springs fell out that were mashed up. I don't want to put everything back together if this part is no good. so I though a new one would be a easy fix but noone has them. Do you know if mine will work still? (if you look close at that picture, the tiny sprigs were like the one at the bottom center of that pic, it's a tiny spring that was all distorted.
aeromech
aeromech is online now
PostPosted: Tue Nov 13, 2012 8:33 am    Post subject: Reply with quote
I'll bet Busdaddy could tell you how to take springs out of a ball point pen and fix that steering lock.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
regalasr
regalasr is offline
PostPosted: Tue Nov 13, 2012 11:57 am    Post subject: Reply with quote
When you go to paint your re-done steering wheel, urethane paint is the only stuff that will hold up. The paint is pricey, by the time you add up all your supplies, the repro wheel will compare.
You could use another kind of paint and then wrap the wheel with one of those leather wheel wraps as a compromise.
bigbore
bigbore is offline
PostPosted: Tue Nov 13, 2012 12:19 pm    Post subject: Reply with quote
do you know if those springs came from the locking mechanism or the key part? I have those parts I think I can part with some.
Red Fau Veh
PostPosted: Tue Nov 13, 2012 12:58 pm    Post subject: Reply with quote
Here is a pic of where the spring came from. It may have been one spring broken in two. It came from that small round mark area on the lock pin part I am holding in the pic.
bigbore
bigbore is offline
PostPosted: Tue Nov 13, 2012 1:28 pm    Post subject: Reply with quote
heres one I just pulled out of a 71 it has no holes drilled in it and the plate is on it I see yours was missing its plate that is why it popped apart. If you want it PM me.
aeromech
PostPosted: Tue Nov 13, 2012 1:59 pm    Post subject: Reply with quote
[/quote]
Now those fingers look like they belong to a mechanic
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
bigbore
bigbore is offline
PostPosted: Tue Nov 13, 2012 2:06 pm    Post subject: Reply with quote
aeromech wrote:
Now those fingers look like they belong to a mechanic[/quote]
Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing Laughing NOW THATS FUNNY!
crownline
crownline is offline
PostPosted: Tue Nov 13, 2012 2:07 pm    Post subject: Reply with quote
You can see why the keyboard is all dirty. Must be alot of searching for info on how to work on ACVW's. No time to stop and clean.
1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
Wish I still had the ones I got rid of.
"It"s got some dings and dents and neither of us is going to SEMA."(Update, I went to SEMA in 2019 but the Bus stayed home)
[url=http://www.vw-mplate.com/mplate-8446.png]Click to view image[/URL]
bigbore
bigbore is offline
PostPosted: Tue Nov 13, 2012 2:10 pm    Post subject: Reply with quote
Mine IS the keyboard of a mechanic trying to answer all your questions as I fix cars all day long.
aeromech
PostPosted: Tue Nov 13, 2012 3:02 pm    Post subject: Reply with quote
I'm sure there's a little bit of internet porn involved too.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
bigbore
bigbore is offline
PostPosted: Tue Nov 13, 2012 3:12 pm    Post subject: Reply with quote
You can see that from there? Shocked ah-or-a-that alleged activity what do you have a black light. Laughing
aeromech
PostPosted: Tue Nov 13, 2012 3:16 pm    Post subject: Reply with quote
bigbore wrote:
You can see that from there? Shocked what do you have a black light. Laughing
hahahaha. You guys need something to help keep the blood flowing on those cold days up in the north.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Red Fau Veh
PostPosted: Tue Nov 13, 2012 4:49 pm    Post subject: Reply with quote
You folks are great haha! Very Happy Yea that's a dirty keyboard of a mechanic alright, or a dismantler anyhoo! Wink The fingers in the lock picture are mine haha, but uh, yea they are kinda beat up anymore. Laughing
Page 5 of 8
