barefootwestie Samba Member
Joined: September 19, 2005 Posts: 1551 Location: Johns Island, SC
Posted: Wed Jul 30, 2008 7:33 pm Post subject: Driver's Side Rear Vent Window |
I am preparing to star working on my Driver's side Rear window, and need to verify everything I need before starting.
The present vent window will open but appears to be so rusted out on the bottom that it could push out.
1. Does this mean that I need a new(used) metal frame?
If i'm understanding the pictures I have seen, there is the main window seal, then also a seal for the vent window itself.
2. Is this the only parts I need to repair the entire window?
Thanks _________________ My Bus Restoration Blog
https://myvolkswagenbus.com/
1973 Westfalia
"Getting better....one repair at a time."
Other VW's owned through the years, in no particular order:
'67 Beetle,
'67 Ghia Hardtop,
'72 Ghia Convertible,
'72 Westfalia |
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Posted: Wed Jul 30, 2008 9:18 pm Post subject: |
The bus vent window is chrome. The Westy vent window is black. I have not seen any good used black windows.
Yes, you will need to remove the big window first, then the vent window. Pull it to the rear about an inch and then it tilts out from the bottom.
Or you can put in one window from the pass side and forget about the vent window.
The bottom pivot rusts and then shears off..... then the window flops when open.
I had another person ask me for a vent window. Sent him pics and a price. Never heard back......
Here are pics of it, ready to use as is with a very nice seal:
Bookwus Samba Member
Joined: August 30, 2003 Posts: 1786 Location: City of Roses
Posted: Wed Jul 30, 2008 9:21 pm Post subject: |
Hiya bare,
I have mine out right now also.
The rear vent window (hmmmm....all the rear vent windows) have a frame that lives inside a rubber seal. Be careful when you go to remove that frame and seal assembly. The frame has two metal tags that should be bent over the pinch weld in the window opening. Look for those two tags on the front side of the window. You'll have to peel back some of the rubber seal on the inside of the bus to locate them.
Only after you get the entire assembly out will you be able to get a good look at the frame. Many are not in very good shape due to rust and corrosion. This is especially true of the area around the bottom post.
Basically if you have a new seal (and your frame is OK - be sure to clean it thoroughly and repaint it) you're set to go for reinstallation. I'm sitting on mine right now because my assistant (my wife) has a bum wrist right now. The vent window seal is a beast all unto itself and has nothing to do with the regular window seal.
The vent window can be taken out and reinstalled without having to remove the main window. Matter of fact that's just what I'm doing. _________________ Mike
1970 AS Bug
1970 Bus - The Ruptured Duck
Have an AutoStick? Check out www.auto-stick.com |
TRN9 Samba Member
Joined: September 29, 2006 Posts: 308 Location: Where its rainy
Posted: Wed Jul 30, 2008 9:37 pm Post subject: |
Karl you have cleaner hands than I expected! If I even look at my bus my hands get dirty _________________ '72 Panel ~ B-Bus
Camper Special Club Member
Posted: Thu Jul 31, 2008 6:13 am Post subject: |
Thanks for the responses and the photos, Karl.
So, if I'm understanding correctly, if the bottom part is rusted, there are no parts that can really be replaced on it? So, if part of the frame is rusted out, I just need a whole new frame ? _________________ My Bus Restoration Blog
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia |
Posted: Thu Jul 31, 2008 7:46 am Post subject: |
I see what you mean Karl about black framed Vent Windows. The classifieds are full of chrome ones, but no black ones. I wonder if the chrome could be sandblasted off? _________________ My Bus Restoration Blog
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia |
2VWs1BMW Samba Member
Posted: Thu Jul 31, 2008 8:22 am Post subject: |
Someone should snap up that window Karl has. Good ones are very hard to come by. During my restoration, I made one good one from 2 or 3 so-so ones. Took the bottom pivot and welded it onto a good window. New seals and painted the chrome window frame after scuffing it up. Still not the same, but it looks good.
Also blasted the outer frame and POR15'd it.. came out real nice. _________________ - Brian -
'17 Alltrack
'99 ///M Coupe w/48k mi - Bimmerforums
'77 Westy w/156k mi |
Karl Samba Member
Posted: Thu Jul 31, 2008 9:17 am Post subject: |
TRN9 wrote: |
Karl you have cleaner hands than I expected! If I even look at my bus my hands get dirty |
Work smarter, not harder
Exam gloves protect you from chemicals....... |
Herbst '71 Samba Member
Joined: April 14, 2004 Posts: 245 Location: Augusta, GA
Posted: Thu Jul 31, 2008 11:31 am Post subject: |
Thanks. I just emailed Shane about them. But they are chrome, I just searched the classifieds and emailed a bunch of folks looking for black ones, so we'll see what turns up. Thanks for keeping your eye out for me. _________________ My Bus Restoration Blog
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia |
quigleyp Samba Member
Posted: Mon Jun 15, 2009 7:40 pm Post subject: |
trying to change out my vent wing fastener on drivers side...I assume the window has to come out...any 1,2, 3 directions for this one? _________________ 79 single cab with Westfalia wide bed and german shop logo
84 Vanagon
2007 Beetle (totaled it)
and a 63 splitty that got away |
peaceful warrior Samba Member
Joined: January 22, 2005 Posts: 5274 Location: Taoswest, USA
Posted: Tue Jun 16, 2009 7:47 am Post subject: |
barefootwestie wrote: |
Thanks. I just emailed Shane about them. But they are chrome, I just searched the classifieds and emailed a bunch of folks looking for black ones, so we'll see what turns up. Thanks for keeping your eye out for me. |
I think I have a couple of black ones, I will check this afternoon and PM you!
My Westy had a solid window on that side and I think I will keep it in. Stripped 2 Westys, so one should be good.
Check my ad. http://www.thesamba.com/vw/classifieds/detail.php?id=794840 _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Jun 16, 2009 8:09 am Post subject: |
quigleyp wrote: |
trying to change out my vent wing fastener on drivers side...I assume the window has to come out...any 1,2, 3 directions for this one? |
If it's just the latch then the window can stay in, but you will need a super tiny drift to punch out the split pin that retains the arm to the window frame. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9142 Location: Syracuse, NY
Posted: Tue Jun 16, 2009 8:16 am Post subject: |
peaceful warrior wrote: |
Check my ad. http://www.thesamba.com/vw/classifieds/detail.php?id=794840 |
The post you're replying to is almost a year old...... _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
Posted: Tue Jun 16, 2009 9:20 am Post subject: |
OOPS! I'm still writing 2008 on my checks...
thanks for the heads up! _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
TOOB Member #15
Brian |
Posted: Tue Jun 16, 2009 10:07 am Post subject: |
Gosh..a whole year. And ask me if it is installed yet...no. But I do have the parts, just haven't gotten around to it yet. _________________ My Bus Restoration Blog
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia |
Bleyseng Samba Member
Posted: Tue Jun 16, 2009 11:18 am Post subject: |
I just put in a nice chrome one, who cares if its black or if you do paint in black. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
SGKent Samba Member
Posted: Tue Jun 16, 2009 11:21 am Post subject: |
Karl sold us a really nice vent window and I can tell you that we were very pleased with it. His items are as close to NOS as you will get. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
ccpalmer Samba Member
Joined: September 17, 2006 Posts: 3850 Location: Ann Arbor, Michigan
Posted: Tue Jun 16, 2009 6:37 pm Post subject: |
I found a great black one in the classifieds a year ago... keep looking..
Someday I'll get around to replacing my chrome one on my '71 Westy... _________________ '71 Westy |
Anovib Samba Member
Posted: Sun Aug 30, 2015 6:27 am Post subject: 73 bus rear vent window frame ???? |
Having trouble locating a new or used rear wing window vent outer frame. Mine fell apart in my hands when I removed it.
appreciate any help locating one |
