Lowdown Dirty Rat Samba Member
Joined: June 25, 2005 Posts: 878 Location: Cornwall, UK
Posted: Wed Aug 06, 2008 12:40 pm Post subject: SWF washer bottle |
would this washer be the correct optional one for a '52?
What is the correct spray jet/nozzle for this?
and was there always only a single jet/nozzle used?
thanks
Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Posted: Fri Aug 08, 2008 6:12 pm Post subject: |
the style that you pictured is the later style.
the earlier style has the connections on the backside of the pump and the pump rod sticks out of the dash and is activated by pushing it in.
the later style has the connections at the front of the pump and the pump is activated by pulling it out.
http://www.thesamba.com/vw/archives/lit/52accessories.php
_________________ .
Wanted:
Scotty M Samba Member
Posted: Fri Aug 08, 2008 10:52 pm Post subject: swf |
When you say later style do you have specs. on year change? |
janerick3 Samba Member
Lind Samba Member
Posted: Sat Aug 09, 2008 7:04 am Post subject: Re: swf |
Scotty M wrote: |
I have an earlier style with the code AJ (jan '57) and later style which has the code JH (oct '56) I have a couple others which I need to clean up to read the date codes. those dates do not line up with the literature that I have seen. the '52 literature shows the earlier style, and I have a couple pieces of literature from the '60s that show the later style. IN2VWS might have some input on this also, as he has quite a bit of literature that might have reference to these pumps.
I have seen dozens of the later style, but the only earlier style one that I have seen is the one that I pulled out of a '56 beetle. the later pumps are relatively easy to find. unfortunately there is an obvious difference between the two when they are installed into a car. _________________ .
Wanted:
Posted: Sat Aug 09, 2008 10:33 am Post subject: swf |
thanks for all the info. its kinda wierd that there could be a 56 with a pull type and a 57 with a push type is there any reason to why this is? |
Posted: Sat Aug 09, 2008 11:45 am Post subject: |
cheers,
could you post a picture of the early type one you have, especially the jet ends.
thanks |
IN2VWS Samba Member
Joined: January 29, 2006 Posts: 2521 Location: Australia
Posted: Mon Aug 18, 2008 3:30 pm Post subject: |
You could get them with push, pull, foot and electric pumps.
as can be seen here in a '54 catalog
_________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³
𝟵_𝟭_𝟰¹⁹⁷³ |
Posted: Tue Aug 19, 2008 10:07 am Post subject: |
and the '52 catalog has two jets and the '54 one. But i would think that wasnt a change but another choice? |
686 bus-boy Samba Member
Posted: Thu Jun 11, 2009 1:57 pm Post subject: |
Can anyone tell me where abouts to find the date code or tell me the years this was made-it is a push pump.Thanks.
jimmy1 Samba Member
Joined: April 17, 2001 Posts: 1569 Location: http://www.thedeafvolks.com
Posted: Thu Jun 11, 2009 2:38 pm Post subject: |
cool topic,
i have all the same set up, except for the glass cansiter. Mine has rubber/plastic bag, wonder where do the bag go on? _________________ North Hollywood, CA
1956 Kabrolett
"I'd rather be driving my VW thinking about God than sitting in church thinking about my VW."
check out my classified ads, lots of rare parts/accessories for sale. |
tomas persson Samba Member
Joined: December 09, 2002 Posts: 220 Location: Sweden
Posted: Mon Jun 15, 2009 12:51 pm Post subject: |
I have the glass jar for you... and I dont have the rest. |
cj1971 Samba Member
Joined: July 18, 2006 Posts: 121 Location: Hythe Kent UK
Posted: Sat Sep 12, 2009 7:48 am Post subject: SWF Accessory Washer Bottle Kit |
Does anyone know where the date code is on the pump please???? |
habitnz Samba Member
Joined: August 03, 2007 Posts: 50 Location: Gisborne NZ
Posted: Sun Jun 12, 2011 2:53 pm Post subject: |
I have one of these unit's in a 57 Kombi I was given, where these installed in kombi's originally? seem's like they were in the beetle but cant see and having being installed in busses, mine is complete apart from the front knob is missing, so if anyone has one would be interested.
The bottle to mine was just sitting on the cab floor.
I am going to remove the unit today and cleat up so will post some pics up later. |
Rag53 Samba Member
Joined: February 02, 2013 Posts: 22 Location: Buena Park, CA
Posted: Wed Mar 11, 2015 5:22 pm Post subject: |
Does anyone have a full kit NOS swf washer kit Split oval. |
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Tue Mar 31, 2015 3:56 am Post subject: |
NOS washer kit???
I would give you little chance to locate an unused one straight out of the factory wrapper. These were sold to be built into cars, so I assume shelf life for complete units outside of the SWF factory must have been short. _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
