64bajaboy Samba Member
Joined: July 17, 2006 Posts: 34 Location: cle elum, WA
Posted: Thu Aug 07, 2008 4:23 pm Post subject: 17 inch with 4x130 |
does anybody know of any brand of rim that makes a 17 inch with the 4x130 lug pattern. its drivin me crazy cause i keep lookin and i cant find any. _________________ * 64 baja bug in progress
*2001 cr250
* 2003 polaris RMK 800 modded |
Posted: Sun Aug 10, 2008 7:10 pm Post subject: |
anyone? _________________ * 64 baja bug in progress
*2001 cr250
buggpower Samba Member
Posted: Sun Aug 10, 2008 8:34 pm Post subject: |
it looks like all they have is 4 lug _________________ * 64 baja bug in progress
*2001 cr250
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17971 Location: Eugene, OR
Posted: Mon Aug 11, 2008 7:51 am Post subject: |
4 X 130 is what you said you're looking for! |
Posted: Tue Aug 12, 2008 4:29 pm Post subject: |
sorry i ment to say all they have is 5 lug. man does that make me look stupid _________________ * 64 baja bug in progress
*2001 cr250
ian c Samba Member
Posted: Tue Aug 12, 2008 6:34 pm Post subject: |
try java .
they'll be able to sort you out _________________
ian c wrote: |
only losers have quotes in their sig . |
ian c Samba Member
Posted: Tue Aug 12, 2008 6:40 pm Post subject: |
sorry , just noticed you said 17"
ian c wrote: |
ian c Samba Member
Posted: Tue Aug 12, 2008 6:41 pm Post subject: |
maybe one of the modern "multi-fit" wheels ?? _________________
ian c wrote: |
ubercrap Samba Moderator
Joined: July 01, 2004 Posts: 1060 Location: Ridley Park, PA
Posted: Wed Aug 13, 2008 6:56 am Post subject: |
ian c wrote: |
maybe one of the modern "multi-fit" wheels ?? |
Nope. I think you'll probably find you need to change the lug pattern on your car through one of several methods, or run adapters depending on your application/desired wheel offset/comfortability with them- to run the wheels you want. _________________ '74 412 wagon
(2) '74 412 2dr. sedan
'73 412 2dr. sedan |
Posted: Wed Aug 13, 2008 12:10 pm Post subject: |
I had knockoff wire wheel hubs redrilled from 4X110 to 4X130 for $120. If you pick ANY 4 lug 17" wheel you can redrill to match if needed. I think the 15's look better anyway! |
Maimas13 Samba Member
Joined: July 06, 2004 Posts: 642 Location: Redwood City CA
Posted: Thu Aug 14, 2008 9:52 pm Post subject: |
you can always have your drums/rotors redrilled then you can run any bolt pattern in existance, that should open up a world of different wheel choices _________________ MAIMAS... read it backwards
(.o\ ! /o.) 62 chopped, dropped, cal looked, oval grafted, 57 styled, ragtop with polk audio sound system, driven daily by an 18 year old
A must read for understanding tires sizes and wheel offsets
Go Bears!!! Mech E |
Franklin's VW Werks Samba Member
Joined: November 25, 2002 Posts: 138 Location: Pacific Northwest
Posted: Fri Aug 15, 2008 2:31 pm Post subject: |
Maimas13 wrote: |
you can always have your drums/rotors redrilled then you can run any bolt pattern in existance, that should open up a world of different wheel choices |
Agreed. This would be the best way to do whatever you want. It's not that expensive. You're a little far away, but if you're interested we can help you out (near Seattle). Give us a call or shoot us an email via our contact form. _________________ Franklin's VW Werks
Service and Parts for the Pacific Northwest and Worldwide.
Custom Narrowed Beams, Wilwood/Porsche Brake Kits, Roll Cages and More!
On MySpace
SBS #24 |
lvwagens Samba Member
Joined: September 27, 2007 Posts: 41 Location: Las Vegas, Nv
Posted: Thu Oct 30, 2008 12:56 pm Post subject: |
ya thats what i had to do, i redrilled front and rear to 5x112 and im running 17x7's and i love them!
J1 Samba Member
Posted: Tue Nov 25, 2014 2:01 pm Post subject: |
I'm wondering if anything has changed in the last 6 years since the last post here.
Still no 4x130 17" wheels?
Is drilling drums/rotors still considered a reasonable way to open up options to 17" wheels? If so, I assume it's not a home garage job. What are the steps? _________________ 1971 Ghia coupe. Assume I know nothing and you'll be pretty darn close to the truth. |
chickengeorge Samba Member
Joined: August 18, 2004 Posts: 5634 Location: Spokompton Warshington
Posted: Sun Nov 30, 2014 12:24 pm Post subject: |
J1 wrote: |
Is drilling drums/rotors still considered a reasonable way to open up options to 17" wheels? If so, I assume it's not a home garage job. What are the steps? |
I ordered blank rotors for my car and had them machined to 5x114.3. Cost me $250.00. |
Brian Samba Moderator
Posted: Sun Nov 30, 2014 3:30 pm Post subject: |
Getting drilled rotors is worth it. Or convert your drums to 5 wide. Many ways to do it. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
JDGas Samba Member
Joined: June 23, 2004 Posts: 1233 Location: Escondido
Posted: Tue Dec 23, 2014 9:06 pm Post subject: |
chickengeorge wrote: |
J1 wrote: |
I got mine from So Cal Imports. They offer a rotor with 5x4.5 & 5x4.75 on the same rotor, but the studs need to be pressed in. I went with the 5x4.5 (same as 5x114.3), opens you up to a ton of front wheel drive wheels options with proper offset for a bug. Plus this pattern fits nicely on a bug rotor or drum.
4x130 is a dead pattern, I don't think its being used anymore. So aftermarket companies aren't going to put money into offering something for a 30+ year old car when nothing currently in production is using it. _________________ 1959 Ragtop Beetle - sold
1958 Danish Beetle
1967 SO-42 West. - sold
1961 Sunroof Beetle - sold
1969 Sunroof Beetle |
marchi Samba Member
Joined: August 10, 2005 Posts: 646 Location: Abilene, Texas
Posted: Wed May 10, 2017 9:04 am Post subject: Re: 17 inch with 4x130 |
i got these from a friend who goes to Mexico alot
_________________ I drive my VW or I walk
'70 Squareback
'21 Tiguan (daughters)
SOLD
'69 Fastback (Flamer) |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13283 Location: Tejas!
