demon1018 Samba Member
Joined: September 12, 2009 Posts: 930 Location: crystal river, fl
Posted: Tue May 27, 2014 2:51 am Post subject: |
Very cool! So I tried to do this to a customers bus that had them done by somebody allready but didnt work so well. The prob seems to be that the key sometimes goes crooked right at the very end of putting it all the way in. If you pull it out a little and straiten it out and pushbit back in it works fine. Half the time you get lucky and it just goes in strait , sometimes it doesnt. The long groove in the key...the one that goes long ways , doesnt allways line up with the little tab stcking out in the lock cyl. But I dont know what to do about it? |
Fatgaz Samba Member
Posted: Sun Jul 06, 2014 9:37 pm Post subject: re keying door locks |
Hi, as a Vdub newby I must be missing something as the door lock barrels wont come out. Help a newby. Thanks. _________________ GAZZZA |
Tcash Samba Member
Posted: Fri Jul 24, 2015 11:22 am Post subject: Rekeying ignition lock |
Rekeying ignition lock.
Estacaco wrote: |
Here's how it's done.
File down the two bronze pins. they've been mushroomed to keep the ignition/cylinder together. May also need to pry a bit with a screwdriver.
Removed.
Remove these shims. They keep the wafers from popping out. It's also been peened in. I filled the inner edges of the groove then tapped the under side of each wafer with a small flat head and hammer. Then pushed them backwards with the same flat head.
Once the shims have been removed you can change the wafers.
Reinstall reverse of diss-assembly. Pound the end back on put a dab of JB weld over each bronze pin.
Now my MK2 Golf and T2 Bus share the same key. |
Sterkman Samba Member
Posted: Wed May 18, 2016 6:31 am Post subject: Re: Rekeying a lock - Tutorial |
Since there are some experienced people on this forum, I was wondering about the following. I want to put a locking engine lid lock on my '67 bus. I do have a three screw locking lid, but it is from a beetle and uses a K-code lock (see below).
Is it possible to fit an L-code cylinder into this lock? I already know rekeying is not an option as an L key will never fit a K barrel. But can I fit an L-code cylinder?
Another question, is this cylinder the same as the cabin door cylinder or different (because I have a set of L-code cabin cylinders extra that I could rekey)...
Maybe someone out there knows...before I take everything apart and find out nothing fits.... |
Tcash Samba Member
Posted: Wed May 18, 2016 9:35 am Post subject: Re: Rekeying a lock - Tutorial |
Sterkman wrote: |
I was told you cannot re-key them.
Tcash |
Posted: Wed May 18, 2016 9:47 am Post subject: Re: Rekeying a lock - Tutorial |
What about fitting a whole L - key lock cylinder in there (from a bay bus)? So are L en K key lock cylinders the same on the outside? |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Wed May 18, 2016 10:07 am Post subject: Re: Rekeying a lock - Tutorial |
You can absolutely re-key any L-code tumbler except the ignition housing. (Thanks for the matching decklid lock, Sunnydog!)
I do not know if the L and K cylinders interchange, but the profiles are remarkably similar, so they might just swap out.
www.airschooled.com |
thelmasdad Samba Member
Joined: July 26, 2016 Posts: 6 Location: Scarborough, Maine
Posted: Tue Jan 10, 2017 7:38 pm Post subject: Re: Rekeying a lock - Tutorial FAQ |
Help with rear hatch lock--
I've got a 78 bus, has the black plastic hatch lock. I was able to get the cylinder out (while damaging the spring collar ), but I can't figure out how to get the tumbler out? Any advice or tricks? I don't see any screws or pins or anything.
Does anyone know if the chrome plated (I believe early 70's model) rear hatch lock is easier to disassemble and/or if it would be compatible with my latch?
Thanks!
vwed Samba Member
Joined: August 07, 2004 Posts: 127 Location: United Kingdom
Posted: Fri Jan 20, 2017 7:27 am Post subject: Re: Rekeying a lock - Tutorial FAQ |
I thought people reading this thread would be interested to read the below extract from one of VW's own workshop manuals.
Note that it mentions that there are in fact 4 different wafers but that only 3 are used on everything apart from the ignition lock. This explains why a wafer might appear to be missing if the "confidential" code lists the 4th wafer.
I have these confidential codes in the form of VW's own key code manual.
I also recently managed to source the mentioned repair kit 211 898 041 A, picture below.
allamaabroad Samba Member
Joined: September 22, 2016 Posts: 560 Location: South Jordan, Utah
Posted: Thu Feb 02, 2017 10:22 pm Post subject: Re: Rekeying a lock - Tutorial FAQ |
Just finished rekeying the locks on my 73 Super after being sent to this thread over in the beetle forums. I had to remove the same 3 wafers in my door locks...strange. Thanks for the great tutorial _________________ Dennis - 1973 Super Beetle ('16-'21)
Debbie- 1970 Baywindow Bus ('21 - Present)
Tin top camper/adventure bus
2180 TW: CNC Panchitos, Beehives Done Right, Web 163, Ultralight Lifters, 1.3 Rockers, CSP Python, Custom Speeduino EFI Conversion with 40mm Throttle Bodies
Distributors are lame
I have a really hard time leaving things alone...
Innovative and affordable engine management systems and EFI conversions for your Vintage VW
Visit https://debbiesaircooled.com/ |
Chrisisw Samba Member
Joined: May 30, 2004 Posts: 148 Location: Amsterdam, Holland, Europe
Posted: Fri Jun 02, 2017 1:05 am Post subject: Re: Rekeying a lock - Tutorial FAQ |
I have a question on rekeying my SG tumbler.
Are the wafers frrm the different key profiles used on aircooled volkwagen interchangable?
Thanks a lot,
Chris |
kkrol Samba Member
Joined: June 13, 2008 Posts: 80 Location: Lorain, Ohio
Posted: Fri Nov 24, 2017 9:30 am Post subject: Re: Rekeying a lock - Tutorial FAQ |
Good information |
Centurion Samba Member
Posted: Wed Sep 26, 2018 5:31 pm Post subject: Re: Rekeying a lock - Tutorial FAQ |
Hello
I don't have a key for any of my lock on my 1971 bus
I want to rekey all the cylinders to work with my ignition key
I understand I should have spare lock cylinders so that I have extra spindles or interior slats to use. Can I buy any door handles to fit my bus and use the cylinders or do they need to be original German or nos?
Additionally I can't find just the lock cylinders to purchase
Any help would be greatly appreciated
Thanks |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Sep 26, 2018 5:45 pm Post subject: Re: Rekeying a lock - Tutorial FAQ |
Contact members Steelersbus or Gabvwkey, they can rework your locks or supply parts. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Sep 28, 2018 4:35 am Post subject: Re: Rekeying a lock - Tutorial FAQ |
Thanks you Busdaddy
I will reach out to them. As always thanks for the help? |
kkrol Samba Member
Posted: Sat Nov 24, 2018 3:48 pm Post subject: |
honeybus wrote: |
Thanks, Karl.
The glove box lock is a SU profile, and the SU profile is compatible with ILCO/EZ U61VW.
My lock is key coded SU 29, so I gues that is the code to punch a SU blank.
As you said, my R profile key is too fat to fit.
(Not only would I NOT lock my glove box, I turn the latch 180 degrees so the passenger does not turn the knob, just pull on it. And if I had my druthers, I would use the ealy bay no knob glove box door I got from Chris Chubb) |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Tue Jan 26, 2021 6:03 pm Post subject: Re: Rekeying a lock - Tutorial FAQ |
busdaddy wrote: |
Contact members Steelersbus or Gabvwkey, they can rework your locks or supply parts. |
I’m going to re-key a lock I got for my engine lid, I’ve pm’d steelerbus but just in case that doesn’t work out, does anyone have a source for more wafers? I would love a kit like was mentioned earlier if anyone knows of a source.
Slightly off topic, why is it on my 77 westy the rear locks/handles have black plastic bodies instead of chrome? Cost? It just seems weird since everything else is chrome. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Wed Jan 27, 2021 4:28 pm Post subject: Re: Rekeying a lock - Tutorial FAQ |
So Steelerbus was a no go. Did other vw vehicles use the R type keys so I can possibly pull from other parts/vehicles? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
