woodendad Samba Member
Joined: March 22, 2012 Posts: 129 Location: Rossville ga
Posted: Sat Feb 09, 2013 5:03 pm Post subject: |
I have read this and read this ...
Ready to start on this part of the project. Having a beam built -4, custom shock towers.
Is there any significant advantage to changing tower height? What would you do and why? |
volksrod71 Samba Member
Posted: Thu Feb 21, 2013 7:57 pm Post subject: |
have a quick question, might have missing it some where, but is anyone running ma785s in the rear of an irs? |
Strawberry Jam Samba Member
Joined: February 10, 2013 Posts: 36 Location: United States
El Fabricator Banned
Joined: November 21, 2012 Posts: 50 Location: Colorado
TalulahThe68 Samba Member
Joined: February 27, 2013 Posts: 3 Location: preston, lancashire, uk
Posted: Fri Mar 08, 2013 11:44 am Post subject: question |
sorry to spruse up an old thread, but this thread has helped me loads, i have a system including the monroe air shocks tyre pump and a mechanical ball valve. the shocks came but with no connector on them to put a air line in. the connector on the air shock is like a cone for a quick release air connector does anybody know which connector i need to connect up an air line. I'm using hydraulic hose with jubilee clips at the moment which aren't the safest. |
Mygfsbug Samba Member
Posted: Fri Mar 08, 2013 12:56 pm Post subject: |
The connector is an odd-ball size. It is a JIC #4 thread. _________________ 1969 Beetle |
Posted: Fri Mar 08, 2013 1:52 pm Post subject: |
so does it just clip onto the shock, like a quick release?? |
Posted: Sat Mar 09, 2013 5:43 pm Post subject: |
Screws onto the threads. _________________ 1969 Beetle |
Maikel_rox Samba Member
Joined: November 08, 2012 Posts: 51 Location: Netherlands
Posted: Fri Mar 15, 2013 8:38 am Post subject: |
Worked on my set-up a little past couple of days. Pretty happy with it.
Posted: Fri Mar 15, 2013 9:25 am Post subject: |
What all parts did you use? _________________ 1969 Beetle |
Posted: Mon Mar 18, 2013 6:38 am Post subject: |
Dropped spindles and a 10 cm narrowed front axle. The airride set-up is from a dutch company called Volksprojects.
They ship to a couple of European countries like sweden, UK, France and Italy.
Compressor is a Viair, Monroe shocks, 20 ltr air tank, 12v 3/8 electric valve's. Very very happy with it.
Don't know the details of the parts, will post them later! |
OG lil E Samba Member
Joined: October 07, 2005 Posts: 24 Location: Mile High City
Posted: Mon Mar 18, 2013 5:35 pm Post subject: |
Maikel_rox wrote: |
I would like to see some pictures of your compressor/tank/valve set-up if you have any. BTW, nice car! E |
Posted: Mon Mar 25, 2013 11:58 am Post subject: |
Only one i have really, will make some more this week if i can find som time! |
Cliff@BrownBags Samba Member
Joined: June 14, 2007 Posts: 649 Location: glen burnie maryland
Posted: Wed May 15, 2013 11:15 am Post subject: |
My buddy bought the 803's for a LP style beam, aka loop ends in both ends. Have you guys had issues with the top and bottom holes being straight with each other? They are cocked a little and bind if you straighten then out.
Anyone else had issues? _________________ its not about what you say you will do oneday, its what you do today that actualy means something. |
Hotahseh Samba Member
Posted: Wed May 15, 2013 9:35 pm Post subject: |
Yea i just got my 803s and i have the same issue. your gona have to give em a little twist |
legotech7 Samba Member
Joined: May 09, 2009 Posts: 879 Location: North Carolina
Posted: Sat May 25, 2013 5:02 pm Post subject: Center grub screws |
Ok just read this entire thread . 52 pages whew, an entire Saturday afternoon.
Great stuff. So bottom line! I have a 2'' in narrowed beam, with adjusters, 2.5'' lowered spindles, MA756 air shocks and running 145/65 r15's in the front. I still have the the spring in the beam. For now I will keep the springs and will do the thru rods at a later date. So if I want to go really low, should I completely remove the center adjusting grub screws on both the upper and lower springs so that they just swing freely as I go up and down on my beam? What are your suggestions on how to do this, and if there are any pros and cons.
Thanks one and all........ |
sfl69 Samba Member
Joined: May 30, 2013 Posts: 1 Location: South Florida
Pothole Samba Member
Joined: June 07, 2013 Posts: 59 Location: Folkestone kent
Posted: Sat Jun 08, 2013 10:35 am Post subject: |
Guys has anyone done this on a k&L beam if so what Monroe shocks did you use?? I'm currently on a standard beam but looking to replace with either a 4 or 2 inch narrowed beam and happy to extend the towers and fit dropped spindles. I would like to be able to get the beam on the ground. Cheers |
rotorbugg Samba Member
Posted: Wed Jul 31, 2013 12:29 am Post subject: Re: Center grub screws |
legotech7 wrote: |
If you corner hard with the center grubs removed, you will destroy the grease seals between the arms/tube and your steering will get stupid sloppy. If you have a weekend cruiser you might get away with it, but driven daily it will eventually happen.
You need to use delrin bushings to last. |
