Question about possible Diesel VW project
Forum Index -> Other VW Vehicles Share: Facebook Twitter
Deacon328
Deacon328 is offline
PostPosted: Wed Aug 13, 2008 10:41 am    Post subject: Question about possible Diesel VW project Reply with quote
I am currently saving up for an AeroTrike kit. The Aerotrike is a fiberglass clad reverse trike that normally uses a Goldwing engine for a powerplant.
I thought about using a VW diesel motor to improve gas mileage. I know the VW diesels have a reputation of being underpowered but think that wouldn't be a problem in this case because of the significant weight loss.
If I were to fabricate a motorcycle frame to house a VW diesel do you think it would be powerful enough? The entire vehicle including passengers would weight less than 2000 pounds.
mike yapps
mike yapps is offline
PostPosted: Thu Aug 14, 2008 3:21 am    Post subject: Reply with quote
Use a TDI engine and it won't be underpowered!
Deacon328
PostPosted: Thu Aug 14, 2008 5:44 am    Post subject: Reply with quote
I wonder if you can modify a TDI to fit a VW Bug transmission?
mike yapps
PostPosted: Thu Aug 14, 2008 4:15 pm    Post subject: Reply with quote
I've seen it done for the gassers, so why not for a diesel. You'll need to get an adapter made for sure.
ManxBug
ManxBug is offline
PostPosted: Thu Aug 14, 2008 5:47 pm    Post subject: Reply with quote
We have a guy in our club that mounted a Turbo Diesel into his Baja Bug.
Air Riders, VW Club
Deacon328
PostPosted: Fri Aug 15, 2008 6:28 am    Post subject: Reply with quote
ManxBug can you please ask the member if they used a commerically available adapter? I would LOVE to use a VW Golf TDI mated to a VW bug Tranny on the reverse trike. The gas mileage would be awesome!
ManxBug
ManxBug is offline
PostPosted: Fri Aug 15, 2008 5:27 pm    Post subject: Reply with quote
No they used a custom made adapter plate
Air Riders, VW Club
V-driver
V-driver is offline
PostPosted: Sun Aug 17, 2008 5:41 am    Post subject: Reply with quote
Deacon,
Have you checked out Kennedy Engineered Products? They can adapt almost any automotive powerplant to the bug tranny.
www.kennedyeng.com/
Paul in Memphis.
visibleink
visibleink is offline
PostPosted: Mon Aug 18, 2008 9:54 am    Post subject: Reply with quote
And probably changed the ratios on the tranny. Diesels require totally different gearing.
<---- Helga. Hot car. Hot girl.
ManxBug
ManxBug is offline
PostPosted: Mon Aug 18, 2008 4:49 pm    Post subject: Reply with quote
Actually he didn't change the ratios. Old ACVW engines and Diesel engines both operate in lower rpm ranges. But you would probably want a freeway flyer if you intend to do allot of highway driving.
Air Riders, VW Club
Reply to topic    Forum Index -> Other VW Vehicles All times are Mountain Standard Time/Pacific Daylight Savings Time
