littlebuggie Samba Member
Joined: March 23, 2004 Posts: 698 Location: California
Posted: Thu Aug 14, 2008 9:34 pm Post subject: Disc Brakes |
I put disc brakes on the rear of my squareback 2 years ago.. Now I'm getting ready to start driving my squareback again and I can't get the rear brakes to bleed. Its a 66 so it stock with front disc, rear drum. I put an aftermarket rear disc kit on before I stopped driving it and they worked great. Now I can't get them to bleed. So I bought a new master cyc. New rear disc kit, new break lines and I can get the passengers side to bleed a steady fluid line out, but the drivers sides I only can get it to drool out, with alot of air bubbles, if I take the hard line out of the new caliper it will have a steady fluid line, but as soon as I hook it up to the caliper it goes to drool. both my new and old calipers do the same thing... Whats up with that? _________________ Subi swaps welcome! |
spook Samba Member
Joined: December 30, 2003 Posts: 2038 Location: in the shop 35750
Posted: Fri Aug 15, 2008 2:12 am Post subject: Re: Disc Brakes |
Old Light wrote: |
I can get the passengers side to bleed a steady fluid line out, but the drivers sides I only can get it to drool out, with alot of air bubbles, if I take the hard line out of the new caliper it will have a steady fluid line, but as soon as I hook it up to the caliper it goes to drool. both my new and old calipers do the same thing... Whats up with that? |
2 things come to mind, metric vrs standard break fittings
or 2 bad calipers . The last time I saw the symptoms like
you are describing, one of the break pistons wasn't retracting
when line pressure was removed. _________________ www.airkooledkustoms.com
SBS US #10
feedback on the shop : http://tinyurl.com/yc7jgkl
Welcome to he darkside, its lower here. |
Hotrodvw Samba Member
Posted: Fri Aug 15, 2008 7:08 am Post subject: |
Check the hoses to make sure the inner tube hasn't collapsed. _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
