Hardware sizes
Goto page Previous  1, 2, 3  Next
BUGTHUG
Samba's Rented Mule
BUGTHUG is offline
PostPosted: Mon Sep 28, 2009 3:36 pm    Post subject: Reply with quote
What is the size of bolt for a 66 type 1 steering stop . This bolts to the welded area on the beam that is adjustable for the steering arm to stop against when you turn the steering to the max. Best I can explain.
I know you would understand what I'm saying if you could just see my HANDS
Even the middle of the week says W T F
1963 15 window bus
1964 split window bus
1966 VW bug
1969 Dune Buggy
1971 Westfallia camper bus
1972 Kelmark, VW drive line
1948 Chevrolet Hearse
glandnut
40 horses of Fury
glandnut is offline
PostPosted: Thu Jan 14, 2010 9:20 pm    Post subject: Reply with quote
Maybe not technically appropriate, but I get constantly asked. Hurst shifter knob/shaft thread size= 3/8 X 24.
Looking for aluminum single port Kadron manifolds.
tirekicker
tirekicker is offline
PostPosted: Wed Feb 03, 2010 6:34 pm    Post subject: Reply with quote
DhK
Phuckancer
(16:45:42) Russ_Wolfe: TK, you are like a Maytag washer
(16:46:44) tirekicker: and what's a maytag washer?
(16:47:35) Russ_Wolfe: If you are not agitating, you are not working right
volksheime
volksheime is offline
PostPosted: Tue Feb 23, 2010 2:54 pm    Post subject: Reply with quote
Wide Five early Lugnuts/ Lug bolts are M12 x 1.50
I needed this because the torque meister wont allow for lug nuts to attach it to drums (too short)
tstracy39
tstracy39 is offline
PostPosted: Thu Mar 04, 2010 3:34 am    Post subject: Reply with quote
1967-71 VW Beetle/Ghia gear shifter knob: 7mmX1.0
68-79 Beetle/Bus/Ghia/Thing shift knob: 12mmX1.5
Outside diameter of 8mm case savers: 12mmX1.5
Check my classifieds for kewl gauges:
http://www.thesamba.com/vw/classifieds/search.php?username=tstracy39
I like your fork.
dsmetanick
dsmetanick is offline
PostPosted: Fri Oct 08, 2010 9:15 am    Post subject: Reply with quote
Please advise: What is the drill bit size needed to change my 12mm break drum lug bolt threads to 14 mm threads? Note I do not want to install press in studs (which is a bigger drill bit, I want to install either lug bolts or screw in studs). What is the pitch of the tap? Is the tap a 14 mm? I appreciate your advice.
Russ Wolfe
Russ Wolfe is offline
PostPosted: Fri Oct 08, 2010 10:19 am    Post subject: Reply with quote
The late model lug bolt thread pitch is 14x1.5mm. (considered fine thread) The tap drill is 12.5mm
Gary: OK. Ima poop.
Ea$y Money
Ea$y Money is offline
PostPosted: Sat Apr 30, 2011 3:21 pm    Post subject: Reply with quote
can anyone help find what size bolts/screws i might need. it's the hardware for the steering column support that attaches underneath the dash for a '66 bus. it requires 4 bolts/screws. i think there are 2 different sizes. just to clarify, its the piece you always hit you knee on when getting into your bus. thanks!
1966 Microbus Deluxe
nlorntson
Crazy VW Lady
nlorntson is offline
PostPosted: Fri Nov 04, 2011 5:05 pm    Post subject: Reply with quote
Here's another source:
September 1950 Complete VW fasteners listing
banditwolf
banditwolf is offline
PostPosted: Tue Nov 08, 2011 4:17 pm    Post subject: Reply with quote
From my 73 Super Beetle
Door hinges: 8 x 1.25 mm (threads approx 10mm), tapered head screw
Door latch: 6 x 1.00 mm (threads approx 8mm), tapered head screw
1973 Super Beetle l 1981 Trans Am
vacajar
vacajar is offline
PostPosted: Wed Mar 07, 2012 6:31 pm    Post subject: Engine mount bolt size Reply with quote
Im looking for the engine mount stud size for the back of the case and also the the top bolt on the drivers side. If it changes anything it is a Mexico Block From 73. Thanks
Empicollector Premium Member
Empicollector is offline
PostPosted: Sat Apr 28, 2012 2:26 pm    Post subject: Reply with quote
How about the size of the bolts in the end of the steering box? The ones that will scrape if you are lowered----lol. On a 67 type 2
Tucky
Tucky is offline
PostPosted: Wed May 02, 2012 7:39 pm    Post subject: Reply with quote
Hello.
I'm looking for the size of the bolts that attach the bumper brackets to the body
Thanks.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed May 02, 2012 7:41 pm    Post subject: Reply with quote
Tucky wrote:
Hello.
Thanks.
What vehicle?
M8x1.25 would be the most common.
Glenn
HBB/RW
www.DasVolks.com
Long Island's Aircooled Club
19super73
19super73 is offline
PostPosted: Thu May 03, 2012 7:05 am    Post subject: Reply with quote
He's got a '72 SB.
'73 Super Beetle w/ all the Sport Bug extras
'75 La Grande Beetle, 1st in Class, Das Volks 2011
'75 110 Standard Beetle
'71 Doublecab
'73 412 wagon "Nasenbär"
Glenn wrote:
Only a hack would have to take the rear apron off to remove a stock engine.
JerryMCarter1 wrote:
If it is something just stuck eventually it will wear down and go away.
Run it for awhile and see if it gets quieter
Tucky
Tucky is offline
PostPosted: Fri May 04, 2012 4:03 pm    Post subject: Reply with quote
Thanks a lot. Im going to the hardware store tomorrow to buy them
Pepo
Pepo is offline
PostPosted: Fri May 18, 2012 5:17 am    Post subject: Only metric sizes on the origianl VW? Reply with quote
Well, I just came back from Europe, had a great time and some interesting discussions. Among them was a statement from a friend wo is a long-time mechanic, mostly Mercedes. He maintains that all items on the original VW, i. e. Beetle were always metric. I challenged that by quoting the wheel sizes as 14 inch or 15 inch. He denied it and claimed that they are in metric conversions. I also quoted my experience with the oil pressure sensor connection to the block that I always found to be 1/8" NPT (National Pipe Thread). Can anyone verify my opinions and give me a source to copy?
Thanks,
Take care and have fun.....
jehugarcia
jehugarcia is offline
PostPosted: Fri Nov 16, 2012 2:36 am    Post subject: Cargo door hinge screws Reply with quote
Type 2 bus Cargo door hinge screws size is 8 X 1.25mm
you can find the tap at McMastercar part # 8305A19 Metric High-speed Steel Hand Tap, Taper, 8 X 1.25mm, D5 Pitch Dia, 4 Flute
and the Drill bit for the tap is item # 2958A113 Metric Black Oxide Hss Jobbers' Drill Bit, 6.7mm, 101mm Oal, 49.6mm Drill Depth,118 Deg Point
Now does anyone know what size the Engine lid hinge screw thread size is? I need to clean the threads on mine.
campingbox Premium Member
campingbox is offline
PostPosted: Fri Nov 23, 2012 11:30 am    Post subject: Re: Cargo door hinge screws Reply with quote
6mm X 1.0
germansupplyscott
germansupplyscott is offline
PostPosted: Wed Dec 12, 2012 9:34 pm    Post subject: Re: Only metric sizes on the origianl VW? Reply with quote
Thanks,
oil pressure switch threads are m10 x 1.0 straight, not NPT.
the only inch fasteners on a VW are the seat belt hardware which are all 7/16" -20.
scott lyons
http://www.germansupply.com
VW Bus-Centric Online Parts Source
Page 2 of 3
