Mr. Mofo Samba Member
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 55841 Location: Long Island, New York, USA
Posted: Tue Jul 17, 2012 5:30 pm Post subject: |
Replaced the gas tank filler and vent hoses.
I got my parts from Wolfsburg West today.
The original vent hose was fabric covered like breather hose. The new stuff is exposed rubber with no covering. The original filler hose had a fabric cover and the new is exposed rubber. It's also longer so I had to cut 2" off it. I carefully cut of the old "crimped" clamps and removed the old hose being careful not to break the plastic Tee's... they can be brittle after 40 years.
The new hoses were the correct metric size and slit on the fittings with ease, after spraying some Simple Green as a lubricant. I also replace the small vent hose that runs from the expansion tank to the other side of the gas tank.
All in all the job was easy and the parts fit as they should, even though they are the original appearance.
Tomorrow i'll take it to the gas station and fill the tank to just below full and see if it leaks. Then i'll fill it the reset as a final test. If it does leak, i'll replace the tank... I have another ready to be installed.
This might be why it leaked.
 _________________ Glenn
HBB/RW
www.DasVolks.com
Long Island's Aircooled Club |
FSFTS18Z Samba Member
Posted: Tue Jul 17, 2012 6:39 pm Post subject: |
| welded up the luggage area. had excessive noise from that area. when i removed the carpet i found out that the piece of sheet metal that was welded in place of the original body panel was only welded along the back. i was very glad that the sheet metal was 18 gauge though. all i had to do was trim it up a little and weld 3 sides. after that i covered it with dynamat xtreme.... i had a hard time at first getting the release liner off of the dynamat, (anyone else run into that problem) which in turn almost caused me to ball it up and punch it in a fit of rage, but that stuff is expensive. noticed a big difference in sub performance and reduction of engine noise. |
evilphoton Samba Member
Joined: March 16, 2012 Posts: 292 Location: San Diego, CA
Posted: Wed Jul 18, 2012 9:03 am Post subject: |
This didn't happen today because when I tried to post from my "mobile device", I couldn't :\
Yesterday, I was rewarded with The FWEEM!!! I heard it under light acceleration as I turned onto one of the neighborhood streets. I used to think the Harley potato-potato-potato was cool, it's got nothin' on the Fweem.
I've spent quite a bit of time sorting out my new (March, 2012) car...
sugar out of fuel system
brakes working - rebuilt master cylinder (i sneakely replaced the worn out OG seals with the seals out of the rebuild), front wheel cylinders cleaned
clutch replaced
rear main replaced
some blood spatter
heads cleaned, valves ground
interior cleanup
electrical cleanup (all lights now work, currently the horn is not but should soon be soon)
couple new tires
some cussing
some new rubber bits
trunk latch handle cut off twice, maybe three times (I'm accurate enough now so that I don't cut into the button)
cv boots on one side replaced, other this weekend give or take
learning to deal with worn synchronizers in second
H30/31 set up as of yesterday (had previously rebuilt a 34/3 but the throttle shaft is worn so bad (bushings replaced...) that it still sucks so much air it won't run low speed or tune)
much of the information I have learned has come from this site... thank you all I do have the Bentley Manual, the wall-of-words-Muir book, and the Bill Fisher How to hotrod book. _________________ '71 SB - 08/1970
34/3 (60/75/75z/135)
VW 028 DVDA, stock 1600 DP
Fweem!
'00 VFR
'01 Blazer |
baxsie Samba Member
Joined: August 09, 2005 Posts: 309 Location: Eastern Washington State
Glenn73 Samba Member
Joined: May 30, 2011 Posts: 841 Location: West Jordan UT
Posted: Thu Jul 19, 2012 1:10 am Post subject: |
Replaced the bent up drain plate on my deep sump.
Then installed Heavy duty coilovers on the rear so i don't bottom out and snag my deep sump. Again  _________________ 1973 SB 1776cc
Sat from 93-2008
Work in progress. |
71Survivor Samba Member
Joined: February 16, 2012 Posts: 404 Location: Newmarket, ON
Posted: Thu Jul 19, 2012 10:23 am Post subject: |
Figured out my 71 SB was built on Thursday Sep 9th 1970 according to production plate. A bit of a surprise as I thought it was built in August based on the door jamb sticker, but when it was made they did not have the numbers aligned properly!
 _________________ 1971 Super Beetle (Stock Green Survivor) - Current
1979 Westfalia (Orange) - 1984-1990
1971 Super Beetle (Red) - 1977-1980
Read the story about my 71 SB Survivor: http://globespotter.com |
fred69vert Samba Member
Joined: August 17, 2007 Posts: 2013 Location: Home of the US Navy Atlantic Fleet, Norfolk, VA
Posted: Thu Jul 19, 2012 11:44 am Post subject: |
Finally got my battery completely recharged. Last week I parked the 'vert on Tuesday after driving in the rain and.........didn't turn the headlights off until Friday morning. Was driving the Titan Wednesday and Thursday. Battery was dead as a doornail. Got a charge on it Sunday and took it to my local FLAPS to have the battery tested. They said it was good, just needed charging. So home and onto the trickle charger. Took a couple of days but the "charged" LED on the charger finally came on. Car started fine yesterday with the voltmeter reading 12.5 before I started it. Still driving the Titan as it's 95 degrees with 95% humidity here. Plan on enjoying the 'vert this weekend, weather permitting. _________________ I'm not losing my hair, it's just retired and relocating further south.
1969 VW convertible, "Heidi" |
baxsie Samba Member
Posted: Thu Jul 19, 2012 10:10 pm Post subject: |
Received and inspected the absolutely incredibly complete front door seal kit from West Coast Metric:
https://shop.westcoastmetric.com/viewProduct.php?productID=113-0669
Way expensive, but seems to have EVERYTHING and it all seems to be very good quality and packed very well.
It will be awesome to have the doors seal perfectly! |
andk5591  Samba Member
Joined: August 29, 2005 Posts: 8995 Location: State College, PA
Posted: Fri Jul 20, 2012 3:35 am Post subject: |
In the middle of complete teardown of 73 standard in preparation for media blasting body and body off build. Dreading the dash and trunk area since all of my other stuff is much older (61, 65 and I even backdated my 69 to 65 specs) so first time with fresh air box and new style fuse box. _________________ D-Dubya Manx clone - 63 Short pan,1776.
Max - 73 standard project at wife's request and your gonna die when you see this one. |
Maddog209 Samba Member
Joined: November 03, 2011 Posts: 292 Location: Central Valley, Ca.
Posted: Fri Jul 20, 2012 10:45 am Post subject: |
Valve adjustment and oil/filter change. _________________ Current VW's= 2013 Tiguan, 1968 Bug |
baxsie Samba Member
Posted: Fri Jul 20, 2012 8:47 pm Post subject: |
Rufus and Jethro came over and helped us rig up a hoist for the body, then we got the body separated from the pan, for the most part:
Post in build thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6165545#6165545
Posted: Sat Jul 21, 2012 4:36 am Post subject: |
You do realize that it looks like you are getting ready to slam dunk the bug, right? _________________ D-Dubya Manx clone - 63 Short pan,1776.
baxsie Samba Member
Posted: Sat Jul 21, 2012 5:28 am Post subject: |
| andk5591 wrote: |
| You do realize that it looks like you are getting ready to slam dunk the bug, right? |
I didn't. But now that I do I am laughing . . . |
kickfli12 Samba Member
Posted: Sat Jul 21, 2012 11:18 am Post subject: |
i cut my right side floor pan out
74superTN Samba Member
Joined: April 01, 2007 Posts: 366 Location: Guyton, GA
FP Samba Member
Joined: May 12, 2010 Posts: 314 Location: Crystal Lake, Illinois
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 1034 Location: Gladstone, Ore
Posted: Sun Jul 22, 2012 8:15 pm Post subject: |
Stood and looked at her beauty! My "keep forever" car! Fog lights, intermittent wipers, rear defogger that works, nice stereo, nice paint. nice 90's resto done by PO, or so I thought......
just noticed after of a year and a half of ownership, the D*** fenders are mismatched!!! one tailight is lower than the other!
Eyesore. going to have to junk the car _________________ 72 Super |
Joel Samba Member
Joined: September 04, 2006 Posts: 8102 Location: NSW Australia
Posted: Mon Jul 23, 2012 1:10 am Post subject: |
It's gotta be a red Beetle syndrome, that would be I think the third red Beetle like that I've seen on here in the last couple of months
I've just finished botching my Kamei spoiler back together.
It split a few weeks back after I KO'd a bandicoot one night.
Poor bug looked naked without it. |
animes2k Samba Member
Posted: Mon Jul 23, 2012 7:17 pm Post subject: |
| FP wrote: |
Added my new Vocho emblem.
Are you actually in Mexico? I've been wondering if it's possible to get a Mexican plate with my US license plate numbers on it (specifically from Puebla, what with the factory and all).
I've been thinking about getting that emblem, too. It almost seems too modern for the car, but I do like it. If it weren't $50-60 I'd have pulled the trigger.
Anyway, I finished up my sound deadening/carpeting installation and took the car for a drive to measure sound levels. Reduction achieved. Could be better, but I'll deal
 _________________ 2000 Mexican BtlMex Swing Axle 4MT - SOLD |
