McAddict Samba Member
Joined: February 27, 2012 Posts: 26 Location: Columbia, Missouri
Posted: Wed Apr 18, 2012 9:28 am Post subject: |
| Pulled interior on the 72 standard, cleaned everything inside, began surface rust removal. Replaced heater cable on 73 super. |
Matt Brutosky Samba Member
Joined: January 03, 2010 Posts: 17 Location: Lompoc, CA
Posted: Fri Apr 20, 2012 7:55 am Post subject: |
| After losing one pea shooter while driving down the highway (yeah, it fell off. so what?), and oredering new tail pipes from a business on The Samba, I installed the new pipes--mini-megaphones. Just an expanded PS, really, but they sound good! |
loper Samba Member
Posted: Fri Apr 20, 2012 4:39 pm Post subject: |
New fuel pump, kitted my original carb so I can replace the chinese J.C. Whitney knock-off, and ordered a bunch of stuff so I can put in a stereo.
And went for a drive... |
Wugsbug Samba Member
Joined: April 02, 2012 Posts: 3 Location: carpinteria, CA
Posted: Sat Apr 21, 2012 12:14 am Post subject: Enjoyed Driving |
I drove to work and home. no clicks, pops, taps or thumps.
Thank You |
legotech7 Samba Member
Joined: May 09, 2009 Posts: 260 Location: North Carolina
Posted: Sat Apr 21, 2012 1:17 pm Post subject: 69 rear lowering today. |
Well I lowered my 69 vert today. Actually I started a few days ago, but finished today. With all the information I got here on Samba it went fairly smooth. Took my time, did 2 outer clicks on both sides. That put the car down pretty low. It looks good but I'm worried about the ride. I'll take it out tomorrow and see how she handles. If at all, I just might bring it up a notch. Will see. The front I took care of a few months ago. She's got 2 inch narrowed adjustable beam and 2.5 inch dropped spindles. She almost lays beam. I installed air shocks with a compressor, to raise the front to level for highway driven. And when she's parked, slam she goes. It's in the garage for now, long way to go before I get it to where I want it but having fun along the way. Will post updates with pics on different threads here on Samba.
Thanks for letting me spiel. Keep posting everyone.................. |
Todd19 Samba Member
Joined: June 24, 2011 Posts: 196 Location: United States
Todd19 Samba Member
69 Jim Samba Member
Joined: September 27, 2004 Posts: 6621 Location: Chickengeorge's Neighbor
Posted: Sat Apr 21, 2012 8:42 pm Post subject: |
| Glenn wrote: | Getting busy this morning.
The tranny and axles are in.
Glenn, would you happen to have a shot of the side of your engine compartment where the access hole was made for the carbs? Also did you notice much of a difference noise-wise when you removed the side pieces of insulation? Thanks... |
68IHscout  Samba Member
Joined: March 10, 2010 Posts: 1874 Location: santa ana ca
Posted: Sun Apr 22, 2012 12:24 pm Post subject: |
| I reinstaled my speedo today , and since I have never had a car with 00000000 miles on it decided to fallow directions from one of the threads here on the samba and reset it to zeros . |
Valnar300 Samba Member
Joined: March 18, 2010 Posts: 273 Location: Garden Grove, CA
Posted: Sun Apr 22, 2012 4:20 pm Post subject: |
bought a rebuilt starter, but still have to mount it, and put an e clip over the lever to adjust the seat back. Now it won't fall off and cause by seat to become "flexible" all of the sudden _________________ Cars So Far:
-73 Super Beetle
...well I didn't say it was a long list.
Graduated Wyotech Automotive Core Program Nov 2011
ASE Certifications A2-A8 |
bigstrov34 Samba Member
Joined: April 03, 2010 Posts: 106 Location: Charleston, SC
Posted: Sun Apr 22, 2012 4:27 pm Post subject: |
checked out the front suspension (working to fix shimmey) looks like my center tierod is bad, needs bushings, and probably 1 ball joint.
Went to bleed the brakes and had a screw snap off luckily i hadn't gotten it open or that would of been a mess. Time for a new wheel cylinder! |
Posted: Mon Apr 23, 2012 10:40 am Post subject: |
Put in my starter before leaving for school _________________ Cars So Far:
-73 Super Beetle
Posted: Mon Apr 23, 2012 5:21 pm Post subject: |
| bigstrov34 wrote: | checked out the front suspension (working to fix shimmey) looks like my center tierod is bad, needs bushings, and probably 1 ball joint.
Went to bleed the brakes and had a screw snap off luckily i hadn't gotten it open or that would of been a mess. Time for a new wheel cylinder! | I would change both ball joints. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 55656 Location: Long Island, New York, USA
Posted: Mon Apr 23, 2012 5:25 pm Post subject: |
| 69 Jim wrote: | | Glenn, would you happen to have a shot of the side of your engine compartment where the access hole was made for the carbs? Also did you notice much of a difference noise-wise when you removed the side pieces of insulation? Thanks... |
I don't think it got any louder, but that was years ago when i had better hearing. _________________ Glenn
HBB/RW
www.DasVolks.com
Long Island's Aircooled Club |
69 Jim Samba Member
Posted: Mon Apr 23, 2012 6:35 pm Post subject: |
| Glenn wrote: | | 69 Jim wrote: | | Glenn, would you happen to have a shot of the side of your engine compartment where the access hole was made for the carbs? Also did you notice much of a difference noise-wise when you removed the side pieces of insulation? Thanks... |
I don't think it got any louder, but that was years ago when i had better hearing. |
Thanks! |
Posted: Tue Apr 24, 2012 3:12 pm Post subject: |
Got about a mile down the road this morning before a cloud of oil-based smoke passed me... Turned around quickly, pulled into the driveway, and checked underneath hoping for a valve cover leak at worst. NOPE! Looks to be the oil cooler seals... I could have fixed it, if my tools werent all at work... _________________ Cars So Far:
-73 Super Beetle
cferry7 Samba Member
Joined: February 17, 2011 Posts: 359 Location: S.E. U.S.A
Posted: Tue Apr 24, 2012 3:23 pm Post subject: |
Painted recently installed replacement Master Cylinder with Diamond Clear de Eastwood.
Continue with Floor Pan Restoration.
Exterior Pan's taken to Bare Metal - first paint layer applied.
Exterior Pan's To Do : complete the outer edges, complete clean-up
of attachment hardware.
Interior Floor Pan's have been de-tar papered, 3M paint stripper wheel sanding to bare metal - - in process. _________________ 1st : ' 71 Super , 1641 cc , ~ Stock - a keeper !
2nd: ' 70 Standard , Totaled 7-14-01 , R.I.P. |
volkz Samba Member
Joined: September 08, 2008 Posts: 40 Location: ontario, canada
Posted: Wed Apr 25, 2012 6:56 pm Post subject: |
today was first time out driving the bug this year. was a magical drive _________________ 1968 beetle |
Posted: Wed Apr 25, 2012 8:16 pm Post subject: |
dropped the tierods, swaybar, control arms, changed a wheel cylinder out. (snapped a bleeder screw )
awaiting my new center tie rod and bushing from topline!
Tips for first timers.. Jacking up the strut, wedging a bolt inbetween the strut and ball joint and letting the jack down works great! Probably the toughest part was removing rusty old cotter pins and trying to not damage the other tierods since they are in good shape. |
Posted: Thu Apr 26, 2012 11:49 am Post subject: |
This was yesterday, Dropped out the motor, checked the oil cooler, and it turns out one of the nuts holding the oil cooler on went AWOL, causing the massive leak. Replaced it with another one I had laying about, and made sure to put a lock washer under it (rather above it because its the one hanging over the 3/4 cylinders.) Leak fixed. _________________ Cars So Far:
-73 Super Beetle
