joeyk803c Samba Member
Joined: January 19, 2014 Posts: 102 Location: United States
Posted: Fri Apr 18, 2014 9:19 pm Post subject: |
Motor drop didn't go as planned today, but I did replace the trunk latches. Now I can open the "trunk" from outside the car, and not have to use vice-grips locked onto the latch cable.
Also tightened up the E-brakes, still having a hard time with those damn drum brakes.
Last, but not least... Did this. I really, really disliked the stock battery location. To far away from the fuse block, and under a seat with metal rods and springs, a potential short and fire waiting to happen. I don't ever plan on using the rear space behind the rear seat for cargo space, so the battery and fuse block will go on the left side, a 10" sub and amp, on the right (eventually). Battery will sit in a tray of angle iron, which will be bolted to some 1/4" plate tabs welded to the floor. ATO fuses are easy to find, and can be used across multiple-vehicles, (a plus for me). This is just mock up for now, battery position may move.
marklock Samba Member
Joined: September 20, 2011 Posts: 118 Location: SE Michigan
Posted: Sat Apr 19, 2014 1:45 pm Post subject: |
It's been a long winter. Finally got the battery charged and added fresh fuel. Going to fire her up shortly, first time since Fall. _________________ 1968 Beetle project |
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1770 Location: Newmarket, ON
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2240 Location: Medford, OR
Posted: Tue Apr 22, 2014 2:19 pm Post subject: |
Picked up super street tranny from Strictly Foreign. Pulled current tyranny .
PSA: remember, alway disconnect the tranny from shift coupler under the seat. The more you know.
Swapping all the mounts, straps, and ground strap, etc, cleaned all the oil off the rear tyranny mount - replaced the leaky main seal earler.
Was grateful the bolts for the cv joints behaved themselves.
Cut access ports in the rear wheel wells to have better access to the carbs.
Two weeks up and running? Let's hope. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
AlienJohn Samba Member
Posted: Fri Apr 25, 2014 6:46 am Post subject: |
Installed new door seals, trunk seal, rear deck seal,
replaced and adjusted a brake cylinder, installed new
rubber beading on all fenders, went for a ride, waved at people,
its been a good day.
JB in Ohio _________________ All Hail Snorkelstang !
72 Standard Beetle
74 Karmann Ghia Coupe
76 Fender Telecaster |
85burb Samba Member
Joined: February 26, 2014 Posts: 220 Location: Lindale Tx
Posted: Sat Apr 26, 2014 6:37 pm Post subject: |
Installed a few crappy parts from cip1. A "top quality" antenna that was a pos. a nice looking oil pressure sender. a good trunk latch. and nice set of lap belts. I had ordered some lock pulls and only got the collar that goes in the door. they did not send the actual pull part. Will not order from them again. and fixed my lights...again. spent most of the day looking for 11 inch wipers and a horn. hope to pass safety inspection later this week and make it my daily driver. cant wait. it has been over 6 years that I have not drove a bug daily. |
volkz Samba Member
Joined: September 08, 2008 Posts: 77 Location: ontario, canada
Posted: Sat Apr 26, 2014 6:58 pm Post subject: |
did its spring tune up. good to go for a summers worth of cruising _________________ 1968 beetle
1970 beetle |
bloomerific Samba Member
Joined: April 26, 2014 Posts: 10 Location: Lockport, NY
Posted: Sun Apr 27, 2014 5:44 pm Post subject: |
(I'm brand new, by the way, hello)
I ripped off the top & headliner down to the frame, and put the window in my living room.
Now to actually get it running and on the road... |
Hnoroian Samba Member
Joined: October 27, 2013 Posts: 535 Location: Bakersfield
Posted: Tue Apr 29, 2014 12:31 am Post subject: |
Packed the front wheel bearings, adjusted the brakes, washed, waxed and polished the bloody knuckles also bought a spare throttle cable, clutch cable, wing nut, and spare belt;all of which I hope I don't have to use on the trip to the beach this next week... _________________ Stupid people do stupid things. |
Posted: Tue Apr 29, 2014 12:39 am Post subject: |
85burb wrote: |
For your wipers, go buy a good 24" wiper blade refill and cut it in half with a pair of side cutters (measure first, 24" are actually like 23"). Keep your old housing and install the newly cut refills in the old arms. I did this years ago and saved me a lot of time and money finding 11" blades. Good luck getting your car inspected... _________________ Stupid people do stupid things. |
85burb Samba Member
Posted: Wed Apr 30, 2014 4:23 am Post subject: |
Well it passed inspection yesterday! Now it's my daily driver. If I would have had old wipers to rebuild I would have done that's that's a good idea. Thanks! |
plimthing Samba Member
Joined: March 29, 2014 Posts: 278 Location: West Midlands UK
Posted: Thu May 01, 2014 5:52 am Post subject: |
I installed new speakers in the rear and two new smaller ones in the front doors. Tomorrow i will tidy up wiring and vacuum the carpets and install all seats. Then, if the sun is shining i will go for a whiz around with the roof down, radio on! |
Posted: Thu May 01, 2014 6:02 am Post subject: |
It's almost summer, so naturally I am working on the heater and defrost tubing so I can make the car hotter
JB _________________ All Hail Snorkelstang !
72 Standard Beetle
Posted: Thu May 01, 2014 11:14 pm Post subject: |
went for spin, goes nice, stereo sounds great from 4 speakers now!
Finding it hard to tune carb as per instructions on resource. I think it may have an air leak somewhere, not sure how old carb is but maybe time for a new one? Might try the rev and hand over throat trick to see if it clears itself. So frustrating when the end is in sight..... |
drgerry Samba Member
Joined: September 12, 2010 Posts: 110 Location: Jonesboro, GA
Posted: Fri May 02, 2014 9:58 am Post subject: clean engine |
organized and cleaned the engine. Looks better.
t7d5 Samba Member
Joined: May 17, 2010 Posts: 76 Location: Pensacola, Fl. 32514
Posted: Fri May 02, 2014 10:47 am Post subject: 11 inch wipers |
85burb wrote: |
Advance auto carries the wipers and a few other beetle stuff. |
tommyangleterre Samba Member
Posted: Sat May 03, 2014 8:26 am Post subject: |
just removed my 1915cc to take off my trany...I am going with 3.88....free fyer+ super diff!!!
[/img] |
Posted: Sat May 03, 2014 12:10 pm Post subject: |
Started cleaning it out. Going to start working on running the wiring today from the motor to the fuse block for now. then from the front end to the fuse block. |
mountainkowboy Samba Member
Posted: Sat May 03, 2014 12:48 pm Post subject: |
Got the engine back in and am having a throttle cable issue. Will get to the bottom of it early in the week. _________________ Chuck in Socal
71 Super Convertible...DD
78 Honda CB750K
06 Honda CR-V (wifes)
63 IH Scout 80 "Beater" |
Posted: Sat May 03, 2014 4:41 pm Post subject: |
I put my finger through the back seat left floor pan. Just wanted to see that happen before I replace them. I was mildly amused. Also tried to start it again, no dice. Thank goodness she's going to the hospital on Monday. |
