miller0358 Samba Member
Joined: November 07, 2007 Posts: 1200 Location: northford,ct
Posted: Fri Dec 26, 2014 8:12 pm Post subject: super |
Just got my car back from Tim (401 Restos ) and started the reassembly. New rubber in rear engine compartment. Rubber in front hood. Steering box, rebuilding speedometer before it goes in. Dash, and started plumbing under hood. I'm going to do as much as I can before I put it back on the chassis. Can't get around inside very well with 2 knee replacements. I am making progress but I have a long way to go. Jeff |
Posted: Sat Dec 27, 2014 5:19 pm Post subject: today |
Worked on the speedometer today. Turned it back to zero mles. Working on putting color back for the lights. Good cleaning and some grease and finish tomorrow. Jeff |
windfish Samba Member
Posted: Sun Dec 28, 2014 8:52 pm Post subject: |
New Hella E-Code H4 headlights in
Supercruiser12 Samba Member
Posted: Tue Dec 30, 2014 5:10 pm Post subject: Okay it wasn't today. |
It's cold and dark in Alaska this time of year. Recently, I dropped a SVDA dizzy in my 1641 DP with 34 pict 3 and it ran a lot better than with the 009. Took it out around the block and discovered I had no lights at all in the back. 4:00 pitch dark so I had to scoot back home quickly. My next task is to find where the power has gone off to back there. |
AlienJohn Samba Member
Posted: Thu Jan 01, 2015 6:51 pm Post subject: |
Both my other cars had dead batteries from the cold. Pulled the tarp off the old Beetle and Vrrrrroooooom
Started like a champ ! _________________ All Hail Snorkelstang !
72 Standard Beetle
74 Karmann Ghia Coupe
76 Fender Telecaster |
Posted: Fri Jan 02, 2015 7:53 pm Post subject: today |
Just finished one door today. All new rubber, weatherstripping, and glass. I forgot how much a pia it is. Jeff |
blienemann Samba Member
Joined: February 21, 2009 Posts: 125 Location: Richmond, Va
Posted: Fri Jan 02, 2015 8:51 pm Post subject: |
Removed the dashboard and interior A/C unit. Apparently it was an original unit (dealer installed) as it has a made by VW of America sticker and made in USA.
Also removed the headliner and found that the rear seal on my sunroof had come dislodged from the mount. Shoved it back in and bent the bracket up slightly to keep pressure on it.
Lastly I checked all tie rods (all need replacement) but reconnected the steering box and shaft so I cam move it around again.
Next up are control arm bushings and door seals when they get delivered. _________________ Previous - 73 1303
Current:
71 1302 w 2110
70 Deluxe Bus - Project
"Aim for the sky and you'll reach the ceiling. Aim for the ceiling and you'll stay on the floor." Bill Shankly |
dahlstrom Samba Member
Joined: February 02, 2014 Posts: 4 Location: Illinois
Posted: Sat Jan 03, 2015 8:34 am Post subject: Removed running boards today |
Removed running boards yesterday on my '71 Super convertible and only broke off 1 bolt! I'm going to get it stripped down this winter and begin sanding. Hopefully along the way I'll get inspired on what I want the "after" to look like. I planned to just drive it for a few years before tearing into the body, but I can't handle having it just sit in the garage for the winter.
Its currently a dark blue (similar to an original Sapphire Blue), on top of red, on top of white (I guess Kansas Beige).
Walter4 Samba Member
Posted: Sat Jan 03, 2015 2:55 pm Post subject: |
Replaced the hinge pins using the tool I rented from the Classifieds. |
Posted: Sat Jan 03, 2015 9:57 pm Post subject: |
Replaced the rear rubber sunroof seal and posted the pics for the next person to hopefully have for future reference.
Hopefully the rain will now stay on the outside of my interior now that the seal is on and I cleaned out all of the drain lines. _________________ Previous - 73 1303
Current:
71 1302 w 2110
mountainkowboy Samba Member
Posted: Sun Jan 04, 2015 12:34 pm Post subject: |
getting the heater in order, its cold with only 1/2 the system working and then the working side isn't right either......lol....parts have been ordered. _________________ Chuck in Socal
71 Super Convertible...DD
78 Honda CB750K
06 Honda CR-V (wifes)
63 IH Scout 80 "Beater" |
Kindredz Samba Member
Posted: Sun Jan 04, 2015 9:30 pm Post subject: breather box |
installed a breather box from empty, new 1915cc engine creating too much crank case pressure and relieving itself all over the engine.
tools:
3/4" step drill, primer paint, and self tapping metal screws.
Drilled into both valve covers and under engine metal above each with step drill. ran the hoses unto box and attached to the front of the fan housing. took all about 25 minutes.
no more oil spraying. |
richardc Samba Member
Joined: September 06, 2010 Posts: 269 Location: New Jersey & North Carolina
Posted: Mon Jan 05, 2015 10:12 am Post subject: |
Just replaced broken speedo cable. _________________ 1970 Ghia vert
1970 Beetle sedan |
Posted: Mon Jan 05, 2015 2:21 pm Post subject: do today |
Put in my windshield wiper motor today. Just a thought for everyone doing a full resto. Put your motor in first,before anything else . Almost impossible if you don't. Jeff |
Posted: Tue Jan 06, 2015 6:59 pm Post subject: today |
Put the front wire harness in today. Jeff |
Posted: Wed Jan 07, 2015 12:15 pm Post subject: |
Got my heater parts in and installed. Now that its not 28* every morning my heater is working at 100%.....lol _________________ Chuck in Socal
78 Honda CB750K
GingaNinja Samba Member
Joined: September 16, 2013 Posts: 131 Location: Vancouver
mslibertarian Samba Member
Joined: January 19, 2008 Posts: 191 Location: Mississippi
Posted: Thu Jan 08, 2015 12:26 pm Post subject: |
Replaced the speedometer gels and cleaned 44 years of grit out of the speedometer. Cleaning the inside of the glass alone made it look amazing.
Also installed a wiper delay module from Revolution Electronics and replaced my blinker switch. _________________ "Veedubers is some strange folk." Bob Hoover
Haikus are easy
But sometimes they don't make sense
Refrigerator |
RTope13 Samba Member
Joined: July 10, 2012 Posts: 106 Location: North Ogden, Utah
Posted: Fri Jan 09, 2015 9:10 pm Post subject: |
Installed my 2.5" drop spindles today. HUGE difference!!
biga1969 Samba Member
Joined: February 09, 2011 Posts: 164 Location: Tennessee
Posted: Sat Jan 10, 2015 6:00 pm Post subject: |
replaced spring plate bushings both sides. _________________ Alan
1973 Super Beetle |
