mountainkowboy Samba Member
Posted: Sun Jan 11, 2015 5:13 pm Post subject: |
Since it was raining and my wife is gone with the Honda, I figured I should track down the intermittent problem with my wipers.......
Typical......bad ground. _________________ Chuck in Socal
71 Super Convertible...DD
78 Honda CB750K
06 Honda CR-V (wifes)
63 IH Scout 80 "Beater" |
Captain Jacques Samba Member
Joined: August 27, 2013 Posts: 231 Location: Saint Augustine, Florida
Posted: Mon Jan 12, 2015 6:47 pm Post subject: |
I totaled my vert last Tuesday. Broadsided a Cadillac Escalade (of all things) at 45 mph. His fault, not mine, but it wasn't any less painful for my wife and I who, for lack of all the modern conveniences such as frontal & lateral airbags and functional seat belts, took the brunt of encounter.
Only time and the adjusters will determine if the Bug is recouperable at this point, but if she is, I'll spend whatever it takes to restore her to her previous splendor, and then trade her in for the first Brinks Armored Truck I can find with decent tires on it.
And to think we'd only taken her out for a short ride with the top down to air out the dog...[/img] _________________ Safe Sex: The Next Best Thing To Being There.
'75 Super Vert (Carbed)
1989 Lada Niva
2000 SL320 Panoramic
2001 Alfa 156 Sportwagon Selespeed |
jrmcc999 Samba Member
Posted: Wed Jan 14, 2015 9:42 am Post subject: |
After wheel balancing, the speedometer was flaky and useless. I looked under the wheel cover, and the hub cap the cable goes thru was knocked loose. That would do it. VW problems are almost NEVER this straightforward, so I celebrated. _________________ 1973 Kansas Beige Super Beetle |
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
Posted: Sat Jan 17, 2015 4:09 pm Post subject: |
Changed the oil and replaced a taillight bulb, whoo |
mark tucker Samba Member
Posted: Mon Jan 19, 2015 9:16 pm Post subject: |
walked by it and got in wifes honda and drove away......the wife is in socal this week so the bug gets a week off!!!!! |
omegared11211 Samba Member
Joined: November 22, 2014 Posts: 17 Location: Arizona
Posted: Tue Jan 20, 2015 8:27 pm Post subject: |
Oil/filter change, new plugs, new gear box oil, adjusted & bled brakes, got all the lights working, then drove around. |
VWCHI81 Samba Member
Joined: April 30, 2014 Posts: 53 Location: Kenosha, WI
Posted: Sun Jan 25, 2015 8:39 pm Post subject: |
Removed pedal cluster, accelerated and clutch cables, rear break line and cut out both pans! |
kevinrevin Samba Member
Joined: January 19, 2015 Posts: 7 Location: East Texico
Posted: Mon Jan 26, 2015 7:03 pm Post subject: |
Today we drained the over-filled crankcase. (NOTE TO SELF: 3.5 PINTS not quarts.)
Made plans to chase non-spark issues tomorrow, after refilling with proper amount of oil.. |
PressY4Pie Samba Member
Joined: December 10, 2014 Posts: 73 Location: Redding Ca
Posted: Tue Jan 27, 2015 3:28 pm Post subject: |
did a little dash customization,
_________________ Who? |
bootstraps Samba Member
Posted: Wed Jan 28, 2015 2:52 pm Post subject: |
Yanked out and "rebuilt" my wiper motor. Sweet. Of course, Now my fuel pump doesn't pump. FML. |
peteandvanessa Samba Member
Joined: July 01, 2009 Posts: 931 Location: Sacramento
Mafmajor Samba Member
Joined: July 17, 2014 Posts: 46 Location: Fairfield CA
Posted: Mon Feb 02, 2015 11:49 pm Post subject: |
Took a look at the weather app and it said it will rain this week. Great time to try out my new rain thingies. Also installed a new glovebox.
Old n' slow Samba Member
Joined: October 29, 2012 Posts: 619 Location: Western Maryland
Posted: Wed Feb 04, 2015 3:10 pm Post subject: What did you do to your bug today |
Went to pull the hood release on my 69 Bug at the gas station and not much happened . Brought it back home and played with it for 30 minutes before it finally released . White greased every part of the entire release mechanism ( cables, slides ,etc) now it works perfectly . Glad I only needed to get out my lead substitute to add to the gas and not had been in a break down situation on the side of the road in the dark .
The moral of the story = A little maintenance can make a big difference . _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
All my daily drivers gone but not forgotten;
1964(sunroof)1967 & (2)1968 Beetles , 1968 Squareback , 1963 (23 window )Deluxe Sunroof Bus , 1969 Westphalia camper, 1974 Dasher , 1985 Vanagon , (2) 1981 Rabbit Diesels & a 1991 Jetta Diesel . |
vamram Samba Member
Posted: Sat Feb 07, 2015 12:09 pm Post subject: Fixed the brakes |
Gad, i HATE working on brakes almost more than anything else. I'd rather trace down a short. That said -
I installed a new master cylinder in my '72 Super as the old one was leaking into the tunnel. And I had to replace ALL FOUR bleeder valves on the [EDIT ] WHEEL cylinders. "Speed Bleeder" valves all snapped when I tried to either loosen them to bleed or tighten them after. So multiple bleedings had to take place. A mess, but now it stops on a dime! _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!!
mouser98 Samba Member
Joined: April 12, 2012 Posts: 300 Location: Lugoff, SC
Posted: Tue Feb 10, 2015 2:44 pm Post subject: |
i have apparently finally broken in the engine i rebuilt last winter. ever since i installed it, i would get a big blue cloud of oil smoke when i started the car up. finally, the other day i cranked it up and .... no big blue cloud of oil smoke. every time i have cranked her up since then, still the same, blue cloud is gone. so that's pretty great. |
Joel73 Samba Member
Posted: Fri Feb 13, 2015 9:57 am Post subject: |
Mouser did you check to see if it was out of oil? Glad the rings finally seated. |
Posted: Fri Feb 13, 2015 4:36 pm Post subject: |
Ordered a set of 4 Humvee seatbelt assemblies for the Ghia and the Vert $63.00 shipped to my door. _________________ Chuck in Socal
78 Honda CB750K
blienemann Samba Member
Joined: February 21, 2009 Posts: 125 Location: Richmond, Va
Posted: Sun Feb 22, 2015 4:18 pm Post subject: |
I ordered what I hope is the last of the major items before getting my 71 super on the road. Front disc conversion, new struts, ball joints and rear shocks.
Hopefully it is just a short list of fix it things, replacing the torsion bar bushings when I lower the rear and reinstalling the engine.
I built the engine and have touched almost every inch of the car so there's nothing else that could go wrong at this point! (I hope the sarcasm comes through) _________________ Previous - 73 1303
Current:
71 1302 w 2110
70 Deluxe Bus - Project
"Aim for the sky and you'll reach the ceiling. Aim for the ceiling and you'll stay on the floor." Bill Shankly |
vamram Samba Member
Posted: Sun Feb 22, 2015 5:18 pm Post subject: |
Ordered new seat covers from JBugs - blue sapphire tweed 12" inserts w/cream/ivory white vinyl sides. Cleaned the brass of the rotor and inspected and did the same for the distributor cap. Leaned out the carb and advanced the timing, trying to improve MGP which has been really crappy all winter. Finally, went on a nice 50-mile cruise. [EDIT] No pinging w/the change in mix and timing. Ran super nice, no idea of the mileage yet. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
