srxfromhell Samba Member
Joined: February 13, 2015 Posts: 18 Location: Downey, CA (90242)
Posted: Sun Apr 12, 2015 5:19 pm Post subject: |
sat on my ass in the driveway with a beer in my hand wondering why the front of my bug is 11 !/2 inches off the ground with 165/85/15, without an adjustable beam I get that the rear was raised with the torsion bars 12 1/2 but how the hell did the front get this high ? |
charlax21 Samba Member
Joined: January 23, 2006 Posts: 20 Location: Savannah, GA
Posted: Mon Apr 13, 2015 6:37 am Post subject: |
More like over the weekend, but continue break down of the 1600 engine. Flywheel off. Crank and Cam out. Pulled the 10mm studs. Bagged and label everything.
Then the best part of all of this is when the fuel flange broke off inside the case. Luckily I had the case opened. But even a threaded bolt would not pull it out. Had to chip away with a flat blade to get it cleared. _________________ Buddy (72 Super) project
74 Superbeetle |
AlienJohn Samba Member
Posted: Wed Apr 15, 2015 1:05 pm Post subject: |
Turned the key, drove it. Waved at all the smiling faces _________________ All Hail Snorkelstang !
72 Standard Beetle
74 Karmann Ghia Coupe
76 Fender Telecaster |
JayO Samba Member
Joined: June 14, 2013 Posts: 310 Location: Taxachusetts
Posted: Sat Apr 18, 2015 1:41 pm Post subject: |
Took the bug out for the first real "dust off" today.
Drove about 30 miles round trip, to my son's first soccer road game of the season.
Had the top down, and the tunes cranked, oh yeah, it's been a long cold winter !
Had a little shimmy in the front at highway speed, that wasn't there in the fall.
I think the tires might have a little flat spot from sitting unmoved all winter, hopefully it gets better as I drive it more !
So glad to have all that damn snow gone at last !!
- Jay |
mouser98 Samba Member
Joined: April 12, 2012 Posts: 300 Location: Lugoff, SC
Posted: Mon Apr 20, 2015 5:45 pm Post subject: |
If someone says you can't rewind the spring in the seat belt doohickey, don't believe them. Although it is better just to leave that little side plate alone, ask me how I know |
profile6 Samba Member
Joined: February 03, 2014 Posts: 4 Location: Bakersfield, CA
Posted: Mon Apr 20, 2015 7:27 pm Post subject: A few upgrades |
Put front blinkers on. Got a cool little amp w/ speakers off amazon, meant for street bikes. Loud & clear, plugs into the ipod and radio! Also tool box, so much better than stashing a bag behind the seat.
[/img]
An the hood still fits
celblazer Samba Member
Joined: November 12, 2014 Posts: 62 Location: South Jersey
Posted: Tue Apr 21, 2015 9:11 am Post subject: |
Replaced the drivers rear wheel cylinder, it had a broken bleeder and was seized solid and got the frozen adjusters working.
Next step is master cylinder and with any luck I'll have brakes. _________________ My Stable: 65 Mustang Fastback, 88 Lebaron GTC Convertible, 01 Sebring Convertible, 09 HHR SS (325whp,400wtq), 92 Harley Heritage Softail And my 1st Bug a 73. |
swhitcomb Samba Member
Joined: November 05, 2003 Posts: 5673 Location: Inwood WV
Posted: Tue Apr 21, 2015 10:11 am Post subject: |
Not today, but last weekend. Painted the pan and removed the black paint from the Empi wheels. Going to paint them orange to match my car.
_________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
Cali_Army_Guy Samba Member
Joined: March 19, 2015 Posts: 2094 Location: Stockton, CA
Posted: Sat Apr 25, 2015 4:34 pm Post subject: |
I put on a new heater cable that controls the flaps under the rear seat. Also pulled my seats out and took out my old nasty carpet and vacuumed up all the crap underneath.
Posted: Sat Apr 25, 2015 5:48 pm Post subject: |
Also replaced my shifter bushing and shift coupler. My god what a difference that made. Feels like the shifter in a 2015 car now. |
Mafmajor Samba Member
Joined: July 17, 2014 Posts: 46 Location: Fairfield CA
Posted: Sun Apr 26, 2015 2:12 pm Post subject: |
Replaced the engine compartment seal today. Surprisingly, installing the new one was not very difficult. I did end up using the soapy water strategy. What did take forever and took skin off my hands was getting the old one out. Should be a happier engine now. Next up is lowering the rear |
mattb1968 Samba Member
Posted: Sun Apr 26, 2015 8:59 pm Post subject: |
Fixed the e-brake lever, replaced the driver side window regulator (pain in the ass by the way) and took off the stock exhaust. I was hoping to replace it but realized the replacement I bought had a connection for a single heat riser. Learning new shit every day. |
Phil911 Samba Member
Posted: Tue Apr 28, 2015 3:34 pm Post subject: |
- Installed new 14 inch wheel with 3.5inch dish so my fingers don't get caught on the signal and wiper controls
- put rotors and drums back on
- put battery on tender
- mounted two back tires on centerline rims (other two are still in shop getting the holes drilled properly)
- sprayed new steel in fender wells with rock guard
- took valve covers off, hit them with a wire wheel, then acetone, then rust prohibitor, then black paint
- while they were drying and valves were exposed, I went around and set the valves to .06 on the feeler gauge
- drained the oil
- took out the tea strainer, cleaned all the parts with brake cleaner
- reinstalled strainer, new gaskets
- by this time the valve covers were dry, reinstalled them with new gaskets also
- topped up with new oil with added zinc
- stored the old oil because I plan to build an oil burning stove for the garage for next winter - cleaned out the plastic bucket I used to capture the oil with brake cleaner. Makes the oil run free and its also combustible so it too will get burned.
....but I dunno how long 2.5 litres of oil will last. _________________ 1990 911 Porsche C2 (964) - Sold
1976 VW bug (sold) |
fatdog Samba Member
Joined: April 23, 2015 Posts: 68 Location: United States western N.Carolina
Posted: Tue Apr 28, 2015 5:06 pm Post subject: |
New to the forum so finding others with the same illness that I've had for 20 years is nice. Today I cleaned my '73 standard (soon to be daily driver) bug and let my little boys pretend to drive my '65 (true love but don't tell my wife) sedan. Got to make sure the VW illness continues on. |
Posted: Tue Apr 28, 2015 5:30 pm Post subject: |
nice work getting your boys onto vw fatdog and 1st post! well welcome to the forum, its awesome! I dunno what I would have done without the people on this forum! _________________ 1990 911 Porsche C2 (964) - Sold
Posted: Fri May 01, 2015 1:59 pm Post subject: |
Wrapped up the brakes.
All new from the master back, replaced everything(front disc were all good). Adjusted and bled and they feel great. _________________ My Stable: 65 Mustang Fastback, 88 Lebaron GTC Convertible, 01 Sebring Convertible, 09 HHR SS (325whp,400wtq), 92 Harley Heritage Softail And my 1st Bug a 73. |
tortugabug Samba Member
Posted: Wed May 06, 2015 10:11 am Post subject: |
New member here! Just got my first beetle , its a 1500cc 72 german.
Though theres a lot of things to fix, this is her first wash and wax
Antonio Trejo VW Parts Dealer
Joined: December 17, 2003 Posts: 937 Location: Mexico City
Bob Brugge Samba Member
Joined: April 09, 2015 Posts: 721 Location: Missoula, MT
Posted: Fri May 08, 2015 8:19 pm Post subject: |
Today I put in a high volume oil pump. I partially disassembled the motor after a hack mechanic put it back together. I have found more stuff loose or falling off, like my valve train...
Tomorrow I am going to try to finish tightening stuff up and pray that nothing goes "SNAP"!!! Then I will get the engine back in the car and continue to pray this thing hasn't eaten a part. |
wingnut6999 Samba Member
Posted: Sat May 09, 2015 12:33 pm Post subject: her first a sponge bath |
A wise man once told me to make it stop, make it go, make it pretty. The stopping part is good tho I hope one day to do the disc conversion. The go part is getting better. So today I did the make her pretty. Yanked out the old carpet behind the back seat. Shop vac every nook and cranny. Scrubbed the interior with hot water and pinesol. Cleaned the windows. Then for gits and shiggles I used the kitchen sponge and soapy water on the outside, doing small areas then wiping with a towel before it dryed. That took off all the white haze and black spots!! Well she may not be road ready but she sure looks good!
