mchn13 Samba Member
Joined: February 28, 2008 Posts: 240 Location: Columbia, SC
Posted: Mon Sep 07, 2015 6:19 pm Post subject: |
nibnib03 wrote: |
Quote: |
Did you rebuild them or find new ones? I need to do something with mine before I put my ,69 back together. |
Um..Rebuilt-ish, I replaced the outside rubber and straighted the kink in the chrome a little bit with some pliers as a added bonus the silicone lube I used really put a shine to the old chrome but if your gonna do it I would say replace the inside and outside rubber at the same time since I only did one eventually im gonna have to take it all apart to do the other. |
Who had the seals? I honestly. Didn't know you could replace them lol. _________________ Steve Moore
always over budget on something.always |
Kindredz Samba Member
Posted: Mon Sep 07, 2015 6:45 pm Post subject: Installed fog lights |
Installed 7' hella fog lights on front bumper.
stained wood rails on roof rack.
Adjusted valves. |
nibnib03 Samba Member
Joined: November 12, 2014 Posts: 71 Location: Bowie MD,
Posted: Mon Sep 07, 2015 6:49 pm Post subject: |
mchn13 wrote: |
nibnib03 wrote: |
Who had the seals? I honestly. Didn't know you could replace them lol. |
you can just google "vw pop out window rubber" and you will find a few places (jbugs.com,wolfsburgwest.com,westcoastmetric.com,cip1.com)
but I just went to ebay for the ones I have, they where $18 I think. _________________ Tell me and I forget. Teach me and I remember. Involve me and I learn.
-Benjamin Franklin
69' Baja bug 1776cc
My Build Log
http://www.thesamba.com/vw/forum/viewtopic.php?p=7705799#7705799 |
NYPATER Samba Member
Joined: June 16, 2006 Posts: 11 Location: Tarpon Springs, Fl.
Posted: Tue Sep 08, 2015 12:21 pm Post subject: Set the valves |
First time doing this. Not as bad as I thought it would be. There was zero clearance! Yikes!
And I ordered a phenolic spacer for the carb. Darn boiling gas vapor lock @!&*%£!! |
pbnj Samba Member
Posted: Tue Sep 08, 2015 5:46 pm Post subject: |
installed new floormats, replaced a dead fuse, and am trying to figure out how to get the aftermarket radio out of the dash |
pbnj Samba Member
Posted: Thu Sep 10, 2015 9:46 pm Post subject: |
new floor mats that say 77 BUG, new fuel filter installed, installed NOS headlight switch, valves adjusted, back up light issue resolved- previous owner cut the wire. No inline fuse. Next LED headlights, speaker shelf, replace dash bulbs, replace some fuel hose _________________ 1977 Super Convertible |
mark tucker Samba Member
Posted: Thu Sep 10, 2015 9:48 pm Post subject: |
drove it.....what else is there?? |
irvanm Samba Member
Joined: January 09, 2008 Posts: 609 Location: Lawrence, Kansas
Posted: Sat Sep 12, 2015 5:59 am Post subject: |
I received the 2 seals for the fresh air hoses my new 74 Super had been missing and installed them and I got a new plastic bumper end too and installed it. I put the seals with this side facing up into the hoses, is that correct?
mountainkowboy Samba Member
Posted: Sat Sep 12, 2015 5:00 pm Post subject: |
Finally changed the points....they were DONE. There was no fiber plate left to speak of. They made it 2 years and its my DD. _________________ Chuck in Socal
71 Super Convertible...DD
78 Honda CB750K
06 Honda CR-V (wifes)
63 IH Scout 80 "Beater" |
pbnj Samba Member
Posted: Sat Sep 12, 2015 7:27 pm Post subject: |
new speakers and back shelf installed, LED headlights installed _________________ 1977 Super Convertible |
kai.scott98 Samba Member
Joined: August 29, 2015 Posts: 514 Location: lincolnshire
Posted: Sun Sep 13, 2015 10:26 am Post subject: |
Replaced back seats with wood, to cover it with carpet and smooth out the back.
And primered parts of the bug that i had to use filler or p40 on.
Beetlebaum Samba Member
Joined: December 04, 2008 Posts: 2181 Location: Virginia Beach, VA
gp98 Samba Member
Joined: May 17, 2010 Posts: 225 Location: Massachusetts
Posted: Thu Sep 17, 2015 7:54 pm Post subject: |
Removed battery to charge, belt let go and caused hell with gen pulley, destroyed key ( keyway), still charges but pully grinding on gen, done. Then decided which vehicle was going to be donor as I want to take it to Conn. tomorrow...'29 Mercedes" , Gazelle kit giving it up. Up early... _________________ 1972 Super Beetle
1961 Dune Buggy,2010 Larz Anderson Class Winner
1971 BSA Lighting
1969 tin top westy |
gp98 Samba Member
Posted: Sun Sep 20, 2015 5:36 pm Post subject: |
Enjoyed the hell out if it! Fri. a.m. I removed messed up generator, removed gen from a project, swapped in and went on 2 hr test ride on the highway (95 south) to see an army buddy I haven't seen in 30 yrs. Ran awesome. Came home Sat. and the ride was fun as hell ( don't get away much).Drove today for errands around town. _________________ 1972 Super Beetle
1971 BSA Lighting
enalnitram Samba Member
Joined: July 23, 2015 Posts: 77 Location: Grand Rapids, Michigan
Posted: Mon Sep 21, 2015 9:05 am Post subject: |
This is my first 'what did you do' post.
My super had rotten door panels but the vinyl looked ok. So I'm reusing it, with new backing. I bought the brown fiberboard at lowe's for $4. The rubber bands on the clothespin, is a trick I picked up from my guitar making days. It adds a lot of clamping power. I used 5-min epoxy. I added a viscuene strip to the edge, which is affixed with spray adhesive, but also has epoxy, near the edge. Maybe they'll fall apart in a week. Who knows. I put thin wood strips (tongue depressors) on the other side so that the clothespins didn't leave little dents all over the edges of my door panel.
_________________ 1972 Super Beetle |
Posted: Fri Oct 02, 2015 9:12 am Post subject: |
I did some machine work on the new transmission Im building for it....yesterday. |
TheAmazingDave Samba Member
Joined: April 11, 2013 Posts: 788 Location: San Jose, CA
slagathor Samba Member
Joined: December 08, 2012 Posts: 253 Location: Oakland, CA
Posted: Sun Oct 04, 2015 5:59 am Post subject: |
washed, waxed and took her for a drive to the park despite brake lights and headlights not working
irvanm Samba Member
Posted: Mon Oct 05, 2015 9:12 am Post subject: |
I took the Sun Bug to a local antique car show. |
mslibertarian Samba Member
Joined: January 19, 2008 Posts: 191 Location: Mississippi
Posted: Tue Oct 06, 2015 1:46 pm Post subject: |
Found out where my rattling was coming from, so much quieter now.
_________________ "Veedubers is some strange folk." Bob Hoover
Haikus are easy
But sometimes they don't make sense
Refrigerator |
