mark tucker Samba Member
Posted: Tue Sep 06, 2016 9:13 am Post subject: Re: What did you do to your Bug Today? |
mine starts eazely&quick. but it's been forever since I did any points adjustments....like...never on this car...hmm I think Ive had 2 cars with points in my life.56 chrysler windsor and for a while my 74 toioidie had points till we upgreaded it to a mopar electronix like we did everything that had points.oops I had a 67 dart that orignaly had points too, wish i still had that car..
as for my bug and doing somethen to it...still trying to get that milk smell out of it. rewashed the carpet and drying it out again......rain had hampered the defunking on my bug...and made it worse than it should be. |
Old n' slow Samba Member
Joined: October 29, 2012 Posts: 619 Location: Western Maryland
Posted: Sun Sep 11, 2016 3:05 pm Post subject: Re: What did you do to your Bug Today? |
Took a length of galvanized bailing wire and wired up an emergency trunk release on my 69 Bug, poking it out of the passenger side drain hole in the spare tire well. _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
All my daily drivers gone but not forgotten;
1964(sunroof)1967 & (2)1968 Beetles , 1968 Squareback , 1963 (23 window )Deluxe Sunroof Bus , 1969 Westphalia camper, 1974 Dasher , 1985 Vanagon , (2) 1981 Rabbit Diesels & a 1991 Jetta Diesel . |
HenryJ53 Samba Member
Joined: September 09, 2016 Posts: 79 Location: Lakeville,MN
Posted: Sun Sep 11, 2016 5:53 pm Post subject: Re: What did you do to your Bug Today? |
Ripped the wire harness out from the fuse block back because it had burnt wires and a short that destroyed 7+ wires, Time for new harness and engine compartment sound proofing |
chrisarnt Samba Member
Joined: November 28, 2005 Posts: 541 Location: New Jersey
Posted: Mon Sep 12, 2016 1:15 am Post subject: seat belt, klaxon horn, larger roller gas pedal. Oil cap refurb |
There were no seat belts in the car, now there is a driver seat belt at least. The belt had an extra pin that I had to drill a hole for.
6 months ago I bought an oogah oogah horn at harbor freight, but hadn't the gumption to put it in my Subaru. The Baja seems a good fit, but I'm not happy with the sound just yet. I read that in order to get that ahh-oog-ahh sound instead of just the oog that I currently have I need to make the signal build and dissipate. The Russian girl at radio shack can help me with that.
There is no pedal, just the little roller. I was in Sears hardware and saw this 3" garage door pulley. So, with that and the correct spacer to make it fit the pin. And a little in the parking lot curb grinding I now have a much larger roller for a gas pedal.
The oil cap was rusty inside from sitting and was puking rust chunks into the oil filler when I put it on and off. So I soaked it in phosphoric acid for about an hour with a few scrubbing between. Washed it with soap and water, soaked it in gasoline and then soaked it in motor oil and then packed it with grease. Viola! |
Posted: Mon Sep 12, 2016 11:05 am Post subject: Re: What did you do to your Bug Today? |
raido shack??? I thought all those were long gone. or is it a russian girl you have in a raido shack.........see if she can get you a new oil cap too while she is servicing your ohh go....oohh horn.
I did manage to get mine all clean&no milk smell after a few cleanings& dryouts. sure was nice to see that hot florida sun for a change. |
darkstar1107 Samba Member
Posted: Mon Sep 12, 2016 4:29 pm Post subject: Re: What did you do to your Bug Today? |
Bought it! Picked up my first VW, a '74 Super Beetle. I expect I'll be back here quite a bit asking questions. I hope you all go easy on newbies! |
andrewwebb58 Samba Member
Posted: Wed Sep 14, 2016 6:44 am Post subject: Re: What did you do to your Bug Today? |
Last weekend, replaced shift rod bushing at the shifter, and replaced the shifter coupling at the transmission. Some jack leg had put the wrong coupler on it, and after removing all the fasteners, it wouldn't come off the shift rod! I don't know how in the world the guy who owned the car before my Pa put it on, but it surely wasn't coming off! Had to take an air rotary tool with a metal cutoff wheel to remove it! After all that, the shifter cleaned up nicely and shifts much better!
Noticed brake lights weren't working, and braking was less than desirable. Checked the master cylinder and only a few drops of brake fluid! topped of the master and no brake lights work and tires squeal when you stomp on the brakes...couldn't be happier! will be pulling all four drums this weekend to see if any of the wheel cylinders are losing fluid...it must be going out somewhere! _________________ 1974 Super beetle Lime Green 1600 DP (originally my Grandpa's before he passed)
1995 GMC 1500 4x4
2015 Silverado 4x4 |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Wed Sep 14, 2016 10:49 am Post subject: Re: What did you do to your Bug Today? |
Just finished a valve adjustment.
_________________ Glenn
Member #1009
#BlueSquare |
tonysantacruz Samba Member
Posted: Wed Sep 14, 2016 7:39 pm Post subject: Re: What did you do to your Bug Today? |
Not today, but on Saturday: I fixed the gas gauge. Every now and then it went from full to half to full again, si I took it off the hook and reconnected it. Works fine now. Also, the trunk lock wasn't locking properly, so I had to adjust it. Finally, I took it to a clutch and brakes place to see if the drums were ok (they were), and they disconnected the speedometer. A quick Youtube tutorial later, I reconnected it. |
the_purist Samba Member
Posted: Thu Sep 15, 2016 5:38 am Post subject: Re: What did you do to your Bug Today? |
whats better for a 68' autostick? a single or dual barrel, split or together carb? _________________ Autostick life is the way to go
Stock life, Stock car, Stock Friends, Stock Everything, Stock Life is the way to go.
68' Autostick (In Progress, red paint, black interior)
71' Super Beetle (Restored to original baby blue)
Triple White (Sold, engine seized, top rotted, interior rotted, MAJOR body rust) |
Posted: Sat Sep 17, 2016 3:40 pm Post subject: Re: What did you do to your Bug Today? |
split duel bbl crabs....new not old junk that is wore out and sold as the best in the world by some scammer.....
as for what i did to my bug today...gave it a nick long highway drive@ 70+ to a car show to see some old friends....and some morons too. |
VERTED71 Samba Member
Posted: Fri Sep 23, 2016 1:57 am Post subject: Re: What did you do to your Bug Today? |
replaced all the bulbs after I cleaned the housings and connections. Finished buffing the paint, put bumpers back on. Almost ready to roll! _________________ Aloha'z and have a great day!
71 Super Beetle Vert
15x4.5 Front
15x6.5 Rear
155/60R15 74T tires FRONT
205/65/15 tires REAR
1600 Dual Port
Progessive Carb
Electronic Ignition
Tri Mil "hotdog" exhaust |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2240 Location: Medford, OR
Posted: Fri Sep 23, 2016 8:38 pm Post subject: Re: What did you do to your Bug Today? |
Installed CNC shift coupler.
http://www.thesamba.com/vw/classifieds/detail.php?id=1252462
_________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
Posted: Sat Sep 24, 2016 11:48 am Post subject: Re: What did you do to your Bug Today? |
I rolled down the window....it's hot outside. |
Posted: Mon Sep 26, 2016 10:40 am Post subject: Re: What did you do to your Bug Today? |
installed nylon aircleaner covers -
have call-back set from TopLine for their out of stock sway bar.
its a fun car to drive - will it become funner? _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
itskyle Samba Member
Joined: October 04, 2013 Posts: 634 Location: Plainfield, IN
Posted: Tue Sep 27, 2016 7:42 pm Post subject: Re: What did you do to your Bug Today? |
Tightened the fan belt.
I was going to replace it, but couldn't find my spare.
Guess I may end up being in the market for a spare belt soon.
Only found 4 shims.
Hope I didn't mess up anything when I was doing it. Will find out tomorrow a.m.
Kyle _________________ --
69 or 72 Autostick Bug current
66 Bug (We both miss it)
74 SuperBeetle Auto Stick (I miss that car)
73 SquareBack, Straight Stick (Wife misses this one.) |
SlammedVDubs Samba Member
Posted: Wed Sep 28, 2016 12:01 pm Post subject: What did you do to your Bug Today? |
Going to start on cleaning out the pan fuel line ( Has fuel in there that has been sitting for 20 years! ) Can't get it unplugged! Tried everything from white vinegar to trying to ram it out with chicken wire. Nothing worked so far. Advice? _________________ Keep e'm slammed |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3328 Location: 802 The Pointless Forrest
Posted: Wed Sep 28, 2016 1:00 pm Post subject: Re: What did you do to your Bug Today? |
old clutch cable or some such on a battery drill might need reverse _________________ "Albatross"! |
enalnitram Samba Member
Joined: July 23, 2015 Posts: 77 Location: Grand Rapids, Michigan
Posted: Mon Oct 03, 2016 4:19 pm Post subject: Re: What did you do to your Bug Today? |
I was scared, but it was simple! They pop right in...
Before. After.
_________________ 1972 Super Beetle |
unclewede Samba Member
Posted: Tue Oct 04, 2016 7:52 am Post subject: Re: What did you do to your Bug Today? |
mark tucker wrote: |
I rolled them up and closed the vent windows on my son's 77, it was supposed to get foggy last night. |
