Rhinoculips Samba Member
Joined: August 08, 2005 Posts: 918 Location: Keystone, Colorado
Posted: Sat Aug 23, 2008 11:37 am Post subject: replacing transmission seals |
Been surfing the threads and haven't found exactly what I need.
The other day I pulled the engine out of my '89 Westy (2wd) and found a light film of oil all around inside transmission bellhousing. Nothing major, clutch was dry. No leaking between the bellhousing and the engine before the engine was pulled. Is the oily fim normal? Or should I suck it up and replace the input shaft seal? Any tips or tricks to this?
People on the samba said if you change the input shaft seal, you should check the oil slinger behind the seal is press fitted. What does this mean exactly?
Also, there is a leak around the shift input selector, where the shift linkage enters into the transmission. How easy is it to replace? Any tricks?
Finally, the housing around the CV joints seem heavily gunked, but the CV boots are clean as a whistle. I am thinking of replacing the seals and cap around the final drive(?). I have seen the thread that describes this, but I am not sure how necessary it is. _________________ “May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image
Mofus Samba Member
Joined: February 21, 2008 Posts: 369 Location: San Diego
Posted: Sat Aug 23, 2008 11:58 am Post subject: |
I replaced the shift shaft oil seal a while back and it was pretty easy. However mine was crumbled and glued into it's seat. I learned after I replaced it that if you unbolt the cover on the opposite side of the selector shaft, and back out the shaft a little, it makes it a lot easier to get the seal out. I used a socket of the same diameter to push in the new seal. While I was in there I replaced the shift shaft linkage with the kit from Van-Cafe. Keep in mind if you buy the kit from them it doesn't come with the boot that surrounds the oil seal. I took a picture of it after I replaced it:
_________________ '87 Syncro passenger w/ 2.2L Subaru
'10 Passat Wagon (keeps Mrs. Mofus away from my van) |
Posted: Sat Aug 23, 2008 5:46 pm Post subject: |
Just got home from work and perused the Bible. From what I see, they show a seal puller for both the input shaft seal and the shift selector shaft seal that is used. Thing is they show it when their is no shaft in either and you pry towards the center of the seal.
How easy are these seals going to be to pry out with the shafts still in place? What kind of puller can you use?
Then again, whats going to be the best way of seating the input shaft seal with the shaft in the way?
What kind of grease is recommended to apply in the "groove" of the seal? _________________ “May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image |
Posted: Sun Aug 24, 2008 8:15 pm Post subject: |
Bump...........
Any one? _________________ “May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Posted: Mon Aug 25, 2008 4:34 pm Post subject: Re: replacing transmission seals |
Rhinoculips wrote: |
People on the samba said if you change the input shaft seal, you should check the oil slinger behind the seal is press fitted. What does this mean exactly? |
Here are a couple of pictures of the oil slinger.
This first one is the oil slinger as you see from the ring and pinion side of the bellhousing. It's the tube protruding from the bellhousing with the grooved spiral centerbore.
This second one is of the oil slinger, guide sleeve and shaft seal removed from the bellhousing. The oil slinger is simply press fit into the bellhousing. The serrated lip is located on the flywheel side of the bellhousing.
When they say to make sure that the oil slinger is seated, this simply means that you want to be sure that it hasn't moved in it's bore and if it has, give a tap back into place.
Then again, whats going to be the best way of seating the input shaft seal with the shaft in the way? |
I have never replaced one with the bellhousing on the gearbox. The bellhousing is REALLY easy to remove. Four bolts and it come off. A little clean-up on the mating surfaces and sealer and it's ready to reassemble.
What kind of grease is recommended to apply in the "groove" of the seal? |
A VERY light coating of wheel bearing grease is what I use. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Jamo7 Samba Member
Joined: September 25, 2014 Posts: 124 Location: Seattle
Posted: Wed Sep 14, 2016 2:52 pm Post subject: Replacing the transmission selector shaft seal |
The information here helped me replace my selector shaft seal last night. (The one pictured below.)
I found two other items particularly helpful if anyone stumbles across this thread while preparing to do this job:
1) the instructions in the Van Cafe description of the Transmission Selector Shaft Seal:
http://www.van-cafe.com/home/van/page_131_783/transmission-selector-shaft-seal.html
2) the schematic below showing what to expect after removing the reverse switch cover and the direction I was supposed to remove the selector shaft.
James _________________ '84 Westy 2.1 wbx |
Crowan Samba Member
Joined: August 31, 2017 Posts: 8 Location: Vancouver, BC
Posted: Mon Apr 23, 2018 7:44 pm Post subject: |
Mofus wrote: |
Is it the same procedure on the early model Vanagon 4 speed transmissions? I have a 1980. |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2310 Location: Southeast Kentucky
Posted: Mon Apr 23, 2018 8:02 pm Post subject: |
Crowan wrote: |
Mofus wrote: |
The selector shaft removal is much different on the 091 transmission (1980-83.5). The gear shift housing (end of tranny) has to be removed. However, the Bentley shows using Channel Locks to remove the selector shaft bushing which contains the seal. Apparently it just twists out.
Although I did rebuild the 1980 091 tranny that I installed in my 84, I cannot remember how I approached replacing the seal. But, it does look rather simple based on the Bentley (Page 35.19, removal Fig 3 and replacement Fig 4). Most likely the procedure could be done with the transmission in place.
I suggest pressure washing any transmission that has been removed. Find the vent hole on the top toward the front of the tranny so that you can place a temporary plug. _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
Crowan Samba Member
Posted: Tue Apr 24, 2018 10:09 pm Post subject: Re: replacing transmission seals |
Thank you, AndyBees, for the Bentley reference. I want to change the seal because I think this is the cause of my oil leak. No need to tackle the selector shaft bushing, at the moment. Figure 5 of Bentley s. 35.19 appears to show this seal being removed (by prying with a screwdriver) with the bushing still in place. I will try this when my parts arrive. _________________ 1980 Aircooled Vanagon |
Vana Guy Samba Member
Posted: Tue Dec 07, 2021 12:13 pm Post subject: |
Mofus wrote: |
Is that seal in backwards? Mine was installed the other direction. I have found conflicting info on the placement of that seal. |
Posted: Tue Dec 07, 2021 1:33 pm Post subject: Re: replacing transmission seals |
The flat side is always out on a seal.
I'm pretty sure that seal is spring loaded, thus, you would not want the spring exposed to the elements!
Below is a copy from Weddle's website .. If your seal looks like this, it is likely it can be turned either way. It appears to have a double lip. Mark Ward brought this to my attention. I'm too lazy to go look for one in my stash.
