VWLover13 Samba Member
Posted: Sun Aug 24, 2008 11:49 am Post subject: Coil wiring diagram for 1973 VW Beetle |
I took out the engine in my 73 bug a while back and now I put it back in. I got new points, new plugs, new rotor, new distributor cap, new wires, new coil. All the gaps setting is correct, cap is on tightly. The engine is turning over but NOT firing. We're getting about 11.5 volts to the coil on both sides of it (+ and -).
I can't figure out the problem. The only thing I can think of is that it's the wiring to the coil. There are 4 wires, and I have unhooked all of them from it. I need to know how to put them on correctly because I don't know.
We're starting at the coil so we can eliminate that and move on to the points.
I need help ASAP, because this is very frustrating Thanks for any help! |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19612 Location: Samba Center for Behavioral Science
Posted: Sun Aug 24, 2008 12:33 pm Post subject: |
Got it!! Thanks a TON. That's all I needed and it cranked right up. Appreciate it!  |
Posted: Sun Aug 24, 2008 4:20 pm Post subject: |
| VWLover13 wrote: | Got it!! Thanks a TON. That's all I needed and it cranked right up. Appreciate it!  |
Great... thanks to Glenn... it's a diagram he has on his site and has linked too many times... I just dug it up from one of his bazillion posts  _________________ my seller feedback
rebuilt carb info = for sale
"STFU Polly and go eat a cracker!" 12-21-2012.... can't wait! |
1973vwbeetle112 Samba Member
Joined: May 06, 2011 Posts: 30 Location: North Carolina
Posted: Fri May 06, 2011 1:46 pm Post subject: |
| what may be the problem if everything is connected right but still no start? |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 10047 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri May 06, 2011 5:47 pm Post subject: |
| 1973vwbeetle112 wrote: | | what may be the problem if everything is connected right but still no start? |
IF key is on and there is continuous voltage (12 volts) at terminal 1 of coil while engine is being cranked the problem is either between coil and distribuitor or actually in distribuitor
Points may not closing when rubbing block is supposed to be off the cam lobe in distribuitor.... Or broken wire between coil and points in distribuitor...
Dale _________________ Lives his life vicariously through his own self...
1970 "Kellison Sand Piper Roadster" For Street & Show.
nsracing  Samba Member
Joined: November 16, 2003 Posts: 5450 Location: VIRGINIA
Posted: Sat May 07, 2011 10:14 am Post subject: |
| Oh come on, Dale. Do you really think the engine will start if the points stayed closed? |
Posted: Sat May 07, 2011 10:59 am Post subject: |
| nsracing wrote: | | Oh come on, Dale. Do you really think the engine will start if the points stayed closed? |
| Quote: | | Points may not [be] closing when rubbing block is supposed to be off the cam lobe in distribuitor |
I think you may want to read my statement again..... I believe I mentioned if point did not close there would always be 12 volts on points side of coil when cranking motor...
Posted: Mon May 09, 2011 2:35 pm Post subject: |
| the points were bad. now asking if you know why a loud knocking and will not stay on and high idle. |
