jay64 Samba Member
Joined: April 18, 2008 Posts: 139 Location: Somerville, TN
Posted: Tue Jun 14, 2011 11:09 pm Post subject: |
The stunt show at Disney World has cars that look like the ford focus running 1300 cc from motorcycles. It pushes those cars around very quickly. _________________ '76 BUG 2054cc |
morymob Samba Member
Posted: Wed Jun 15, 2011 3:36 am Post subject: |
HRVW wrote: |
Someone mentioned a 2 cyl VW engine possibility.
As a VW shop owner back in 1979 I had many old parts laying in the scrap pile waiting for disposal. On a sat afternoon got the idea of the 2 cyl engine.
Welded up a couple crank journals, used rods, used bearings, two used pistons/cyls, two junk SP heads, warped engine case...assembled with new gskts from broken gskt sets. Used #1 and #3 on the case.
Sheet metal, SP intake manifold, old clutch and pressure plate and installed the engine into a 70 T1 bug.
Drove it down the fwy at 35 mph. Slow getting there due to the car weight but the combination might have worked in a small trike etc,
Never did try anything else over the yrs. |
I had to do the 2-cyl thing during the 70's gas crunch, not enuf money to do a rebuild and drove it in a '64 body fot about 2 months until gas was easy to get, works well around town and to work. Gonna do another, only going 94's and some other ideas this time, just for fun and maybe this time check out gas mpgs and performance. VW mag covered just this thing around late '70's mag which ihave somewhere, a college out west class project, 2 diff vw's and a rear eng 4cyl(X-19??) Fiat. |
jbbugs Samba Member
Joined: September 16, 2002 Posts: 2150 Location: Behind the wheel
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
Posted: Wed Jun 15, 2011 5:37 am Post subject: |
With a name Like Yamaducci (Yamaha-Ducati) I have to chime in and say that the OP was interested in a motorcycle engine in a bug; not the other way around. So why would you want to do that when the obvious problem would be the inherent issue of broken cranks. The car is much heavier than the intended use of that engine.
Sure, anything could be done for a price but why.
You can get a Smart car with a Hyabusa engine in it but the kit cost more than a brand new Smart car then you are still left with a cut up piece of junk that cost $30,000+.
There is a reason most people don't do it and that is because reality sets in. I guess it's fun to contemplate for a minute. _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
mark tucker Samba Member
Posted: Wed Jun 15, 2011 6:22 am Post subject: |
I still dont under stand why??a well built 2332 will gt 40+mpg and have plenty of power.my wedgeport 2332duel 44's gets 35+mpg. if you just want a 2cyl bug looking car buy an old toyota publica. 2 cyl air cooled oposed.looks like a 4 door bug. slower than shit flowing up hill, but I have seen slower vw's.we had one when I was a kid. |
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2073 Location: Gardnerville, NV
Posted: Wed Jun 15, 2011 6:43 am Post subject: |
even if you went witha r1 or r6 motor with trannys somehow discected those motors only come alive at much higher rpm range.... in other words your car would be a total pig until 4500 if that... if it tops out at 12000 there might be a trade off.... but that would be almost unbearable for anykind of streetable vw _________________ Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4925 Location: Raleigh, North Carolina
Posted: Wed Jun 15, 2011 8:49 am Post subject: |
[quote="mark tucker"]I still dont under stand why??a well built 2332 will gt 40+mpg and have plenty of power.my wedgeport 2332duel 44's gets 35+mpg. quote]
Care to prove the 35+/40+mpg 2332 numbers?
How did you manage to pull that kind of economy when Hot VW's, in conjunction with some talented engine builders, struggled to hit the mid-30's with a 1750cc engine?
Not calling anyone a fibber, but what is your 2332/transmission/car combination?
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
torsionbar Samba Member
Posted: Wed Jun 15, 2011 9:51 am Post subject: Re: Motorcycle engine in a bug? |
oicdn wrote: |
How hard would it be to put a 1000cc motorcycle engine in a bug? |
not difficult at all. you can slide the passenger seat back all the way and lay it on the floor. it would also fit on the back seat most likely, although you'll want to wrap it in a tarp to avoid soiling the upholstery. |
Posted: Wed Jun 15, 2011 10:17 am Post subject: |
[quote="didget69"]
mark tucker wrote: |
bnc |
enough power to pull the car with out the motor knowing it is doing it. a fricken mag ??j?let me see if I go by mag std addtion of power for each snazzy part of the week I would probably be putting out some where in the neighborhood of 400 hp. and yes lets put something with little holes in it under the carb to make the motor suck harder to try to keep up with a yugo, hmm how much wasted power is in the extra sucking on the mag motor???just because somebody is selling snake oil dosent mean your snake needs oiling. trans 3.88 .89&.92 4th about the same, but the .92 is nicer to drive in town with the 19.5 wide by 33 tall mickeythompson street pro tires. the next set of tires were hoosier dirt track 16x 31.5 millage not much change the 33"tire was in reality a 32+" tire unless you aired it up real good (20 psi). if your motor spends all of it's time with the throttel WFO trying to keep up you need to fix it or have someone who know how to do it do it.
car has a 4.12 trans in it now with a 2028 wedgeport duell 44's 28" tire.still more than 33 mpg (by gps) with baha fenders hanging in the wind.go figure.
WTJT |
bdkw1 Samba Member
Posted: Wed Jun 15, 2011 11:02 am Post subject: Re: Motorcycle engine in a bug? |
torsionbar wrote: |
oicdn wrote: |
How do you get a Goldwing motor in a Dodge Neon rental car? Take off the back door of course.......... |
Posted: Wed Jun 15, 2011 12:41 pm Post subject: |
yamaducci wrote: |
Ha, Break out the popcorn! |
...I'm still waiting for a analytical response with validated proof... keep popping the popcorn. I'd say that it rocks that you have been able to pull-off what a number of VW engine building veterans have not been able to achieve. Who mentioned oiling snakes?
The bull is beginning to lift it's tail -
Posted: Wed Jun 15, 2011 12:46 pm Post subject: |
southysuper wrote: |
I would still like to find an adapter for a v2 to vw trans other than blackjack or Z cars. |
Make your own adaptor...
cmiller95 Samba Member
Joined: August 04, 2010 Posts: 1232 Location: Illinois
Bewitched Samba Member
Posted: Wed Jun 15, 2011 11:38 pm Post subject: |
In holland i once saw a buggy with i think was a Kawa ZZR1100cc engine on it.
Had some small tires(think 13 inchers)on it and went like hell with that engine.Dont know how it did on the freeway or so but sprinting off from trafficlights was a blast to see |
Greezy Joe Samba Member
Joined: April 12, 2010 Posts: 1534 Location: Crawfordville, Fl
Posted: Thu Jun 16, 2011 3:54 am Post subject: |
[quote="tstracy39"][quote="hotair65"][quote="Pelikan"]
tstracy39 wrote: |
Here's the pic I was looking for:
Motto Guzzi, on all the BMW Rallies I have been on (I ride a Harley), where referred to as a BMW with a HARD ON I have seen a few Bemmers with VW motors tho at Daytona Bike Week. I think I was told by the people that had them that there as a kit for the conversion. _________________ Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound". |
aspirit5 Samba Member
Posted: Tue Jul 28, 2015 6:29 am Post subject: |
If you want to see a motorcycle with a Vw beetle engine, it's so simple!
so far the only bike i did find that had this conversion, was made by one of the most Icon of the Cars and Motorcycle world.
Mister Von Dutch !!!
There is a link where you can find a bit more about it:
http://www.dwmsracing.com/forum/index.php?topic=214.0
Hope this Help you guy's.
Sebastien |
