mgoodwin Samba Member
Joined: August 23, 2008 Posts: 12 Location: Seattle, WA
Posted: Tue Sep 09, 2008 12:12 am Post subject: Squeaking Sliding Window -- OUCH! |
I just bought an '84 1.9L Vanagon and she is wonderful!
However, the sliding glass door right above the stove/fridge area squeaks horrifically when you open it. I tried to figure out what was causing it, but the squeak is so deafening, I had to come back to it with earplugs. Seems to possibly be rubbing against old rubber possibly?
Has anyone dealt with similar issues on these sliding windows? I am hoping there is a quick fix.
Thanks! |
Wellington Samba Member
Joined: September 21, 2004 Posts: 1077 Location: Montreal
Posted: Tue Sep 09, 2008 4:27 am Post subject: |
| You are probably missing the plastic slider in the bottom channel, or it is worn right through. |
sanchius Samba Member
Posted: Tue Sep 09, 2008 5:26 am Post subject: Re: Squeaking Sliding Window -- OUCH! |
Mine does the same thing. On mine, it's the vertical metal bar in the middle of the window scraping across the moving glass. If I pull out on the metal a little as I open the window, there's no sound. It's annoying, but I don't want to brute-force the metal either. Unfortunately, I simply haven't had the time to research solutions here yet.
| mgoodwin wrote: | I just bought an '84 1.9L Vanagon and she is wonderful!
Thanks! |
campism Samba Member
Posted: Tue Sep 09, 2008 6:42 am Post subject: |
I used various sprays on the top and bottom tracks, most recently some silicone spray and now my sliding windows have finally quieted down. Took a while for the spray to work its way in. I also sprayed a Q-Tip and wiped various places on the track I thought might need it. Keep after it.
Remember: window screech, wife screech; window quiet... |
snowesty Samba Member
Joined: September 06, 2005 Posts: 189 Location: Nelson, BC
Posted: Tue Sep 09, 2008 8:59 am Post subject: |
Mine used to squeek. I figured out that it was the glass rubbing on the plastic frame of the screen that was making the noise. I took out the screens and viola! no squeek I like being able to open them while I drive for the airflow, and no (no more than normal at least) noise. When I cam, I pop them back in. Will be making some magnetic-on screens for the side windows, as well as the door windows when I get a chance. (Well, realistically, spring. Since it's cold now / no bugs...). _________________ Fritz - '86 Syncro Tintop, Camper interior
Toaster - '91 Multivan Westy, 4sp. |
MootPoint Samba Member
Joined: September 16, 2006 Posts: 663 Location: Sandia Park, NM
Posted: Tue Sep 09, 2008 9:11 am Post subject: |
| Wellington wrote: | | You are probably missing the plastic slider in the bottom channel, or it is worn right through. |
Same as mine. You can get replacement sliders from Van Cafe... http://www.volkscafe.com/main.jsp?pa=p&p=1464530415&pct=1508353218&ct=142109052 ...but they apparently only fit the newer van, not an '84 like yours (or mine). The sliders have small "wings" on the side to hold them in place but on the older sliding windows they seem to be almost impossible to install. If you cut the wings off, then they don't stay in place. You can modify the sliding window a bit to accept them (apparently) but you have to pull the window to do it. Nuts. There was a discussion on this somewhere here quite a while back. I've just discovered Gorilla Glue and I thought I'd try gluing a wingless- set in and see if it will hold.
If anyone else has newer info on this painful problem, I'd love to hear it m'self. _________________ 1984 Westy with tencentlife power! |
Posted: Tue Sep 09, 2008 1:31 pm Post subject: |
thanks for all the good info!
Turns out it was the glass of the windows scraping against the screen plastic.
When I pulled back the screen and opened it VOILA, no screeching!
So, next step is to remove the screen and sand it down so it wont scrape, or apply some tape to the edge so that it rubs against something non-screechy
BUT, I can't figure out how in the heck to get the screen off... Can someone help me? |
Pascal Samba Member
Joined: January 13, 2006 Posts: 671 Location: Fredericton, NB, Canada
Posted: Fri Sep 12, 2008 7:36 pm Post subject: |
Do a search on how to remove those screens. IIRC you puch down and out from the inside bottom of the screen frame. They should pop right out. Whatever you do, do not pry them out or you will likelly break the tabs holding the screen frame in place.
BTW I modified my '84 sliders to acept the newer plastic guide pieces. I wrote up the process on the Vanagon mailing list and on the Samba. http://www.thesamba.com/vw/forum/viewtopic.php?t=296393&highlight= _________________ '84 Westy
'90 Cabby
'04 Forester |
