Official Bay whine about parts and vehicles for sale
Goto page Previous  1, 2, 3 ... 150, 151, 152 ... 247, 248, 249  Next
ccpalmer Premium Member
ccpalmer is offline
PostPosted: Sat Feb 11, 2012 9:04 am    Post subject: Reply with quote
I also had a carb barb fall out, no fire but no fun either. I am now safety-wired as well with my filter over the tranny.
Maybe the filter isn't the issue but why risk it when the fix is so easy??
On my first three Buses I never cared about fuel lines also never had a problem but those Buses were 25-30 years old at the time. Now they're ~40 years old and thus all the more prone to age.
'71 Westy
'77 Bay/rusty shed on wheels
Chris Palmer
Cocobolo Co., LLC
ccpalmer.com
cdennisg
cdennisg is offline
PostPosted: Sat Feb 11, 2012 10:41 am    Post subject: Reply with quote
Desertbusman wrote:
cdennisg wrote:
Glad your bug survived, but this is yet another example of a filter being in the engine compartment, but not causing a fire. It seems to be the scapegoat for further issues. I agree that the filter and it's connections are areas for potential leaks, but the brass inlet pipe and old, dry, and non-ethanol compatible fuel line are the root cause of fuel caused fires, not the filter.
Thanks, I was really thrilled it didn't burn either but it still about scared the stuff out of me. I actually agree with you on these issues, somewhat. The root cause of the fires is fuel being ignited by ignition sparking or hot exhaust. Keeping fuel away from those ignition sources would solve that problem. Removing potential leak sources would solve that problem.
We know we have a bad hose situation. The right size hose available is bad. Good hose is the wrong size. I'm changing my hoses all the time, at the most every couple years. And I've still run into leaks and seeps. Seems like it's always been at connections where you can see the deteration and cracks and not in the hose runs. So avoid connections, and particulary in the pressure line. Solex inlet fittings are pulling out and fixing that problem or safety wire solves that. I didn't and most folks probably don't do that until a fitting pulls out. In addition to the fitting being a crummy design, the weight and probably flopping of a filter, the line pressure, and any hose tension is what actually pulls the fitting out.
A filter in the suction side of the pump helps solve many of those problems even if it is still in the engine compartment. My tanks are clean and I never get any junk in the filters so am not at all bothered by them being out of sight and in a akward location right under the tank. A lot of problems get solved that way although the hottest of the exhaust is right there in front of the engine.
This is perfectly stated. The filter is an indirect cause. I only run them in the engine compartment if I am dealing with a dirty tank and I want to be able to change that filter at will. I would rather put the filter on the feed side of the pump in the engine compartment, but I like to run a solid line for that area. I'll run the filter in the pump to carb line, with the brass inlet epoxied in place and the connections safety wired. I like to tie the filter off to something to keep it from bouncing around.
My 70 bus has a nice clean tank. the filter sits above the tranny and is well supported. It's a pain to check and replace, but I don't need to perform that task often. The 57 I am building may have a cruddy tank, and it will get a filter that is easy to access if need be.
Olddog52 wrote:
horn test. one tab to ground, the other to a 12 volt source. Listen intently for a sound.
Stuartzickefoose
Samba Post Whore
Stuartzickefoose is offline
PostPosted: Thu Feb 16, 2012 6:25 pm    Post subject: Reply with quote
http://seattle.craigslist.org/est/cto/2850506528.html
beautiful bus, but for 16500, can we at least get 4 whole pictures???
MINE - 1978 Westfalia ~ Maisy ~ FI, Hydraulic Valves, Electronic Points, 2.0 (NEED A SET OF HEADS, PM ME IF YOU HAVE A SET)
DAD's - 1972 Westfalia ~ Sticky ~ 1.7(?) 914 motor, allison electronic ignition, electric fuel pump, dual webers w/o choke.
“Don't cry because it's over, smile because it happened.”
“Those who mind don't matter, and those who matter don't mind.”
rustbus
rustbus is offline
PostPosted: Fri Feb 17, 2012 5:37 pm    Post subject: Reply with quote
k somebodies gonna get ripped oooo-oooofffff
http://www.thesamba.com/vw/classifieds/detail.php?id=1264377
thats just rude. these are what, $35 new? maybe $50?
May of '72 Deluxe. Red Bay Bus 2.0L L-Jet CS & 091 trans conversion
my Bus thread
Boesen
Boesen is offline
PostPosted: Sat Feb 18, 2012 3:31 pm    Post subject: Reply with quote
Shocked WOW!!! I just got a sweet used set from a Bay at a junkyard for $5.00.
1979 Westfalia Deluxe http://www.thesamba.com/vw/forum/viewtopic.php?t=474334&highlight=iowa
babysnakes
babysnakes is offline
PostPosted: Sat Feb 18, 2012 3:50 pm    Post subject: Reply with quote
I was talking with someone the other day and they commented "your window visors look like dealership options, not like that cheap aftermarket crap.". I had no clue nor could I tell the difference. If the seller said "NOS" then someone, not me, may think about it. You never know these days. Confused
'69 SC under resto
'72 deluxe daily
'78 Westy motor transplant in progress
'71 super vert
1st bus, '67 Westy in '83. Thank you '74 Pontiac Ventura.
Luftwagens
420GOAT wrote:
..dont ever ever ever ever EVER, compare any bus forum to a bug forum...
sgn2bapt
sgn2bapt is offline
PostPosted: Tue Feb 21, 2012 5:03 am    Post subject: Reply with quote
http://www.thesamba.com/vw/classifieds/detail.php?id=1265512
Seems a bit ambitious
Yes Officer, the suspension has sagged a bit over the years....
cdennisg
cdennisg is offline
PostPosted: Tue Feb 21, 2012 9:45 am    Post subject: Reply with quote
Nice bus, but it is overpriced. It being a non-camper, and not a special model or color makes it a bit run-of-the-mill. But, it has all of the documentation from new, tourist delivery, decent interior, body looks straight and dry, and it has what sounds like a nice, strong, fresh engine.
Hard to assess this one. I would guess it's in the $5-$7K range.
Stuartzickefoose
Samba Post Whore
PostPosted: Tue Feb 21, 2012 9:49 am    Post subject: Reply with quote
why not buff the paint? i bet if VdubTech got ahold of it the value doubles because the paint would look so much better. Laughing
if its original, why is there white coming through on the nose, just above the grill?
cdennisg
cdennisg is offline
PostPosted: Tue Feb 21, 2012 10:01 am    Post subject: Reply with quote
I agree, it would look nicer and probably fetch more money of it were buffed out really well. I would bet that paint would come out great.
I think what you are seeing on the nose is the paint fading through to the primer. I suppose it could be a repaint though. Hard to tell without seeing it in person.
Missing the rear bumper, too. For an asking price of more than a couple of grand, I would expect a rear bumper. But I do see Zee bed brackets on the rear seat back. That's a nice bonus.
EDIT: OK, just had a closer look through the photobucket link, and I see a pic of a rear bumper. Strike that comment. And upon closer inspection, it may have had a partial repaint. The left rear corner has definitely been repaired and painted, and the passenger side appears to be a slightly different shade of red. Could just need a good clean and buff, though.
sgn2bapt
sgn2bapt is offline
PostPosted: Tue Feb 21, 2012 10:07 am    Post subject: Reply with quote
What would be a fair price for this Bus in yall's opinion?
http://www.thesamba.com/vw/classifieds/detail.php?id=1017076
Thanks
cdennisg
cdennisg is offline
PostPosted: Tue Feb 21, 2012 10:27 am    Post subject: Reply with quote
Thanks
A nice, clean, shiny bus. Looks to be very solid and complete.
Roof, bumpers and wheels have been repainted the wrong color. Body has been repainted, color looks slightly off but it's pretty nice in the pics. Mechanically sound. It's a 70, which for early bay buyers is less desirable than a 68 or a 71.
I prefer original paint, as it hides nothing and tells a story. Many people prefer shiny new paint, as it is shiny and new so it must be better somehow. I would guess that this bus is realistically an $8K bus. Maybe more in the eyes of a Raven who likes shiny stuff.
The fact that it has been for sale for half a year tells you something, too.
RocketSurgeon
RocketSurgeon is offline
PostPosted: Tue Feb 21, 2012 12:42 pm    Post subject: Reply with quote
Oof! $1000 westy tent
http://sacramento.craigslist.org/spo/2862447460.html
69 Westy
notchboy
notchboy is offline
PostPosted: Tue Feb 21, 2012 12:51 pm    Post subject: Reply with quote
I wonder if thats that NOS one that started out at $1200?
Jason "notchboy" Weigel
1963 Pearl White Sunroof Notch
1964 T34 S Convertible
1974 Westfalia Hardtop Campmobile
1977 Westfalia Camper pop-top
the1500club.com TS Logo
TOOB Member #5
RocketSurgeon
PostPosted: Tue Feb 21, 2012 12:59 pm    Post subject: Reply with quote
Only if rusty poles are nos!
69 Westy
notchboy
notchboy is offline
PostPosted: Tue Feb 21, 2012 1:04 pm    Post subject: Reply with quote
Thats just a relative statement Wink How rusty, rusty from what? Describe what you think is rusty? Rusted through or growth on unprotected steel caused by moisture in the air......
TOOB Member #5
PostPosted: Tue Feb 21, 2012 3:44 pm    Post subject: Reply with quote
VW buss tent - $1000 (placerville)
The extra s costs.
How to: Post Photos | Search
Everett Barnes - [email protected] | My VWs | My wanted ads
RocketSurgeon
PostPosted: Tue Feb 21, 2012 4:09 pm    Post subject: Reply with quote
The extra s costs.
I think that was one year only! Very Happy
69 Westy
seventyfo
seventyfo is offline
PostPosted: Wed Feb 22, 2012 7:54 am    Post subject: Reply with quote
Thanks
I don't know, doesn't really seem all that far off to me. Granted it's not a camper, still rust-free, straight and complete.
74 standard Beetle dual 40 IDF "a$$ kickin' mystery engine"
85 Vanagon GL Westy GW 2.2
78 Champagne Westy project
VDubTech
VDubTech is offline
PostPosted: Wed Feb 22, 2012 3:29 pm    Post subject: Reply with quote
This guy is out of his mind. I've cut up and scrapped several pop tops cause you can't even give them away.
http://www.thesamba.com/vw/classifieds/detail.php?id=1266807
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
Page 151 of 249
