Fltblkbaja Samba Member
Joined: June 24, 2014 Posts: 88 Location: Kelowna B.C
Posted: Sat Aug 16, 2014 4:44 pm Post subject: Replacement cv boots |
Anyone have a good place to get replacement cv boots. The type that bolt up over the cv in place? |
Posted: Sat Aug 16, 2014 4:46 pm Post subject: |
I haven't dealt with my CV's yet, so I'm also wondering how I tell what ones I have I guess I'll have to see if I can pull a number off of them somewhere. |
wbrown45 Samba Member
Posted: Sat Aug 16, 2014 4:48 pm Post subject: |
I would highly recommend taking the time to remove the joint, and putting on a one piece boot. This will give you a chance to check out, and re-grease the joint, and you won't have any issues with leaks where the boot seams come together. _________________ OK Thang |
Posted: Sun Aug 17, 2014 1:03 pm Post subject: |
You're probably right, I need to replace my trany soon so I was looking for a quick fix in the mean while. My reverse gear is basically gone |
Brian Samba Moderator
Posted: Sun Aug 17, 2014 1:26 pm Post subject: |
wbrown45 wrote: |
I would highly recommend taking the time to remove the joint, and putting on a one piece boot. This will give you a chance to check out, and re-grease the joint, and you won't have any issues with leaks where the boot seams come together. |
For swing axles, yes.
For IRS, I don't think they make split boots. New ones aren't great as the quality of the rubber has gone down. Get some EMPI axles from rockauto.com
I got two complete assemblies for $100 _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Sun Aug 17, 2014 2:45 pm Post subject: |
Brian wrote: |
wbrown45 wrote: |
I got two complete assemblies for $100 |
Thankfully I haven't seen the split boots for IRS either, but there are so many "snake oil," quick fix products that I wanted to cover all bases. Those axles are a smoking deal! I love Rock Auto. _________________ OK Thang |
Posted: Sun Aug 17, 2014 2:50 pm Post subject: |
Alright I'm with you guys, the boots are shot so I'll replace them when I can. Thanks |
