Jay83p Samba Member
Posted: Sat Mar 21, 2020 12:55 pm Post subject: Brakes - need help! |
Hi all, my first post and hoping you guys might be able to help. I have the spindles on my car and want to fit 5x205 wheels.....I can’t seem to find a kit. Any idea on my options?
Mos6502 Samba Member
Posted: Sat Mar 21, 2020 1:17 pm Post subject: Re: Brakes - need help! |
We need a little a more info. I'm not even sure what you're asking for? You want to fit the old five lug wheels to a car with strut suspension? |
Jay83p Samba Member
Posted: Sat Mar 21, 2020 1:25 pm Post subject: Re: Brakes - need help! |
Yes that’s correct, they are fitted on a Porsche 550 replica with what I believe is 1302 brakes...drums on the rear and discs on the front. I would like to go discs all round with 5 lug wheels. Basically looking to match the original 550 look |
vwoldbug Samba Member
Posted: Sat Mar 21, 2020 5:15 pm Post subject: Re: Brakes - need help! |
Does it have strut front suspension , can we see a picture. |
Jay83p Samba Member
Posted: Sat Mar 21, 2020 6:17 pm Post subject: Re: Brakes - need help! |
its a pretty tight squeeze in there but hopefully you can make something out from these...
Joined: August 31, 2013 Posts: 12848 Location: North Carolina
Posted: Sun Mar 22, 2020 2:37 am Post subject: Re: Brakes - need help! |
That’s an intriguing re-engineering using some stock pieces, good luck replacing that upper balljoint. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Jay83p Samba Member
Posted: Sun Mar 22, 2020 3:43 am Post subject: Re: Brakes - need help! |
Yep that’s my struggle...considering stripping the whole lot and starting again |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Sun Mar 22, 2020 7:35 am Post subject: Re: Brakes - need help! |
There are 4x130mm to 5x205mm adaptors that might work.
You can probably find them in the UK but here is what they look like and one source...
https://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D6709 _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
