Nevada Notch Samba Member
Joined: May 02, 2005 Posts: 540 Location: Carson City Nevada
Posted: Mon Sep 22, 2008 11:22 am Post subject: Power Steering Reservoir |
Where in hells name is the power steering reservoir for an 89 Cabriolet? I believe the power steering unit on my newly acquired car has a leak and I need to check the fluid level. |
mike yapps Samba Member
Posted: Mon Sep 22, 2008 3:55 pm Post subject: |
Should be right next to the battery, I believe. |
Posted: Mon Sep 22, 2008 4:02 pm Post subject: |
I looked and didn't see it but I'll look again! |
Posted: Wed Sep 24, 2008 3:42 am Post subject: |
I forgot that the cabbies are different. I think it's next to the radiator on the passenger side. |
kamzcab86 Samba Moderator
Posted: Wed Sep 24, 2008 3:47 pm Post subject: |
mike yapps wrote: |
That is correct, provided the Cabriolet in question even has power steering. _________________ ~Kamz
2016 Golf GTI S
Posted: Wed Sep 24, 2008 4:31 pm Post subject: |
If that is the reservoir for the power steering, where do you add transmission fluid? I thought that one was for the transmission! |
Posted: Wed Sep 24, 2008 6:08 pm Post subject: |
Automatic or Manual? |
Posted: Thu Sep 25, 2008 7:28 am Post subject: |
Automatic! |
Posted: Thu Sep 25, 2008 5:35 pm Post subject: |
It should have a dipstick on that model. If so, fluid goes in there. |
codycat Samba Member
Joined: July 18, 2006 Posts: 1163 Location: Mobile, Alabama
Posted: Sun Apr 26, 2015 8:01 am Post subject: |
i cannot get the lid off this reservoir - seems wont turn either direction
is this my issue if when turning the wheel is making a squeal sound when turning ?? also - what type of fluid is recommended? which hydraulic fluid is best to use ?? manual does not state what to use _________________ Did you ever stop to think, and forget to start again?
Winnie the Pooh
Sometimes the questions are complicated and the answers are simple.
Dr. Seuss |
