Mexicant Samba Member
Joined: December 31, 2010 Posts: 99 Location: Colorado
Posted: Sat Dec 21, 2013 1:23 pm Post subject: |
Finally got the 67 registered and road ready.
LyonMan Samba Member
Posted: Fri Dec 27, 2013 10:16 pm Post subject: |
Here is my 1965 Baja the 'Gray Racer' restored with my kids over the last few years. I wanted a modern car that I could daily drive comfortably. This baja has IRS, 2387 cc motor, bus trans, fuel injection (Megasquirt), air conditioning, gas heater, long travel front beam, 27mm torsion bars, cutting brakes and much more.
[/img] |
tobiism Samba Member
Joined: January 21, 2004 Posts: 502 Location: Chandler AZ
Posted: Sat Dec 28, 2013 5:02 pm Post subject: |
Nice job dude, looks great!!!!!
Mexicant wrote: |
_________________ "There has never been a genius without a hint of madness."
-Albert Einstein |
HOTMOPR Samba Member
Joined: December 14, 2013 Posts: 72 Location: Rochester, Wa
Posted: Mon Dec 30, 2013 10:39 pm Post subject: |
Heres my new project I got a couple weeks ago,,
I have a roof rack for it I plan on mounting a few lights to it. I am trying to figure out what color to paint it. Leaning towards the same dark blue and then bed liner on the fenders and lower nose piece. Also a bigger front tire. Probably a 215/75/15 BFG mud terrain km2.. Gotta get some heat going in it too!! |
greggearhead Samba Member
Joined: June 20, 2004 Posts: 563 Location: Colorado Springs, CO
Posted: Tue Dec 31, 2013 10:40 am Post subject: |
As I trailered it home after sitting for a long, long time in Wyoming.
Yes, that's a Buick 215 V8 in the back.
Pulled the 356 brakes off, put all new VW brakes, hoses and wheel bearings on, installed some seats and harness belts, relocated the Porsche 914 steering rack to get rid of some bump steer, added shock mounts to the 3x3 arms, sealed up the shock holes in the body, etc etc. Added a Porsch 924 Speedo, already had an 091 trans - added a NEW 1800 (74 x 8 mini stroker with a single Weber 40 and it was ready to go! Sold, BTW - went to Utah. Liked having it, though...
Pre-compound:
Mid process:
All done:
_________________ 1972 Porsche 911E
1973 VW 412
1984 VW Doka
1991 Vanagon Syncro Westy
Period Lights, VW & Porsche wheels and Recaro/Scheel Seats for sale
https://www.facebook.com/greggearhead
http://greggearhead.com/soco-swap---september-vw-swap-meet.html |
brs1997 Samba Member
Posted: Sun Jan 05, 2014 9:19 pm Post subject: |
SMN Samba Member
Joined: October 27, 2009 Posts: 37 Location: St. Louis
Posted: Sat Jan 11, 2014 8:25 pm Post subject: Installed winch;) |
dustymojave Samba Member
Posted: Wed Jan 15, 2014 3:32 pm Post subject: |
HOTMOPR wrote: |
I like the paint treatment on the wheels. Took a bit of work to mask those. Did you do it? Or did the PO?
HOTMOPR wrote: |
... Also a bigger front tire. Probably a 215/75/15 BFG mud terrain km2.. |
That should be a good choice!
HOTMOPR wrote: |
Does it have heater boxes? I have them on mine. The factory style slip joints where the header meets the heater box exhaust tube end tends to slip and leak constantly.So I put the headers on the car with a pair of 2-bolt flanges on each of the heater box ends, weld flanges to the flared end on the headers, and weld the other pair to the heater boxes. It self jigs on the exhaust tube. I don't use gaskets between the flanges as they allow movement that then lets the bolts come loose. The slip joints have a lot of overlap anyway. _________________ Richard
SoCalBajas Member
cjward22 Samba Member
Joined: January 18, 2014 Posts: 24 Location: puyallup, Washington state
Posted: Sat Jan 18, 2014 11:34 pm Post subject: |
hay new to the site and just looking for some opinions and some feed back on what to do next! I traded my chevy wheeler for this thing as a body and have had to much fun toying around on it.
[/img] |
Posted: Sun Jan 19, 2014 12:49 am Post subject: |
dustymojave wrote: |
HOTMOPR wrote: |
Does it have heater boxes? I have them on mine. The factory style slip joints where the header meets the heater box exhaust tube end tends to slip and leak constantly.So I put the headers on the car with a pair of 2-bolt flanges on each of the heater box ends, weld flanges to the flared end on the headers, and weld the other pair to the heater boxes. It self jigs on the exhaust tube. I don't use gaskets between the flanges as they allow movement that then lets the bolts come loose. The slip joints have a lot of overlap anyway. |
The wheels were done that way when I got it. Wheels are a little different than other wagon wheels Ive seen. These have tiny recesses around the triangles. they are about 3/8" wide.. For tires I ended up getting BFG all terrains in the 215/75. It doesn't have heater boxes the exhaust goes up high behing the spark plugs. Ive been trying to snag a gas heater for it but they are either really spendy or junk. Not much in the middle of the road stuff |
Hamsterben Samba Member
Joined: December 05, 2011 Posts: 238 Location: Kooskia Idaho
Posted: Sun Jan 19, 2014 8:48 pm Post subject: |
Rebuilt the entire turbo setup today got it running a whole lot better and looks better now. Oh and I hit a tree the other day. |
profile6 Samba Member
Joined: February 03, 2014 Posts: 4 Location: Bakersfield, CA
Posted: Mon Feb 03, 2014 3:19 pm Post subject: California City. |
1 trip down, 5 more to go!
taylor5081 Samba Member
Joined: September 19, 2011 Posts: 9 Location: Hesperia CA
Posted: Tue Feb 11, 2014 12:53 am Post subject: |
I just picked my baja up about 3 weeks ago |
68ohiobug Samba Member
Joined: October 26, 2012 Posts: 150 Location: Southeast Ohio
Posted: Tue Feb 11, 2014 9:13 pm Post subject: |
Great job, that looks awesome on those sprintstars!!! _________________ "There has never been a genius without a hint of madness."
-Albert Einstein |
BUGGUTZ Samba Member
Joined: March 13, 2007 Posts: 537 Location: Luzerne Mich
Posted: Wed Feb 12, 2014 6:26 pm Post subject: |
Hey taylor5081 sweet baja. How about some more pics and info on that ride? |
Posted: Thu Feb 13, 2014 12:01 am Post subject: |
BUGGUTZ wrote: |
Thank you it has a 6" over beam, longer trailing arms, combo spindles, king coilovers, 3x3's 2165cc.
scubaaron Samba Member
Posted: Thu Feb 13, 2014 3:22 am Post subject: |
Just picked this up this week...had bad brakes but what "new" project not come with issues? Ha ha, second Type 1 but first baja...
[/img]
1776cc
74 Bus Tranny
2.5 in raised spindles
3 in body lift
31 in tires
Pop up sunroof
Overall, pretty clean and solid. |
craigman Samba Member
Posted: Fri Feb 14, 2014 8:26 am Post subject: |
Looks like fun to me! |
