Show off your BAJA!
Page: Previous  1, 2, 3 ... 58, 59, 60 ... 71, 72, 73  Next
svs
svs is offline
PostPosted: Thu Oct 09, 2014 8:38 am    Post subject: Reply with quote
dustymojave wrote:
Dude! A different looking Schwimmwagen!
I like how you've pieced together a couple of rear bumpers to make that one. A friend of mine has one kinda similar.
That rear Bumper originally was used with a Single Carb set up. The upper support arms went to the rear firewall around the shroud, When I went to dual carbs I needed to use a different rear bumper or modify the one I had.
I bought a different rear bumper and did not like it, returned it and had the Fabricator I use modify the existing bumper to mount to the shock towers. Used the "ideas" from different set ups to Frankenstein the original bumper I had.
The original bumper mounted to the Cross Bar that connected the rear C-Pillars of the Cage at the firewall, was a more secure set-up..
Modified it to go around the Carbs..
dustymojave
dustymojave is offline
PostPosted: Thu Oct 09, 2014 11:54 am    Post subject: Reply with quote
Damned dual carbs anyway!!!!!!!
Laughing
Been there, rode that horse...
Your single carb setup was using basically the same air filter setup I used on my 58 Baja most all of you have seen many times way back when it was a full body car with the original 36hp engine, The only difference being that I used Filtron oiled foam "sock" air filters. I still have the PVC Tee and the filter screens somewhere in my archives of old VW parts. It worked great.
But if I ran the engine, then took off the air filter tee, it would be wet with fuel spray. I decided that if I did that setup again, I would add a little height under the tee, comparable to the height of inside the top of the stock oil bath air cleaner. It's related to what is known as "reversion wave standoff". That is a reverse direction pulse wave in the intake flow from the intake flow getting stopped by the intake valve closing. There is one pulse for each cylinder in the 4-stroke firing cycle. All 4-stroke engines experience this. Not all engines is it noticeable. It shows up in the VW due to a combination of factors including the 1-into-4 intake and the valve size and cam grind.
But enough of all that. I like your Bug.
Richard
SoCalBajas Member
ponyboy88
ponyboy88 is offline
PostPosted: Fri Oct 17, 2014 4:31 pm    Post subject: Reply with quote
New Decals/Lost Another Headlight Ring
JimJonkers
JimJonkers is offline
PostPosted: Fri Oct 24, 2014 1:06 am    Post subject: Reply with quote
Recently purchased this 69er, all the hard work done by previous owner...2074cc, 4 wheel discs, more of an on-roader than off, but great for a spin along the local beach or river bed. Plans include a roof rack and some spots, and maybe a bit more ground clearance.
joker65
joker65 is offline
PostPosted: Fri Oct 24, 2014 7:55 pm    Post subject: here's my retired class 5-1600 car Reply with quote
balczo robert
balczo robert is offline
PostPosted: Fri Oct 31, 2014 4:05 am    Post subject: Registration Reply with quote
Hello! I bought a Baja from California, and got the papers. Only this one. In Germany need to registration and need to know how it works in California!? The fiber body mods, the wide rims or the ID. Any othe registration form or possible to make it?
[img]https://plus.google.com/u/0/photos/101829364499342138293/albums/6072176435882984241/6075331640011251938?pid=6075331640011251938&oid=101829364499342138293[/img]
[img]https://plus.google.com/u/0/photos/101829364499342138293/albums/6072176435882984241/6072176506326875218?pid=6072176506326875218&oid=101829364499342138293[/img]
KrAzY-BaJa
KrAzY-BaJa is offline
PostPosted: Fri Oct 31, 2014 7:43 am    Post subject: Reply with quote
its still a vw bug, just different finders and tires. which is hardly a "mod" because you can simply reinstall factory bolt on parts.
almost all "bajas/rails are beetles on registration paperwork
70% of what you buy is something to start with.
ForYotaWagen: A Ford/Toyota/Volkswagen http://www.thesamba.com/vw/forum/viewtopic.php?p=4871576&highlight=#4871576
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Sat Nov 08, 2014 10:28 pm    Post subject: Reply with quote
I did a photoshoot with a 1968 Baja this morning for an upcoming issue of Aircooled Classics Magazine.
I figured I would share it here. Very Happy
Stranded by Eric Arnold Photography, on Flickr
Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page.
vice87
vice87 is offline
PostPosted: Fri Nov 21, 2014 4:55 am    Post subject: Reply with quote
just thumbed through all 60 pages and will have to again because I only caught half the pics. amazing rides! gives me lots of ideas for my new project I just picked up with my dad. (I posted a thread but deleted it)
a '74 that someone started and then quit after the bumpers:
my 2nd bug, my dads 4th. it's all wrapped and tarped until spring or maybe to the shop. priority list is tear through the powertrain to get it running top notch, brakes, suspension, new wheels and tires, and interior restoration. and convince my dad to replace the fenders. then the rest is game. the street to offroad ratio will be bout 80/20 so lifting is at the bottom.
sloboatnova
sloboatnova is offline
PostPosted: Fri Nov 21, 2014 7:23 am    Post subject: Reply with quote
If you lift it now, it may be easier to work on and get under it. wink wink nudge nudge
Ms Hoover, I glued my head to my shoulder.
3BT Baja build page
http://www.thesamba.com/vw/forum/viewtopic.php?t=417564&highlight=3bt+baja
vice87
vice87 is offline
PostPosted: Sat Nov 22, 2014 12:23 am    Post subject: Reply with quote
hmmm.
hmmmmmmmmm.
Think (best thinking smiley I could find)
I like your logic.
60 baja
60 baja is offline
PostPosted: Sun Nov 30, 2014 2:46 pm    Post subject: Reply with quote
Here are a couple pics of my baja, now that i have been posting for a while.
[img]
[/img]
[img]
[/img]
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Thu Dec 18, 2014 11:30 am    Post subject: Reply with quote
Another view of this beauty:
Baja Beauty by Eric Arnold Photography, on Flickr
Eric
KrAzY-BaJa
PostPosted: Sun Jan 04, 2015 12:49 pm    Post subject: Reply with quote
Newyears outing Cool
Matt Wilson
Matt Wilson is offline
PostPosted: Sun Jan 04, 2015 5:52 pm    Post subject: Reply with quote
1972 Standard Beetle
1969 Baja Beetle
twowheeletex
twowheeletex is offline
PostPosted: Thu Jan 08, 2015 11:05 am    Post subject: Reply with quote
Here is mine. the only pic of it I have before it went under the knife to get a new powerplant is when it was stuck in the sand.
My Build Thread:
http://www.shoptalkforums.com/viewtopic.php?f=28&t=146218
marcelo cenora
marcelo cenora is offline
PostPosted: Wed Jan 14, 2015 4:50 pm    Post subject: Orange rides again. Reply with quote
kingkongslie
kingkongslie is offline
PostPosted: Tue Jan 20, 2015 8:25 pm    Post subject: Reply with quote
My Baja project. I started with a stock 1970 bug. Work in progress... All steel body. This afternoon I took it out to Cinder Hills off road riding grounds Flagstaff, AZ (0.1 miles from my house)!
KrAzY-BaJa
PostPosted: Tue Jan 20, 2015 10:01 pm    Post subject: Reply with quote
evening drive, not into ice that much Rolling Eyes
lmw
lmw is offline
PostPosted: Mon Feb 23, 2015 7:58 am    Post subject: 76 Baja named Herpie Reply with quote
New to VW's in general but lovin my new 76 Baja project car
Page 59 of 73
