guzzirider Samba Member
Joined: May 01, 2005 Posts: 107 Location: Durango CO at last
Posted: Sat Oct 18, 2008 9:59 pm Post subject: 914 rack and pinion steering in a 74 standard bug |
I have left over 914 steering rack. How big of a pain would this be to put in my 74 bug?? |
Mark33563 Samba Member
Joined: November 13, 2005 Posts: 1667 Location: Tampa Bay. FL
Posted: Sun Oct 19, 2008 12:02 pm Post subject: Re: 914 rack and pinion steering in a 74 standard bug |
guzzirider wrote: |
I have often thought of performing the same change that you are thinking about.
If I remember correctly, the bottom of the gas tank is in the way unless you offset it towards the driver's side. But that would screw up the geometry. But them I was thnking of mouning the rack up close to the fire wall, similar to how it is in a 914. Perhaps placing it closer to the beam would solve the conflict. I never really got too deep into it. _________________ -—--------—-------
"That's an ultra-rare Dung Beetle... in reverse, it rolls up giant balls of crap. " - Dave24 |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sun Oct 19, 2008 1:30 pm Post subject: |
Why?? _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Sun Oct 19, 2008 2:07 pm Post subject: why not |
Rack and Pinion steering, with more direct feed back |
Posted: Sun Oct 19, 2008 5:05 pm Post subject: |
Why have a car that several million other people have?
The task at hand:
A R&P system would complicate things, that is the main reason I have not done it. Just on a cursury level, the area where there steering wheel assembly would bolt to would need reinforcing, then there is the routing and custom fabricating of the steering column (u-joints, rods, etc.), then the fabricating of a mounting system for the rack itself...... _________________ -—--------—-------
clay ford Samba Member
Joined: July 21, 2008 Posts: 1120 Location: Cheyenne, wy
Posted: Sun Oct 19, 2008 6:57 pm Post subject: |
that would be cool you could by an after market tank that is cylindrical that wont get in the way . |
fastinradford Samba Member
Joined: June 08, 2008 Posts: 2895 Location: Athens Ohio
Posted: Sun Oct 19, 2008 9:32 pm Post subject: |
209slushee209 wrote: |
You can buy them anywhere, it's called a steel drum, they're cheap too. |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Fri Dec 26, 2008 9:47 pm Post subject: |
Company offering rack & pinion steering for Beetles...
http://www.classic-centrum.de/Kaefer_Lenkung_1.htm
Of course, I only speak Engrish...
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Fattie I'd roll it
Joined: November 27, 2005 Posts: 5582 Location: louisiana
Posted: Fri Dec 26, 2008 11:16 pm Post subject: |
sweet
_________________ Donate and help me get another aircooled dub to share with you guys www.paypal.me/WhosCare |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17285 Location: Left coast, Canada
Posted: Fri Dec 26, 2008 11:17 pm Post subject: |
This is the way to go:
A huge benefit is the increased length of the left tie rod. This reduces bump steer significantly. _________________
Posted: Sat Dec 27, 2008 5:51 pm Post subject: is there an us out let for these |
is there a us distributor for this? _________________ 69 doublecab with 2" lift
Suzuki DR650
2016 Dodge Crew 1500 4x4 |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76908 Location: Sneaking up behind you
rzepko6194 Samba Member
Posted: Sun Dec 28, 2008 4:43 pm Post subject: |
Babel fish translation of website:
a steering rack kit for VOLKSWAGEN, developed again on the market, offers beetles and Kamann Gia with ball joint axle. This Lekungskit can be blocked also with vehicles with clevis pin axle. Our appraisal is valid only for vehicles with ball joint axle. An entry by single decrease is possible by our enterprise. This kit offers the advantage of a lighter, more stable steering element. By the same long tie rods it comes to a better stability with Lenkmanöver.Der kit completely with tie rods, TÜV appraisal and detailed fitting instruction is supplied and can also of a non-specialist be very well blocked. The steering column must be in-shortened, in order to weld an admission for an universal joint. This can be usually taken over in the context of the service of us, if you send us your developed steering column. This service is in the price inbegiffen, it results jediglich forwarding expenses for the customer, if the steering column is dispatched at us. We take over the back transmission costs. The Umschweissarbeiten should be taken over in any case of a framework place, if you do not want to take our service in Ansruch, then the necessary part in the kit is directly provided. Operating range: Fz. - Type 11 all vehicles starting from Id.Nr: 11600001 beetles Fz. - Typ14 all vehicles starting from Id.Nr: 147000001 Karmann Technical consultation and installation assistance ask only by telephone under: 06825/45511 Mr. Huwig or Mr. Zimmer.
What the hell is an "Umschweissarbeiten"?
JP |
gregthomas Samba Member
Joined: March 24, 2008 Posts: 927 Location: Big Blue Nation
Posted: Sun Dec 28, 2008 7:26 pm Post subject: |
rzepko6194 wrote: |
What the hell is an "Umschweissarbeiten"? :roll:JP |
Best I can come up with... schweiss arbeiten -- welding work _________________ Checkout my church's website: http://www.ebcky.com
We offer podcasts of Sunday Sermons, articles and more! |
Posted: Sun Dec 28, 2008 8:24 pm Post subject: |
That should not be had to reproduce (famous last words) or create. They are just using one end of the rack.
Looks like Super Beetle tie rods.
Interesting. _________________ -—--------—-------
Bruce Samba Member
Posted: Sun Dec 28, 2008 11:44 pm Post subject: |
I'd like to know what car that rack comes from. Anyone recognise it? _________________
Posted: Mon Dec 29, 2008 6:23 am Post subject: |
Bruce wrote: |
I'd like to know what car that rack comes from. Anyone recognise it? |
It sort of looks like a Pinto/Mustang II rack with the driver side cut down. _________________ -—--------—-------
Bruce Samba Member
Posted: Thu Jan 01, 2009 12:22 am Post subject: |
Forget the Super Beetle rack, it won't work.
The little arms on the spindles of a Super are ahead of the axle centerline, not behind. A Super rack would make the wheels steer the wrong direction when you turn the steering wheel. _________________
Posted: Fri Jan 02, 2009 6:59 pm Post subject: |
Bruce wrote: |
The little arms on the spindles of a Super are ahead of the axle centerline, not behind. A Super rack would make the wheels steer the wrong direction when you turn the steering wheel. |
Phhhhsssshhh! It would just make the driving more exciting...
