Speedwell BRM center caps?
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
vweddie
vweddie is offline
PostPosted: Thu Oct 23, 2008 10:05 am    Post subject: Speedwell BRM center caps? Reply with quote
Does anyone know where to get the large S speedwell center cap for BRM's? I've seen them on a few cars, but can't find where to get them.
Thanks for any help.
T.B.D.
79 El Camino
12 Scion Tc
PIMPPRIDE
PIMPPRIDE is offline
PostPosted: Wed Oct 29, 2008 2:21 pm    Post subject: Reply with quote
our billet BRM center caps like this?
here is the link to the add here on samba...
Anthony / ISP WEST
http://www.thesamba.com/vw/classifieds/detail.php?id=466946
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Facebook Twitter Gallery Classifieds Feedback
vweddie
vweddie is offline
PostPosted: Wed Oct 29, 2008 2:37 pm    Post subject: Reply with quote
Do you guys have any that aren't billet?
T.B.D.
79 El Camino
12 Scion Tc
Stuggi
Stuggi is offline
PostPosted: Fri Oct 31, 2008 1:15 am    Post subject: Reply with quote
What's wrong with billet?
Orange Bug 1970 Beetle
Green Bay Bus 1969 Panelvan
Orange VW Fest!
Pulled out of a Lake Fest!
vweddie
vweddie is offline
PostPosted: Fri Oct 31, 2008 3:09 am    Post subject: Reply with quote
Just figured if they weren't billet they would be cheaper. But if thats all I can find then I guess thats what I'll get.
T.B.D.
79 El Camino
12 Scion Tc
Stuggi
Stuggi is offline
PostPosted: Sat Nov 01, 2008 1:52 pm    Post subject: Reply with quote
Billet is usually easier for smaller shops to do since you don't need to bother about castings that still would need machining. And the tooling is cheaper than die-pressed plate.
Orange VW Fest!
alikatcraig
alikatcraig is offline
PostPosted: Tue Nov 11, 2008 8:43 pm    Post subject: Reply with quote
FAT Performance in Orange, CA used to sell good copies of the pressed original caps, and may still do. Give them a call.
Al
1967 Ghia
1971 Deluxe Microbus
1974 Convertible Bug
1973 Standard Bug
1998 Mexican Bug
Stevo Wide 5
Stevo Wide 5 is offline
PostPosted: Fri Jan 09, 2015 12:02 pm    Post subject: Reply with quote
Would these clear the end cap on earlier beams?
My original caps don't fit right especially the drivers side with the odometer cable thru it as well!
So i'd like to run these if they would fit with the cable thru it!
Anyone an idea???
62 Type 3 Notchback
Check out my Aircooled blog @ http://stevo.skyblogs.be
Wide 5 Vintage Volkswagen Club
http://www.wide5.com
Split 1
Split 1 is offline
PostPosted: Thu Apr 02, 2015 7:25 pm    Post subject: Reply with quote
Having the same problem, the fronts dont fit if you run linkpin front end.
Who else makes ones that will fit?
Thanks
JohnnyEuro
JohnnyEuro is offline
PostPosted: Mon May 18, 2015 10:47 am    Post subject: Reply with quote
Same here, having an issue fitting the cap on the front left.
As a product designer it might be a good idea to add maybe another mil more of material out at the center of the caps - so adjust the outer profile. Then take one cap and machine the inside center in another 2mm for clearance.
Most of us don't have a lathe and these caps are expensive to have to take a Dremel tool to it. I'll have the one "shaved" in by tonight but it's a pain in the arse!
Not as big a deal, just more time consuming - again customer experience is important - I know it may be easier for assembling and getting out the door faster but it'd be nice if I didn't have to take all 3 threaded posts out, have to flip them, then turn 'em back in. This is a minor nit pick though.
Make them fit for all the cars=better product and customer service Smile
Other than that I love them. Would still recommend them.
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
