metoooo Samba Member
Posted: Thu Jan 26, 2017 9:13 am Post subject: Engine case insert missing |
Hi,
while take my enigne out I've noticed that the top left engine to trans bolt, doesn't have the insert that is fixed to the engine case.
Is it possible to implant new insert there ? If so, where can I get replacement insert? |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13842 Location: White Mountains Arizona
Posted: Thu Jan 26, 2017 9:34 am Post subject: Re: Engine case insert missing |
Yes you can redo the insert. Not sure where to obtain one. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33875 Location: Conejo Valley, CA
Posted: Thu Jan 26, 2017 10:23 am Post subject: Re: Engine case insert missing |
What year is your car, or more specifically, what year/type is your engine? The top left insert was added when VW went to the doghouse oil cooler in about 1971, because you could no longer get at the nut. Earlier engines had no interference from the shroud/cooler, and so used a conventional nut and bolt. |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Fri Jan 27, 2017 10:34 am Post subject: Re: Engine case insert missing |
Thanks for the link!
My case is D , 1200cc but with dual relif valves. |
mark tucker Samba Member
Posted: Fri Jan 27, 2017 10:36 am Post subject: Re: Engine case insert missing |
I got new ones from one of the std vw stores....possiably cb perf, there was somebody in the classified selling used ones. |
