glutamodo The Android
Joined: July 13, 2004 Posts: 26323 Location: Douglas, WY
Posted: Thu Nov 18, 2010 9:04 pm Post subject: |
I've heard of people using a giant Viton O-ring for to keep jugs centered, but I think that was on the case side if you use a 1200 cylinder in a later case. On the head-end, I think the heat would just be too much over the long term for that to be reliable. A metal sleeve spacer that is a good tight fit over the end of the jug, now that might be good, I can't remember if I've heard of someone talking about that before. |
fiveohnick Samba Member
Joined: June 23, 2009 Posts: 37 Location: Napa valley
Posted: Fri Nov 19, 2010 7:55 am Post subject: |
I think what you have to find out first is if the combustion chamber of the DP head is wider than the 40 hp cylinder. If its wider then I think you would have to face the 40 hp jug (head end) a bit, then machine a steel ring with a step (to take up what you faced off) that presses on to the jug. This would allow the head to "think" its getting a 1600 cylinder but in fact its a 1200 with a wider face/contact surface. I wish I had some pics to show right now
If the combustion chamber is fine then all you need to do is make a aluminum ring the presses into the head that makes it the size of the 40 hp jug.
Im sure its been done as the world has had the better part of 50 years to try it out |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Fri Nov 19, 2010 9:45 am Post subject: |
OB Bus wrote: |
glutamodo wrote: |
fiveohnick wrote: |
But since I built that 1776 I often wondered If you could machine some rings to take up the difference in a 1600 DP head so the 40 hp juggs fit in?? A set of stock 1600 DP heads would probably run great with or without dual carbs. |
Actually, I was thinking - really all you need is to keep the cylinders from floating around - why not just get the cylinder opening welded up at three points, then machined/centered to the size of the 40HP cylinder... |
At some point in the last year (two?) someone in this forum had a write up about using 1600 heads on a 40 horse. I could not find it, maybe someone who is better at searching?
**edited for accuracy... |
That would be me. That engine only has about 20 minutes run time on it, but it is currently installed in a kit car. I should have it up and driving in the next month or so.
Video can be seen here:
touchdowntodd Samba Member
Joined: April 13, 2009 Posts: 283 Location: milwaukee
Posted: Sun Dec 05, 2010 3:22 pm Post subject: |
id love dual carbs for my 1200 if a new kit existed _________________ mine - '65 6vt 40hp, 5.5" beam, Spindles, BRMs, etc
project with dad - '62 pan'd manx copy body 6vt 40hp.. |
CLASSIC CAR GUY Transport and Title Guru
Joined: August 09, 2010 Posts: 1608 Location: Phoenix AZ, but originally from Long Island NY
Posted: Mon Dec 06, 2010 3:28 pm Post subject: |
touchdowntodd wrote: |
id love dual carbs for my 1200 if a new kit existed |
build it!!, thats what im doing its not rocket science, im currently building a 1385cc with dual 28 pict's, for my 64' T-1 built a pair of manifolds and using a Scat push pull linkage, is eas pretty simple to do!! Honestly if sombdy tooled up to fab 40hp dual intakes they could be sol ans there would be a small demand for them i think for the vintage speed guys _________________ (0\!/0)
58' Rag'
60' Type 1
61' Type 1
62' Type 1
64' Type 1
66' Type 1
66' Vert'
67' Type 1
"every one wants to reinvent the wheel, but nobody knows how to make it round"
Vintage Volkswagen Sales and Service as well as Classics and Muslcecars all located here in Phoenix Arizona at www.rpmotorcars.com |
Posted: Mon Dec 06, 2010 3:40 pm Post subject: |
id love to make one, but im no good with a welder...
i can figure out the rest.. but tahts what holds me back the most _________________ mine - '65 6vt 40hp, 5.5" beam, Spindles, BRMs, etc
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Mon Dec 06, 2010 4:32 pm Post subject: |
i can figure out the rest.. but tahts what holds me back the most |
Get a welder, and practice, practice, practice. That is what gets you to Carnegie Hall. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Mon Dec 06, 2010 4:36 pm Post subject: |
Heres a idea, as for the manifold whih is what will need to be welded if you can fab a nice set out of 2 stock 40hp manifolds which is what i did, if you can get the tubes cut and fitted the way you want and just tack them in place, then bring it to a pro welder to weld up for a few bucks, a buddy of mine cant weld eiether, so when he makes something he'll tack it all inplace then call me to come over and lay the bead down..lol i tell him all the time just pratice and do it, he's like "why when i can have you do it",,,lol _________________ (0\!/0)
58' Rag'
60' Type 1
61' Type 1
62' Type 1
64' Type 1
66' Type 1
66' Vert'
67' Type 1
skyto Samba Member
Joined: November 24, 2003 Posts: 177 Location: Finland
Posted: Thu Dec 30, 2010 12:05 am Post subject: |
eurodub wrote: |
sorry to dig up this thread.. can anyone explain what is the best jetting for a stock 40hp with 2x28PCI's?
Book knowledge from "Jetzt mache ich ihn schneller", TDE/VAE34 setup, 2xPCI (21,5mm venturi) for stock 40hp:
Main: 110
Air: 195
Emulsion tube 8
Idle: 45
Idle air: 1,2
Accel.pump 0,3-0,5 cc
"because of engine differences, some minor changes might be needed with main and air jets " |
skyto Samba Member
Posted: Thu Apr 14, 2011 8:25 am Post subject: |
nice site, thanks for the link!! _________________ (0\!/0)
58' Rag'
60' Type 1
61' Type 1
62' Type 1
64' Type 1
66' Type 1
66' Vert'
67' Type 1
36hplandspeedracer Samba Member
Joined: January 30, 2006 Posts: 847 Location: Ivins, Utah
Posted: Thu Apr 14, 2011 9:51 am Post subject: Re: Kits and how to for dual Carbs to the 40Hp |
illombarbugz wrote: |
I know there are several kits on the market to fit the dual carbs on the 40 HP, hence I would love to make a list here of all of them including prices, with all of your help...
..as well as what adaptation are possible out of the single port ones...
..or starting with junkyard 40HP intakes, duely modified... |
Below is some history on 36hp stuff but much of the carb manufacturers also sold to 40hp owners.
Burly
36hp OLD STUFF(High Performance Equipment)
DUAL CARBURETORS . CYLINDER HEADS( 30 int 28 exh)
Speedwell Sprint(Stromberg)-EMPI Decker
Solex(28pci Solex) Fish(rebuilt)
Monaro(Austrailian)(SU sidedraft) Okrasa D/P
Wessex(32b10 Solex) Denzel D/P (38 int 28 exh)
Amal Wessex(rebuilt)
Okrasa(32pbic Solex) Aussie D/P(lateral)
Denzel(32pbi Solex) CRANKSHAFTS
Carter-JC Whitney Okrasa(69mm)=1286cc
Express(28pci)Rally Equip-Autotechnik-AG Denzel(67mm)=1281cc
OW Dietz Engineering(28pci Solex) Porsche(74mm)-used
Ken Virgin(Stromberg 1bl)(Austrailian) Weber(1/4”)=1310cc
Ken Virgin(Zenith 2bl)(Austrailian) Weber(1/2”)=1427cc
Riechert(34pci Solex) single port EMPI(also Okrasa)
Abarth(32pbic Solex) single port
Rethwish(28pci) single port
SINGLE CARBURETOR PISTONS & CYLINDERS
Solex (32pbi)(pbic w/choke) Okrasa(77mm) domed
Minnow Fish(MPG & H Engineering) Denzel(78.5mm)
Volkswagen(77mm-1966 1300cc)
w/22mm pin for stroker
FUEL INJECTION motor w/ Porsche rods
S.E.S. Porsche(80mm) w/20mm pin(36HP)
w/22mm pin(356A+)
EMPI(80mm)
INTAKE MANIFOLD RODS
Autogas Denzel
CAMSHAFTS
SUPERCHARGERS Potvin(Moon Equipment)
Pepco Isky R5T Porsche race grind
Shorrock(C75 to 1500cc) Isky 2B Road 252 Porsche grind
(C142 from 1600+cc) Isky 2J 335 duration
Judson(w/Solex 28pci) Racer Brown 15a 254 “
MAG Camshaft Eng.Co. 254 “
Paxton(EMPI) Weber Tool co. 281 “
Arnott(-Corey) Sig Erson 410 290 “
Isky 103A 325 “
Crower P-63 299 “
EXHAUST SYSTEMS Crower P-65 ?
Abarth 4 Tip Schneider 43R or 135F ?
Ernst 4 Tip Wessex (__?__)
Lukey(Austrialia)2 Tip Norris 341 SR ?
Stepa 4 Tip(Belgium) Nels Hedlund 284 “
IGNITION SYSTEMS PUBLICATIONS(Old)
Mallory Dual Point Souping the Volkswagen……..Morgan
Motorola Transistorized aka Volkswagen Technical Manual
Scintilla Magneto Making the Volkswagen Go…..Elfrink
Bosch 010/019 aka All About the Volkswagen
Judson Magneto Volkswagen Owners Service Manual…
OIL COOLERS ………………………………Abbey
Okrasa or Porsche 356 Hot Rodding the Volkswagen….. Ritch
Hot Rod Magazine..Jun 60
How to Hot Rod the VW……….Fisher
02/01/10 |
Henrip Samba Member
Joined: April 04, 2011 Posts: 42 Location: Mcbo/Venezuela
Posted: Fri Apr 15, 2011 7:57 am Post subject: |
Thanks for the link... a lot of info! I am starting a project with a pair of 30 solex for my engine. |
Howard Sanson Samba Member
Joined: October 25, 2007 Posts: 68 Location: 15 and 91 frwy
Posted: Fri Apr 15, 2011 4:27 pm Post subject: |
HOW MUCH IN US DOLLARS |
Posted: Fri Apr 15, 2011 4:30 pm Post subject: |
PLEASE some just make a kit that all us 40HP people can buy |
Posted: Fri Apr 22, 2011 6:05 am Post subject: |
AGREED _________________ mine - '65 6vt 40hp, 5.5" beam, Spindles, BRMs, etc
Posted: Fri Apr 22, 2011 9:15 am Post subject: |
Yeah, an available-in-the-USA and halfway-decently-affordable bolt-on manifolds+linkage kit would be great - be it for PCI, PICT or even ICT carbs. |
Posted: Sat Apr 23, 2011 10:07 pm Post subject: |
Yes but some one has to modife the intake manifold to 40 hp heads . Empis 34itc kit looks the best for the cost plus welding ?Making the flanges for the intake manifolds is the real part to have sub let out . |
Zarzamora Samba Member
Joined: September 07, 2006 Posts: 121 Location: you tube puppetforchrist San Antonio
Posted: Sat Oct 22, 2011 11:00 am Post subject: |
Hey Bro. I went into the site ... but my translator takes forever. could you see how much for some single port manifolds for some PDSIT Solex dual carbs that I could put on a 1600 single port motor that's going into a VW beetle? _________________ Only one life, it will soon be past, only what's done for Christ will last. |
Type1xperience Samba Member
Joined: November 04, 2011 Posts: 18 Location: Queens, New York
Posted: Fri Nov 04, 2011 3:19 am Post subject: |
Updates on the kits? |
