Clara Samba Member
Posted: Thu Jul 31, 2014 1:41 pm Post subject: |
busdaddy wrote: |
68-70, 71-72, 73-79, the main difference is the brake reservoir. |
I have these three driver side kick panels:
one with no notch for brake fluid reservoir,
one with smaller notch for brake fluid reservoir,
one with larger notch for brake fluid reservoir
I figure the no notch for brake reservoir is the later one, as the 73 I had had the reservoir under the front seat, but which is which on the ones with the notch for the reservoir?
My parts list shows the reservoir changing for ch # 219 000 001, so that implies there's a 1969 only version?
TIA! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Jul 31, 2014 3:05 pm Post subject: |
68 has the largest cutout as it used a wide flat reservoir:
69-70 has a smaller one:
71-72 has no cutout as the reservoir move to behind the seat:
73+ may have a cutout for the fuse box, I can't recall, I'll have a look.
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Clara Samba Member
Posted: Thu Jul 31, 2014 6:16 pm Post subject: |
Thank you! |
wcfvw69 Samba Purist
Posted: Thu Jul 31, 2014 8:12 pm Post subject: |
Clara, are you making some kick panels or do you currently? _________________ Contact me at [email protected]
The Samba member since 2004.
Clara Samba Member
Posted: Thu Jul 31, 2014 9:02 pm Post subject: |
Yes I am, and trying to figure out how many patterns I need to sort out. And also what to call the different patterns. Looks like I have the 69-70, and the 71-72 (71-79?)
At some point they dropped the little lever you kick up/ down for heat to defrost or foot vents, so they probably dropped the notch for that too.
I don't think 73 had that.
I'll be checking out buses at the show in Portland this weekend. |
Posted: Thu Jul 31, 2014 9:21 pm Post subject: |
73 was when the defrost changed from kick to dash control but the lever is still there, just shorter with a cable on the end, I'll look at a 73 next time I'm near one to see if the panel changed. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Jul 31, 2014 9:31 pm Post subject: |
I've seen some of your beautiful panels in other buses and would be interested in losing the cheap, ABS plastic, POS panels in my 70.
What are you making them out of? What's the final finish? I haven't seen what the originals were like. _________________ Contact me at [email protected]
RixiesRide Samba Member
Joined: August 31, 2005 Posts: 708 Location: Stockton, CA
Clara Samba Member
Posted: Fri Aug 01, 2014 7:17 am Post subject: |
busdaddy wrote: |
73 was when the defrost changed from kick to dash control but the lever is still there, just shorter with a cable on the end, I'll look at a 73 next time I'm near one to see if the panel changed. |
one with smaller notch for brake fluid reservoir (69-70?),
one with no notch for brake fluid reservoir, and notch on right side for lever that turns heat from defrost to foot vents ? Is this right?
one with no notch for brake fluid reservoir, and larger notch on right side for lever that turns heat from defrost to foot vents ? Is this right for 71-79?
Sometimes it is hard to make out the shape from the originals, as they get a bit battered.
I am not sure if the top part of the notch by the heater lever broke off for the lower pattern and it was supposed to be like the middle one, or if that lower one was really the shape. I think that lower one might be right for a 73. Rixies Ride, that would be great if you could share a picture of your 73.
These ones I made of hardboard. I haven't made bay kick panels for some years, but figured I'd start it again.
The original material is a bit more flexible. I am wondering about using a more flexy material. I was going to paint these black. Originally, the kick panels had a thin black vinyl glued one, at least most did. |
Posted: Fri Aug 01, 2014 9:30 am Post subject: |
Clara, I added the pics to the gallery but my smartphone isn't cooperating this morning so I'm only getting part of the link to copy.
It looks like your kick panel on the bottom is correct. _________________ 1973 Wild Westerner "Mr. Peabody"
1967 Beetle "Sherman"
http://s13.photobucket.com/albums/a269/RixiesRide/WW/ |
werksberg Samba Member
Joined: February 08, 2005 Posts: 2151 Location: Prescott Valley, AZ
Posted: Thu Jan 21, 2016 2:25 pm Post subject: |
wcfvw69 wrote: |
What are you making them out of? What's the final finish? I haven't seen what the originals were like. |
Good luck Clara getting those 1/8" press boards to fit the lower channels and are flexible enough to conform to the top areas....
I learn that problem back some 25 years ago when I first started making my ABS Bay window kick panels that 1/8" doesn't work well.
Some people don't understand material science on these forums.... as the .060" ABS plastic is tougher and still flexible enough to use in this applications than 1/8" press board materials. Plus easy to trim the ABS if needed (I have made and sold maybe 10K plus ABS kick panels sets and only a hand full asking about weird applications).
I do special orders of .090" thick ABS plastic kick panels for those wanting to add speakers down there...
New Bay window Bus products to be posted soon. _________________ Werksberg Products....Products that work!
Follow my new products on my Facebook Werks Berg
Click the below ADs link for products & feedback.
Search "werksberg" on Photobucket for products photos & Please remember to buy "American made products!" |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Thu Jan 21, 2016 3:08 pm Post subject: Re: all kick panels the same? |
^^^I agree
the fiber panels look like shredded wheat on the edges trying to get them in.
good luck getting any vinyl to stick
the werksburg panels are like rubber bands. twist, fold, snap, bang DONE. I love them and have used about 6 sets at this point. no chichi looking flaky ends _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Thu Jan 21, 2016 3:14 pm Post subject: Re: all kick panels the same? |
skills@eurocarsplus wrote: |
^^^I agree
the werksburg panels are like rubber bands. twist, fold, snap, bang DONE. I love them and have used about 6 sets at this point. no chichi looking flaky ends |
Thank you! _________________ Werksberg Products....Products that work!
Clara Samba Member
Posted: Thu Dec 01, 2016 8:52 am Post subject: |
Haven't kept an eye on this thread, so delayed comment here.
It's not too tricky to install these kick panels. Not sure what is meant by a lower channel... I didn't see a lower channel on a Bay window bus. Maybe that's talking about a split bus? They fit fine there. I didn't have a shredded wheat experience. Maybe if you use them as a walking stick?
If you want to upholster them you might try upholstery glue. I've done upholstered panels in full sets for split microbuses, but haven't done that with the bay buses.
Most people seem to want the more budget friendly version, and upholstered with vinyl would cost more than painted black.
What I learned about installing under dash bay kicks:
1) Put center end by heater tube in first,
2) Attach screw by heater vent but don't snug it down
3) Bend the panel so there is a bulge towards you, and fit the outer edge into the slot near the door.
4) Lift outer edge so screw holes in panel line up with screw holes in bus. A pokey thing and a flashlight helps.
5) Hold lower edge and pop bulge of panel forward.
6) Install last two screws, snug all screws
If screw holes are not pre-drilled, or you don't want to bother with the screws, ignore some of the steps.
It's not like they will fall out if you don't screw them in place. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Clara Samba Member
Posted: Thu Dec 01, 2016 9:04 am Post subject: |
I my quest to actually make all the versions of the panels rather fewer versions in the one-size-fits-all concept, I am still figuring out details.
Wouldn't mind a little help.
It seems there are *two* versions of kick panels 73-79 with the heater control on the dash. Any idea when the change below was made?
Smaller notch for the heater control:
Larger notch for the heater control:
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Thu Dec 01, 2016 3:54 pm Post subject: Re: all kick panels the same? |
Here is a factory 1978 kick panel.
It has the deep cut-out at the floor/defrost flap lever.
Colin
_________________ www.itinerant-air-cooled.com |
Hoody Samba Member
Posted: Thu Dec 01, 2016 11:56 pm Post subject: Re: all kick panels the same? |
I have recently restored my original kick panels back to like new condition. Granted I am over the top when it comes to originality. It was a nerve testing experience to say the least. I took care of the original issues of the water absorbent qualities of the press board with modern sealers and the pain staking process of sealing the edges with fiberglass resin. The backs and edges are now bullet proof from moisture. To Clara I would happily trace my original kick panels and send you the patterns. The thickness of the board and its ability to flex is the key. If I was reproducing these I would sell them bare not painted. Those of us that are hard core sticklers would have them covered in the closest available vinyl. Painting them would greatly mess up the adhesion of the vinyl. I can mic the thickness and send you patterns if you like from my 78 Westy. There are a few of us that care about such details. I am not knocking anyone's products. But for me ABS does not cut it. Let me know if I can help. |
Xevin Samba Member
Posted: Fri Dec 02, 2016 12:34 am Post subject: Re: all kick panels the same? |
Or you take me up on my offer and take my 72 or 76 panels out when I'm in Olympia and make your own patterns. You just have to put them back in _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
SGKent wrote: |
Hoody Samba Member
Posted: Fri Dec 02, 2016 3:01 am Post subject: Re: all kick panels the same? |
Is it me or is it absolutely maddening to see a post about a common question and up pops Howdy Doody plugging his products....which I have seen the samples and are fine for those that don't give a shit about originality. For the majority of the VW crowd the abs panels are the way to go.....trying to be nice here....however is there a need to bust out the my product is better then yours mentality every chance one gets to plug their product? I could be BRUTALLY honest and give my opinion as to why any Bus owner would install highly flamable engine sound deadening panels above their type 4 or type 2 engine which neither sound deaden what so ever and GREATLY increase the god forbid ensuing engine fire making a bad situation worse. Ummmm.....plastic melts and drips and is far more toxic then wood. It doesn't sound deaden anything. Perhaps you should take a class in basic physics. If your going to slam others for pursueing "original" ways of recreating parts that you peddle....it's not good form to tought your products as state of the art when in fact they rank up their with the CIPI 1 mentality that if I can sell it cheap and enough people buy my Mickey Mouse product I am in a win win. Tell me how well your ABS holds up to cold weather? Oops your kid rested his foot on it....brittle and broken. Can you affix vinyl to it....nope but bullshit will sell it. The engine sound deadening panels made out of ABS plastic are a complete fucking joke....but there is a sucker born every day. For those that's want to put speakers in their kick panels which is a terrible place to put them to begin with, and those that want to put speakers in the bottoms of their door panels.....also another terrible place to put a speaker....there are all different levels of restorers and refreshers. And there are those that believe what they read and go on price point alone. My advice to you is to not slam someone who is trying to make some money building a better mouse trap. Sorry to be so up front and harsh....but honestly since we are throwing stones....your product will do just fine for the majority of the VW crowd that just wants to fill the void. For those of us that take it seriously.....um I would rather leave the area empty and wait Til a quality near perfect piece showed up on my door. Seriously now that the gloves are off...your selling flexible textured plastic....period. The next time you
attempt to plug your products after trolling for the opportunity to do so I highly suggest you don't put down someone else who is actually making the product out of original materials....who has been doing this a loooong time before you decided you were the foremost authority on plastic....which VW NEVER used in ANY of your products. So this is a friendly heads up. If you want to stay competitive....you should never have to put down what you perceive to be competition or a threat to your business. You only end up looking like an ass. |
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Fri Dec 02, 2016 9:07 am Post subject: Re: all kick panels the same? |
☝🏻️THIS!
Also, he dug up a thread that was nearly 2 years old to bash the person, I had considered buying his product for my bus, but after seeing his response to her post, I may change my mind. That's NOT a good way to sell your product and you just come off like an ignorant asshole, whether you are or not, regardless of what your actual intention was. _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
