Dave56 Samba Member
Joined: October 01, 2008 Posts: 24 Location: Westerly RI
Posted: Mon Nov 10, 2008 5:30 pm Post subject: 16" wheels and lowered springs? |
Greetings all,
I was wondering if anyone here has any experience with lowering a 2wd Westy after installing 16" wheels and tires? Specifically any rubbing or bottoming out of the tires on the body work.
Thanks in advance for any input.
Regards
Dave |
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
Posted: Mon Nov 10, 2008 5:34 pm Post subject: |
My westy has carat springs, and I have 16X6.5" wheels, I have 195 75 16's on the wheels. If I drive over a LARGE bump with the wheel turned all the way the tire will rub the bottom of the fender lip, well, that has only happened once. _________________
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies
Samba ad here.
DIY artificial rain gutters (ARGs) |
Posted: Mon Nov 10, 2008 5:53 pm Post subject: |
jackbombay wrote: |
My westy has carat springs, and I have 16X6.5" wheels, I have 195 75 16's on the wheels. If I drive over a LARGE bump with the wheel turned all the way the tire will rub the bottom of the fender lip, well, that has only happened once. |
And that is a 27.5"(ish) tall tire. The stock tire height was/is 25.6".
Dave, tire size and wheel offset have more to do with any rubbing issues than the wheel height.
Do you plan on using Carat or H&R springs?
If you stay with a 215 or 225/60/16 on a 7" wheel with the proper offset, you should be just fine. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Mon Nov 10, 2008 5:58 pm Post subject: |
loogy wrote: |
jackbombay wrote: |
And that is a 27.5"(ish) tall tire. |
27.1" according to the manufacturer, but close enough. I have had the 16's for ~30k miles now. _________________
Samba ad here.
82WestyMan Samba Member
Joined: December 28, 2006 Posts: 1098 Location: Western OR
Posted: Mon Nov 10, 2008 6:04 pm Post subject: |
I have 16x7.5 aftermarket wheels with spacers and lugs from loogy with 225x55/16's on my 82 westy with h&r lowering springs & bilstein hd's and love it
took it fully loaded on a grand tour of the utah national parks last june and never had a problem
here's my thread on the wheels and tires
http://www.thesamba.com/vw/forum/viewtopic.php?t=281763&highlight=wheels _________________ "The floggings will continue until morale improves"
"I never did give anybody hell. I just told the truth and they thought it was hell" - Harry S. Truman
82 Westfalia - w/ a Raby 'Camper Special' engine |
Steelhead Samba Member
Joined: February 25, 2007 Posts: 1791 Location: Kentfield, CA
Posted: Tue Nov 11, 2008 12:05 am Post subject: |
Stock carat springs, maybe slightly compressed.
16x7 rims
offset =30
215/60/16 tires (26.1" tall)
No rub and I've tried to flex'm pretty hard.
_________________ '77 Bay Window / '89 Caratsburg (aka. the Stormtrooper) |
Gorge Runner Samba Member
Joined: February 24, 2008 Posts: 199 Location: Portland, OR
Posted: Tue Nov 11, 2008 10:20 am Post subject: |
I have 235/60/16 on my Carat. I get some very slight rubbing when the front suspension is fully compressed. A few months ago, I did cut off all but 1 bump stop from the shock covers--that may be the difference between rubbing or not.
Marc _________________ 91 Carat
EJ205 WRX |
Dave56 Samba Member
Posted: Wed Nov 12, 2008 8:27 am Post subject: Thanks all |
Thank you all for your input. I appreciate your willingness to share the results of your experience and expertise. I hope I can add something to the conservation some day.
Here's the specifics of what I'm thinking. This is one of the first steps of getting a '84 Westy with a 2.2 Subaru engine in it ready for use. The first step was resealing the gas tank and replacing the breather lines etc. One of the next steps will be to replace the fuel lines, the post about that was scary.
For the wheels I'm planning to use a set of Mercedes 16X7 steel, and putting 225-70-16s on them. My thinking is that a 10% increase (25.7" to 28" diameter, 734 revs/mile to 800) will give me a de facto decrease in final drive ratio. With the Subaru engine I figure it can use the reduction in revs. Then since this will increase the height of the van about an inch I was planning to put H&R springs on it that will lower it 1.5". It barely fits in the garage as it is, and this will end up lowering the van a 1/2" after all is said and done. Along with new shocks, bushings, tie rod ends, etc. I was also thinking of bigger anti sway bar in the front and maybe adding one to the rear.
With the correct spacers on the wheels (loogy I'll be in touch about that as soon as I can afford the wheels) and new bolts and drilling out the bold holes I hope this will work.
Any input from the more experienced?
Thanks again
Dave |
Posted: Wed Nov 12, 2008 11:13 am Post subject: |
Here are some pictures of my own 2wd van with Toyo Open Country A/T 225/70/R16s on 16x7 ET30 (after spacers) wheels. The specs on the tires are 28.4" tall with a 6.9" tread width.
With the wheel turned left and right to the point of minimum clearance between the body and tire, this is what you get.
A thumb and a quarter width at the rear.
Les than a pinkies width at the front.
Keep in mind that my hub center to fender lip height is 17". You can see that because of the diameter of the tire, the lower the body gets, the closer the tire will be to the front and rear fender lips, although they don't ever rub, even when turning and hitting a bump. I wouldn't want my finger in between them though as it gets pretty close.
I think that you will find that a 225/70R16 combined with H&R lowering springs, the tire will rub on the upper fender lip when traversing varying height obstacles while turning (like turning into a steep driveway) and the tire will be VERY close, if not touching, to the front fender lip while turning. Also keep in mind that less offset will make the clearance worse and all tires are different in their actual size and shape, which could make your situation much different than mine. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Dave56 Samba Member
Posted: Thu Nov 13, 2008 6:31 am Post subject: Thanks Loogy |
Thanks for the info Chris. Maybe lowering isn't the best idea. I like your setup. Do you notice reduced revs at crusing speed with it?
Regards
Dave |
a914622 Samba Member
Joined: July 29, 2004 Posts: 835 Location: Westend of HWY2 , Wash
Posted: Thu Nov 13, 2008 4:54 pm Post subject: |
Learn form my mistake!!!!!
The H&Rs are to low for a 28" tire!! Im running 17 with an offest of 25mm and 28" tires. The first time you try to turn the fronts will feel like they're beeing riped off the van. Center to lip is only 13.5 inch.
Im running Carat springs with no troubles. If Your looking for new carat springs the brickyard.uk sells them, but only in the UK. Send them an email and they will send you a contact from AVO. AVO makes and sell them. they are TUV. approved.
jcl |
