Joined: March 18, 2002 Posts: 593 Location: Peterborough, Ontario, Canada
Posted: Mon Nov 17, 2008 3:05 pm Post subject: 36hp to 12v car? |
Hey guys, wondering what I need to do to my 36hp to run it in a 12v bug or bus? Ignition wise, What about the flywheel?
Any tips on what it takes would be great! thanks! |
glutamodo The Android
Joined: July 13, 2004 Posts: 26315 Location: Douglas, WY
Posted: Mon Nov 17, 2008 3:43 pm Post subject: |
You can keep the small flywheel and a 6V starter, if the tranny is 67/newer, you just need to replace the starter bushing in the later tranny with an adapter style.
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D5766
The generator is going to be the big thing - you'll have to use the Porsche 912 style 12V 90mm-diameter generator, which is not cheap. Or find an automotive electrical rebuild expert who can re-wind your 6V generator so that it outputs 12V, (and use a 12V voltage regulator too, of course) (Either that or convert your 12V car down to 6V, but that's not a very good option either.)
The ignition, just change the coil out for a 12V version, the rest will be fine on either voltage.
-Andy |
morymob Samba Member
Posted: Mon Nov 17, 2008 5:44 pm Post subject: |
There are 2 types of 12v coils,1=has to have external ballast resistor,2nd=has ballast built in as in VW type. 6v dont need ballast. Ballast is to limit current flow thru coil so u dont fry points real quick. |
