troll77 Samba Member
Joined: July 03, 2008 Posts: 90 Location: victorville,california
Posted: Fri Nov 28, 2008 2:17 pm Post subject: judson power? |
so what will a good 36hp with a judson run like,and what other mods could be done to help with more power with the judson. |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13943 Location: Southampton U.K.
Posted: Sat Nov 29, 2008 6:24 am Post subject: Re: judson power? |
troll77 wrote: |
The most oft quoted comparison is it will output equivalent to a 1600 single port. It will run smooth a strong especially in the mid-range.
If you want more power than in stock configuration from your Judson you are asking for trouble. The vanes run in contact with the chamber and so generate friction heat as well as compression heat.
Spin the unit faster to generate more power you also generate more heat which the small heat-sink vanes on the blower body can't handle.
There are things you can do to make the Judson run cooler and more reliably but they won't necessarily make it run more powerfully.
As long as your expectations aren't too high the Judson will give years of reliable service...and most importantly, if you have one in good condition. _________________ John.
passoa55 Samba Member
Posted: Sun Nov 30, 2008 6:53 am Post subject: |
So a Judson can damaging your engine when you give to much gas? _________________ 1950 Hebmuller #458
1955 lowlight lizard green
1955 original paint oval
1956 1600 super V-sunroof Porsche
1958 lowlight ghia black
1963 firetruckred 23 window
1967 SO42 westy
1969 original paint Westy
1970 one owner 1300L bug |
Posted: Sun Nov 30, 2008 7:32 am Post subject: |
Okay thanks!
One day i will have one on my car.
First I have to finish my projects and see what amount left over... _________________ 1950 Hebmuller #458
1967 SO42 westy
oval-55 Samba Member
Joined: September 21, 2007 Posts: 43 Location: Finland Europe
Posted: Tue Dec 02, 2008 4:03 am Post subject: |
I am going to use ported stock heads with 33mm intake and 30.5 exhaust valves (and performance cam from Mr.Okrasa) with Judson next summer! Exhaust will be stainless steel 4-tip muffler from Wolfsburg Specialties => I have all parts allready in my garage, just have to find some time to put these things together |
