clutch problems (page 2)
dcollin
dcollin is offline
PostPosted: Mon Sep 29, 2008 10:12 pm    Post subject: clutch problems (page 2) Reply with quote
okay well first of all here is my 64 notch that i got yesterday..
I dont have a picture of it but there are many wires hanging just underneath the pushbutton's on the dash, to the left of the steering wheel. They are all tangled and mix matched. its a mess... but the headlights, the gauge lights and the gas gauge are all not working.. i will post a picture of it tomorrow but does anyone have any suggestions of what it could be and what i could do to fix it[/img]
burgandysquare
burgandysquare is offline
PostPosted: Mon Sep 29, 2008 10:23 pm    Post subject: Reply with quote
Welcome to the Type 3 world! There is a wiring diagram in the technical section that might be of use to you.
1968 Volkswagen Squareback
notchboy
notchboy is offline
PostPosted: Tue Sep 30, 2008 6:00 am    Post subject: Reply with quote
Get this, pull the driver seat out, put a nice comfy pillow-blanket on the floor, lay on your back so to get a good look under the dash, look over the wiring diagram thats easy to read and follow even JMSkater can do it Wink Have fun finding whats missing and conectining the dots.
This is truly a case of the dreading is worse than the doing. Good luck.
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
notchback
Insensitive Jerk
notchback is offline
PostPosted: Tue Sep 30, 2008 7:12 am    Post subject: Reply with quote
That was me several years ago. This is what I had:
It was a 12 hole fuse box from a later car. Things were plugged randomly onto it. I went down to Kinko's, pulled up these three items:
http://www.thesamba.com/vw/archives/info/wiring/type3_1500S_64.jpg
http://www.thesamba.com/vw/archives/info/wiring/type3_1500S_64_fuses.jpg
http://www.thesamba.com/vw/archives/info/wiring/type3_1500S_64_key.jpg
printed them out in color and laminated them. Then I did as Jason suggested and lay down in my car. It took me about 4 hours of tracing and running wires and I got everything hooked up. I feared the job for months and didn't do anything. I tried to get a couple different local guys to do it for me. I'm glad they refused. It's not as hard as it looks at first.
zeen wrote:
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point.
FU#3
dcollin
dcollin is offline
PostPosted: Tue Sep 30, 2008 8:39 am    Post subject: Reply with quote
That looks almost identicle to my situation, thanks for the info.. Now I just gotta get myself to do it
dcollin
dcollin is offline
PostPosted: Tue Sep 30, 2008 9:57 pm    Post subject: Re: Just got my 64 notch yesterday. got some electrical prob Reply with quote
dcollin wrote:
[/img]
I didnt want to start another thread but i am wondering what these wheels and tires are worth, they are 4 lug sprint stars on continental 195's. any input will help. thanks alot
notchback
Insensitive Jerk
PostPosted: Tue Sep 30, 2008 10:03 pm    Post subject: Re: Just got my 64 notch yesterday. got some electrical prob Reply with quote
dcollin wrote:
dcollin wrote:
[/img]
If they are original steel sprints in very good shape (can't tell for sure from the picture) I'd guess $400-$500 for the set on a good day. $300 will probably get them sold quickly. I had mine up for $500 and got a few nibbles, and lots of lowball offers. I've since decided to run them on my square.
FU#3
dcollin
dcollin is offline
PostPosted: Tue Sep 30, 2008 10:17 pm    Post subject: Reply with quote
what about wheels and tires together?
Mobiltune
Samba Road Ranger
Mobiltune is offline
PostPosted: Tue Sep 30, 2008 10:37 pm    Post subject: Reply with quote
wiring pic
remove the battery! (you will want to clean that area and paint)
and you want the wiring to be dead(fried wiring sucks)
drop the fuse "box"
remove the pushbutton box
study the above wiring pic
trace wiring as needed
these photos I took, while working on daves 62 notchback
Roadster Bus
PostPosted: Tue Sep 30, 2008 11:26 pm    Post subject: Reply with quote
Don't duplicate the fuse colors seen above. There shouldn't be any blue fuses and a bunch of the others look wrong too. The wiring diagram or owner's manual has the correct fuse ratings for each spot.
Mobiltune
Samba Road Ranger
PostPosted: Wed Oct 01, 2008 2:11 am    Post subject: Reply with quote
d'oh!
you are right, all the fuses should be 8 amper/amps, white in color.(1962-3)
I will repair that, once dave gets the notch back, from jimmy,
getting paint...
Roadster Bus
dcollin
dcollin is offline
PostPosted: Mon Oct 20, 2008 7:14 pm    Post subject: Reply with quote
well i recently went in to try and tackle this job.... i found that there were many wires which had been cut short. random ends sticking out different places. ALL of the wires coming from the push buttom terminals had been cut... and there are missing fuses. Im thinking at this point it might be easier to just buy a complete wiring harness and start over. What do you guys think? would it be easier to try and fix what i have or go for a new harness. any help is appreciated thanks..
volkoman
volkoman is offline
PostPosted: Mon Oct 20, 2008 8:14 pm    Post subject: Reply with quote
i thought about starting with a new harness and just tried connecting my push button box the wires were cut as well, took me a while but everything worked out. Of course I had alot of questions and thank god for The Samba
dcollin
dcollin is offline
PostPosted: Sat Oct 25, 2008 9:40 pm    Post subject: Reply with quote
okay so i bought a bunch of new connectors, fuses, wiring etc. i followed the diagram and just tried starting with hooking up the headlights, front parking lights, and tail lights. I got the tail lights to work and front parking lights, but the headlights will still not work. what should i be checking next?, i replaced the front headlights also...
JSMskater
Samba Grease Gorilla
JSMskater is offline
PostPosted: Sat Oct 25, 2008 9:44 pm    Post subject: Reply with quote
I had it a lot easier than neil Laughing
71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors
notchboy
notchboy is offline
PostPosted: Sun Oct 26, 2008 7:18 am    Post subject: Reply with quote
Follow all the wires. Make sure they are connected. The headlights have a brown wire that is ground and is grounded in the front trunk off the loom. Make sure they are screwed down. After that make sure the switch works and you have power.
The only bad thing about all this is that there may be a gremlin hiding somewhere-you know the one that got the guy before you to hack things up for some reason. Be prepaired to find it and squish it.
1964 1500 S
dcollin
dcollin is offline
PostPosted: Sun Oct 26, 2008 8:00 pm    Post subject: Reply with quote
well i got the headlights all hooked up and somehow got them to work but only by pushing in the high beam button on the dash, the low beam one only turns on the parking lights, im thinking this is due to the headlight relay... on the wiring diagram it has 6 pins and on mine it only has 5. in the diagram it lists 30, F,S, J, 56, 56a. the one that i have has 30, S, 56, 56b and 56a.... so does anybody have any helpful information? any help is appreciated.
notchboy
notchboy is offline
PostPosted: Sun Oct 26, 2008 8:10 pm    Post subject: Reply with quote
The relay has corosion in its contacts. Flip from hight to loww a bunch to see if it clears. If not youll have to open the relay and clean it.
1964 1500 S
notchback
Insensitive Jerk
PostPosted: Sun Oct 26, 2008 8:24 pm    Post subject: Reply with quote
The two buttons on the dash would be working fine if working as you explained. The "low beam" button is really the button for the parking lights. It is not supposed to turn on the headlights. The one you call the "high beam" button is the actual headlight switch. Your high-beam switch is on the back side of the turn signal lever. Just turn the headlights on and tap the backside of the lever and it changes from high to low. If you don't have an owners manual, check out the one on-line here.
http://www.thesamba.com/vw/archives/manuals/aug63_1500s.php
FU#3
dcollin
dcollin is offline
PostPosted: Sun Oct 26, 2008 8:53 pm    Post subject: Reply with quote
Okay thank you I was thinking that could be a possibility but wasn't sure, what would explain one of my lights being on high beam and one low
