67 Standard Peach Kombi, West Palm Beach, FL
Page: Previous  1, 2, 3 ... 29, 30, 31 ... 40, 41, 42  Next
kenshapiro2002
kenshapiro2002 is offline
PostPosted: Fri Jun 07, 2013 7:56 am    Post subject: Reply with quote
Also...that bus is a killer! If something can go wrong... Have you thought of naming her Christina? Laughing
don.ville Premium Member
Samba YardMan
don.ville is offline
PostPosted: Sat Jun 08, 2013 9:28 am    Post subject: Reply with quote
kenshapiro2002 wrote:
Am I the only person who thinks your brakes are upside down? Adjuster should be on the top...e-brake mechanism should be on the top. Is this because of the lowering thing?
Yes, they are upside down compared to stock, it is because it is lowered.
The brakes are from a Type 3.
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
Samba YardMan
PostPosted: Sat Jun 08, 2013 9:32 am    Post subject: Reply with quote
Makes life interesting I guess.....
Funny, this one does not have a name that sticks yet.... Very Happy
DONGKG
The Araneta Boys
Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
DONGKG is offline
PostPosted: Sun Jun 09, 2013 11:28 am    Post subject: Reply with quote
don.ville wrote:
DONGKG wrote:
So how's the status of your bus now? I experienced that problem before on my '67 vert' Karmann Ghia. We replaced the fulcrum and axles, and everything turned out well. The knocking sound was really annoying that ever sound is like vibrating so intense that you always foresee what would be the effect thereafter.
Running great for now!
Haven't opened the deck lid except to show someone the engine.
No squeaks except from clutch pedal spring.
No clunks from axle on take off.
It is a good thing that it runs great now...
Cool one buddy!
'67 KG Cabrio (Mickey) ;
'66 Type 3 (Sharky 2)
'72 Type 2 Homey
'67 Splitty Bus
'65 beetle;'69 Country Buggy; '44 Kubelwagen (replica) TOOB MEMBER #20
Samba YardMan
PostPosted: Mon Oct 28, 2013 7:46 pm    Post subject: Reply with quote
Getting ready for Bulli Brigade and Bug Jam Nov 8th.
Decided to do a mini service....
Change oil added 2.5q of Brad Penn 10W30 semi-synthetic
used Silicone oil screen gaskets from Wolfsburg West
Pertronix check all screws and nuts for tightness
Check dist cap
Checked all 4 plugs
Samba YardMan
Battery terminal cleaning
Fuel filter and lines inspection
Clutch cable inspection
Samba YardMan
PostPosted: Mon Oct 28, 2013 7:47 pm    Post subject: Reply with quote
Tranny leak check
Small drip while jacked up
Adjusted all 4 brake shoes
Checked front wheel bearings for grease
Samba YardMan
Checked and cleaned front suspension (lubed few months ago)
Checked and tightened rear shift rod coupler, added safety wire to grub screws
Checked Tires...These Continentals are doing really well since Feb 2010 and about 15K miles
Samba YardMan
PostPosted: Wed Nov 06, 2013 7:13 am    Post subject: Reply with quote
Me with my cyclops light...
kenshapiro2002
PostPosted: Wed Nov 06, 2013 7:18 am    Post subject: Reply with quote
Nice grill too!
Looking for a correct 1967 rear seat
Looking for '67 Engine / Block HO 183xxx - HO 194xxx
Big Bill
Big Bill is offline
PostPosted: Wed Nov 06, 2013 7:37 am    Post subject: Reply with quote
Nice check list, I think you covered all the bases. Although it looks to me like your a little lean by the looks of your plugs. Or maybe its the way they look on the computer.
Samba YardMan
PostPosted: Wed Nov 13, 2013 4:58 pm    Post subject: Reply with quote
I thought the same thing Bill...
Before Bulli Brigade, I adjusted my fuel mixture screw 1/8th of a turn inwards/tighter/clockwise to add a little more fuel.
I also saw my oil was above the line before I left the house.
I drained it slightly to end up right below the top mark on the dipstick.
I did 483 miles over the Bug Jam/Bulli Brigade XX weekend and got about 22 mpg on average after doing the math.
Big Bill
Big Bill is offline
PostPosted: Wed Nov 13, 2013 5:59 pm    Post subject: Reply with quote
Sweet, saw some pictures of the Bulli alot of great looking buses there.
Samba YardMan
PostPosted: Wed Feb 19, 2014 10:53 am    Post subject: Reply with quote
Pre-Volksblast inspection and checks.
Fan belt tighten by moving one washer from inside pulley to outside.
Looked like a preheat gasket leak, so I just removed, flipped upside down and retightened.
Sometimes when I start engine, the exhaust tip would bang on the bumper when then engine shook and make it sound like my engine is broken.... so I clamped the muffler to the bumper..
Samba YardMan
PostPosted: Wed Feb 19, 2014 10:57 am    Post subject: Reply with quote
I like to look and see if and where any oil leaks are starting....
My silicone Wolfsburg West drain screen gaskets are doing well, the drain plug is not doing so well, I may switch back to the factory drain plate without the center drain bolt, as that seems to be where the drips come from.
Other oil stains...
Samba YardMan
PostPosted: Wed Feb 19, 2014 10:59 am    Post subject: Reply with quote
Transmission side plate gasket with Permatex red on one side: no leaks
and Grey on the other: slightly damp
Samba YardMan
PostPosted: Wed Feb 19, 2014 11:01 am    Post subject: Reply with quote
Axle seal leaks...
Samba YardMan
PostPosted: Wed Feb 19, 2014 11:11 am    Post subject: Reply with quote
Adjusted my valves using hydraulic valve lifter procedure, that did not go well. ( I started another thread just for that).
All pics for reference...
BulliBill
BulliBill is offline
PostPosted: Wed Feb 19, 2014 11:18 am    Post subject: Reply with quote
Lookin' good! Way to stay on top of your maintenance!
Couple of little things, I would crawl under there with some wax and grease remover solvent and some of those blue paper shop towels and wipe down/remove all of the oil/grease/ tranny gear oil from all of your components (brake backing plates and inner sides of your wheels, under push rod tubes, bottom of crankcase and transaxle). Clean everything that has any residue on it! Get 'em all clean and dry. Then after your next drive, crawl back under and if you have any leaks, the source of them will be much more apparent.
I would not clamp that clamp on the damper/tailpipe to the bottom edge of the bumper blade. The engine is supposed to move or rock a little and be independent of the fixed bumper blade. Part of your contact problem "might be" that I think you have the wrong tailpipe for a Split motor on there. Hard to see from the angle of the photos above, but I think you have the tailpipe from a Bay Bus or Type 3 on there (more of an "L" shape tailpipe)? The correct one that clears the Split-Bus blade properly looks a lot like a "?" or question mark.
Enjoy that old Bus!
Bill Bowman
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
Samba YardMan
PostPosted: Wed Feb 19, 2014 11:31 am    Post subject: Reply with quote
Barbie ... It's already the right color....
Page 30 of 42
