AlanInMass54 Samba Member
Joined: August 29, 2003 Posts: 1066 Location: Massachusetts
Posted: Wed Apr 23, 2014 9:30 am Post subject: |
Wow that service install is quite unsightly!
I haven't got the facilities to access my chassis like this, unfortunately. |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Thu Apr 24, 2014 7:55 am Post subject: |
AlanInMass54 wrote: |
Wow great idea! i'll certainly keep that in mind. I make smaller openings to investigate problems...
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
GermanRust52 Samba Member
Posted: Fri Apr 25, 2014 6:56 pm Post subject: |
Still working on that.
Walter Wiseman Samba Member
Joined: April 13, 2010 Posts: 21 Location: Glencoe, Ca.
Posted: Fri Apr 25, 2014 9:44 pm Post subject: My December 1954 project |
Got the choke cable out!!
Took over a week, but I set up a funnel to keep deep creep soaking in.
Then I attached a ratcheting tie down to start putting pressure on it while keeping deep creep soaking in.
Then I attached vice grips on the other side to keep pressure going that way as well.
Throughout the week I kept ratcheting the tie down and spraying deep creep in.
Tonight I felt it give a little bit so I started pulling, and got this:
And I got it all!
Then I blew out all the crap and have a clear tube, finally! _________________ 54 Semaphore Beetle
65 Beetle (Gone)
71 Bus (Bastard Double Cab)
73 Thing |
EverettB Administrator
Joined: April 11, 2000 Posts: 69802 Location: Phoenix Metro
detroitjohnny Samba Member
Joined: November 23, 2002 Posts: 364 Location: Traverse City, MI
Posted: Sat Apr 26, 2014 4:59 am Post subject: |
Wow! Nice job, and great thinking. _________________ ostkuste |
Posted: Sat Apr 26, 2014 5:54 am Post subject: |
Great job getting it all out! I had gotten some of the coil winding out and then it snapped. I figure I got a total of ohhh.. 3 inches out. |
RichOakley Samba Member
Joined: August 30, 2004 Posts: 1108 Location: Midlands, UK
Posted: Sat Apr 26, 2014 9:00 am Post subject: |
Great work! _________________ 1947 Beetle
1956 RHD Karmann Cabrio
1956 RHD Beetle
1957 RHD Pitt-Moto Type 2 Camper
1959 RHD Beetle
1966 RHD Type 3 Fastback
1976 RHD Sun Beetle |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Wed Sep 03, 2014 8:41 am Post subject: |
I have been reading about removal of stuck choke cables now for the last year, and have a grip on the methods people are having success with. My situation is a bit different though. My choke cable is cut off flush with the edge of the tube where it enters the chassis at front, and is cut off at the back, with maybe an inch or so of the damaged wound sheath visible. I think it would pull apart.
In short, I have nothing to grab. I imagine I can try to pick at the cut off winding in front, and then start pulling the winding out, but it sounds like they more often break.
I also read about trying to tap the whole cable and sheath out using conduit, or thick wire.
Anyone have an idea how I might get started? I do plan to remove the gas tank, attach a funnel, and start trying to get lubricant into the tube with the front of the car raised to begin with.
Thanks! _________________ Plate of shrimp |
jason Samba Member
Posted: Wed Sep 03, 2014 9:23 pm Post subject: |
Try a screw, then pull on it. |
Posted: Wed Sep 03, 2014 9:52 pm Post subject: |
Thanks, I'll give it a try. _________________ Plate of shrimp |
TheLadyBug Samba Member
Joined: August 17, 2014 Posts: 639 Location: Saskatoon, Saskatchewan, Canada
Posted: Sat Oct 04, 2014 9:28 pm Post subject: |
I've joined the club and my choke won't come out.
Is it favorable to pull the coiled wire so it unravels? _________________ Charmaine
1954 Beetle - because I can
2016 Golf highline - hubby’s daily
2016 Golf R - my daily |
Posted: Sun Oct 05, 2014 12:54 pm Post subject: |
Well... I must have eaten horseshoes for breakfast.
Pulled on the cable, unravelling it. Pulled and pulled. The plastic sheathe broke into about 4 pieces. We had a little coiled wire left to pull out and after determining about 20" of sheathe remained inside... We pulled the remaining coiled wite out and the sheath came with it.
It's out! I ran a thick 8 gauge wire through and the tube is clear. Rusty, but clear! _________________ Charmaine
Posted: Sun Oct 05, 2014 10:31 pm Post subject: |
Tried a long course thread drywall screw. It took! It grabbed the spiral, and I used a slide hammer to work an inch or so of the cable out, and now I am soaking it with deep creep.
Posted: Sat Oct 11, 2014 11:01 pm Post subject: |
So I started the pull today, after a week of feeding it deep creep.
I made up my own method, which resulted in 1 inch of stretched coil winding per attempt, using a claw hammer and a vice grips.
I spent the afternoon doing this, netting 10+ feet of stretched coil winding before it broke.
I estimate that I got about 3 feet of the coil winding out. That leaves about 3 feet still in the tube, and I have nothing to grab at the rear. Anyone have an idea? _________________ Plate of shrimp |
Posted: Sun Oct 12, 2014 10:29 am Post subject: |
I have heard that affixing a truck antenna to a drill works. Flatten the end so I can grab the wire. Once it grabs it, pull. _________________ Charmaine
MeeferMadness Samba Member
Joined: June 14, 2004 Posts: 305 Location: Eugene Oregon
Posted: Wed May 13, 2015 6:12 pm Post subject: Stuck choke cable |
My choke cable was broken off at both ends on my 59 Euro rag project. I filled the tube with PB Blaster let it soak for a couple of weeks then used a long drywall screw at the transmission end of the chassis. Today using a pry bar, vise grips and a strong pull.....I GOT IT OUT!! WHOO HOO!
Thanks for all the tips fellow Samba experts. Now if I can just get my split case trans to quit leaking at the sideplates.
Meefermadness |
Posted: Wed May 13, 2015 8:04 pm Post subject: |
I'm jealous. Mine is broken off and now inaccessible. My last option without going totally nuclear will be to remove the gas tank and try to drive the cable out with graduated lengths of 3 gauge copper wire.
If that fails, I'll run it through the cabin like in the old tech bulletin.
A permanent and proper repair (like a new tube installed) would come later down the road, like when it's time to paint again.
Anybody have any new tricks...?
....anybody....? _________________ Plate of shrimp |
Bret2094 Samba Member
Joined: March 22, 2012 Posts: 665 Location: Linden, Texas or College Station Texas
Posted: Wed May 13, 2015 8:33 pm Post subject: |
panicman wrote: |
....anybody....? |
I just spent all day trying to get mine out...... no luck so far. I've tried most methods other than the cut method as well. hopefully you have better results
Bret
Bret _________________ 1959 baja beetle ragtop( going back to Full body)
1959 beetle
1960 Beetle frame Custom buggy
1962 Karmann Ghia
1967 beetle( august 66, first car)
1967 beetle (parts car)
1977 Westfalia Camper
1972 Plymouth Duster
Just another 22 year old jackass who caught the bug, and lives by the motto " NO fatchicks allowed" , I've got too many cars as is (buses N/A) |
Posted: Wed May 13, 2015 9:46 pm Post subject: |
I'll be sure to post my success (or failure) for posterity. _________________ Plate of shrimp |
