EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
Joe Caraway Samba Member
Posted: Mon Nov 28, 2011 9:01 pm Post subject: 53 Barndoor Single Cab |
Latest progress. And it runs!
bugpartslou Samba Member
Posted: Mon Jan 02, 2012 4:39 am Post subject: |
Nice! Your panel is alive and well, in case you needed to know! |
D-train Samba Member
Posted: Sun Aug 10, 2014 3:28 am Post subject: |
reboot of old thread...
updates? _________________ shiny paint doesnt make it worth any more |
My57Oval Samba Member
Posted: Thu Sep 01, 2016 7:23 pm Post subject: Re: '53 Single Cab on eBay, now being restored in Arizona |
Is it done yet? 🇺🇸 |
Fifty-Eight Rag Samba Member
Joined: September 07, 2011 Posts: 936 Location: St. Louis, MO
DSweinhagen Samba Member
Joined: July 30, 2002 Posts: 382 Location: Phoenix, AZ
Posted: Fri Dec 16, 2022 8:58 am Post subject: Re: '53 Single Cab on eBay, now being restored in Arizona |
So Joe still has this single cab. Progress has been slow but he's been plugging away. Once it was realized there wasn't much usable of the original body, he sourced a donor body. The donor is a '58 and from what I understand, it was a completely stripped field find but really solid. So it was a good fit for this. I'd stop by his shop from time to time and just shake my head in amazement at what he was trying to do...
Once Joe went as far as he could, he enlisted the help of Mike Bailey. Mike's part of the Edgefinder VW family here in Phoenix and does excellent metal and fabrication work. Mike blended the donor body with what was left of the barndoor parts and got it all set back on the chassis. The result is awesome and it's great to see this thing back in one piece.
So now I'm helping to get this truck to paint. I picked it up at Joe's shop up in Scottsdale and dropped it at Pro Strip Mediablasting for stripping. It's back at my place now and I'm starting on the body work. I'll do my best to keep this updated and get this thing to paint before too long...
_________________ David S |
Huetti_1989 Samba Member
Joined: February 13, 2011 Posts: 1136 Location: Austria
Posted: Wed Jul 26, 2023 8:13 am Post subject: Re: '53 Single Cab on eBay, now being restored in Arizona |
I've been needing to catch this thread up and just can't get motivated to go out to the shop with a low temp of 98*F(36.6C for everyone outside the US) this morning. So here it goes...
With the body roughed out and in first primer, it was time to start on the undercarriage. There were a few surprises when it came back from the blaster, but nothing too bad. I had to do some repair at this front left frame area, and the back of the same wheel well was pretty thin...
Some of the cable tubes weren't installed so I sorted that out. I had to R&R the rearmost outriggers to run the e-brake cables correctly as Barndoor runs a little further out and the floor support was cut for a later bus...
Posted: Wed Jul 26, 2023 8:44 am Post subject: Re: '53 Single Cab on eBay, now being restored in Arizona |
So onto final prep and painting the undercarriage. My oldest son Mason has been helping out in the shop on breaks from college and there was lots of pitting to fill here.
Matt Howard at Deluxe Customs will be helping me with final paint again so we needed to figure out the dove blue. He uses ProSpray and their codes are usually pretty good, but this one wasn't. You can see here it took some work to get right...
And time for final prep and paint. PPG's DP epoxy primer, then PPG DCC single stage urethane grey matched and flattened, and then some blue overspray.
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Thu Jul 27, 2023 6:08 pm Post subject: Re: '53 Single Cab on eBay, now being restored in Arizona |
You know its a quality paint job when it begins with the overspray!
That rocker is sexy...
Wonderful work. Thanks for the updates! _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Posted: Thu Aug 03, 2023 9:16 am Post subject: Re: '53 Single Cab on eBay, now being restored in Arizona |
Thanks John!!
With the bottom done, it's off the rotisserie and onto fitting and body working doors...
The side door was pretty nice but had some damage to the lower inner support, so I made and replaced a section...
The decklid needed a little modification along with the R-corner...
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Thu Aug 03, 2023 7:09 pm Post subject: Re: '53 Single Cab on eBay, now being restored in Arizona |
you do good work, i will be watching. _________________ regards
Uli
Posted: Tue Aug 29, 2023 7:47 am Post subject: Re: '53 Single Cab on eBay, now being restored in Arizona |
The bed didn't look too bad before blasting, but after, it was pretty well pitted, lots of pinholes and kind of beat. While Joe really wanted to save the original bed, we came to the conclusion it wasn't worth the amount of work to repair it, and I could refinish the areas underneath much better with it out of the way. Remember, this is from the donor '58.
With the bed out of the way, The engine compartment was body worked and primed, and the treasure chest area was prepped, primed and painted.
Posted: Tue Aug 29, 2023 6:59 pm Post subject: Re: '53 Single Cab on eBay, now being restored in Arizona |
Out here in the East, the treasure chest floor usually rusts away worse than the bed floor.
Something about the ground moisture.
The cross rails look really solid! _________________ Founder and Chairman Emeritus, ECMSAS
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Wed Aug 30, 2023 7:09 am Post subject: Re: '53 Single Cab on eBay, now being restored in Arizona |
Thanks for sharing Dave, great work! _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
Posted: Tue Sep 26, 2023 8:08 am Post subject: Re: '53 Single Cab on eBay, now being restored in Arizona |
Thanks Patrick!
So here I was hoping to install a new bed, but Joe insisted on using original. He came up with this one locally. This was a ton of work!
The pieces were already blasted. Here's the front section removed, straightened, the bottom side primed and painted and installed...
Same process for the rear. There were some pinholes to weld up and I got a coat of paint in the engine compartment while it was more accessible...
myklsmyth Samba Member
Posted: Tue Sep 26, 2023 9:41 am Post subject: Re: '53 Single Cab on eBay, now being restored in Arizona |
I think posts like this (and the modern car restoration shows) can mislead someone who wants to take on a project into thinking that it's a lot easier than it really is. I click on a thread and see a "simple" bed install that took a few minutes to review, with photos attached! But that had to be a very tedious process and one that really was not worth it, given the reproduction metal available, except for that client that wants OG metal. I respect the commitment because at that point it is beyond making the right financial decision. I also commend you for being willing because there are times that this has come up in a variety of areas of my life and I have just said, "I don't want to, no matter what they are paying". Thanks for sharing as I enjoy the quality of your work! |
Two Glove Boxes Samba Member
T2 Samba Member
Joined: February 15, 2003 Posts: 187 Location: Yachats, Oregon
Posted: Wed Sep 27, 2023 7:58 pm Post subject: Re: '53 Single Cab on eBay, now being restored in Arizona |
Beautiful work like always David. I love the updates |
