miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Thu Jan 01, 2009 11:34 am Post subject: So it begins... Type 4 Twin Screw |
Who wants to see how this turns out?
The recipie is as follows:
2.0 case
71mm crank
103mm AA piston kit
Rods are up in the air, either lightened stockers or H-beams
914 2.0 heads
Custom merged exhaust
EFI (Megasquirt of course)
EDIS distributorless ignition
Intercooler (probably the PWR barrel cooler I already have)
IHI Twin Screw supercharger from a Mazda Millenia S
Custom cooling system: this is gonna be the hardest part. Since the supercharger is gonna be close to the block due to the way it's oiling system works, the cooling fan(s) will have to be above it. It's lubricated via engine oil with drains on the bottom, so I'd like to simply have the oil return to the top of the block through the old breather mount spot. I'm toying with the idea of a Corvair magnesium fan with ducting, but at this point nothing's set in stone.
Any questions? _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Type 5 Joe Banned
Joined: January 18, 2003 Posts: 1795 Location: Oregon
Posted: Thu Jan 01, 2009 11:47 am Post subject: |
How are you going to keep the heads / cylinders sealed? |
Posted: Thu Jan 01, 2009 11:53 am Post subject: |
Think 5th studding would be a good idea? _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
Type 5 Joe Banned
Posted: Thu Jan 01, 2009 11:57 am Post subject: |
I think a set of Nickies are the only real answer....Even in non-boost applications.
There is another engine out there with Type I cylinder spacing and proven reliability Characteristics... Even has a German Alum case, and a Type IV style flywheel. |
M-Owen Samba Member
Joined: October 24, 2007 Posts: 88 Location: Chestnut Hill, Phila
Posted: Thu Jan 01, 2009 12:12 pm Post subject: |
Keep me posted, I have been thinking about a supercharger on a type4 for a while |
craigman Samba Member
Posted: Thu Jan 01, 2009 12:40 pm Post subject: |
I WANNA SEE!
Keep us posted!
Craig |
MAYHEM Samba Member
Joined: January 30, 2006 Posts: 1813 Location: Warm and sunny coastal CT
Posted: Thu Jan 01, 2009 12:53 pm Post subject: |
Very interesting
Anxious to see how it does. How much boost should it make? _________________ Greg
Model Citizen
johnnypan wrote: |
I digitize myself in the privacy of my own home. |
Eric_S Samba Member
Joined: August 12, 2007 Posts: 862 Location: Sparks (think Reno) NV
Posted: Thu Jan 01, 2009 1:11 pm Post subject: Re: So it begins... Type 4 Twin Screw |
miniman82 wrote: |
Custom cooling system: this is gonna be the hardest part. Since the supercharger is gonna be close to the block due to the way it's oiling system works, the cooling fan(s) will have to be above it. |
Or on both sides of it:
Everything has already been done. _________________ --
Eric_S
What are all these extra parts? |
Bad bug Samba Member
Posted: Thu Jan 01, 2009 1:55 pm Post subject: |
One thing i surely can advise you about make sure your chassis can take the abuse of a type4 on boost. O.k. interesting build i was considering a supercharged typr4 at one point. You could try to put a corvair fan on it, this has being discussed over at shoptalk forum a while back. Their was a guy on shoptalk forum by the name of moggy that had a supercharged 2.4ltr t4 just like the one you are building, it had loads of torque. I SAY AGAIN MAKE SURE YOUR CHASSIS CAN TAKE THE TORQUE THIS THING WILL PRODUCE.
Instead of fifth stud why not try increasing the surface area of the head where the sleeve would come into contact by machining grooves that interlock in the heads and the top of the liner. A very famous type4 engine in england used this method with great success ( Russ Fellows ). |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6025 Location: CONGERS, N.Y.
Sigurd Samba Member
Joined: April 18, 2006 Posts: 2639 Location: Rockford, IL
Posted: Thu Jan 01, 2009 2:10 pm Post subject: |
Subscribed. |
gerg a.k.a. 6volt65
Joined: April 25, 2003 Posts: 5454 Location: Monroe, LA
Posted: Thu Jan 01, 2009 2:14 pm Post subject: |
nextgen wrote: |
What is the supercharger from.? I know VW makes very compact units. |
IHI Twin Screw supercharger from a Mazda Millenia S _________________ Gerg
. . . I got 99 problems and my bus ain't one . . .
'65 Sunroof Beetle
'65 Vert
'60 Singlecab |
Mark Henry Samba Member
Joined: November 24, 2005 Posts: 251 Location: Port Hope, ON, Canada
Posted: Thu Jan 01, 2009 3:58 pm Post subject: |
You would have sealing issues even with 103 nickies. Heads should be welded across the top instead of the 5th stud crap and you would have a better chance of sealing with a smaller cylinder.
How much boost are you planning on? Seems most that try over 10 pounds have issues. _________________ '74 914, back on jackstands for a 3.0/6
'67 Bus 2007cc, Berg engine
'67 EMPI GTV bug w/ 102mm Nickies, massIVe bottom end, SDS FI, 2.6L T4 monster in the works |
Alexander_Monday Samba Member
Joined: November 09, 2007 Posts: 306 Location: Springfield Missouri
Posted: Thu Jan 01, 2009 5:24 pm Post subject: |
I don't know if he is still using this, however Moggy's solution to the head sealing problem was to do this:
_________________ Danth’s or Parker’s Law:
“If you have to insist that you've won an internet argument, you've probably lost badly.”
andk5591 wrote: |
The original german engineers have attained sainthood and it is impossible to improve perfection.
Anything that anyone does to deviate from the original designs will be made to wrench on 20 year old Yugos with Harbor Freight tools in hell. |
Type 5 Joe Banned
Posted: Thu Jan 01, 2009 5:41 pm Post subject: |
Nice....
I would scrap the Type IV idea. |
Posted: Thu Jan 01, 2009 6:19 pm Post subject: |
I found the post where I got those pictures:
http://shoptalkforums.com/viewtopic.php?t=93194&am...1cefb60852 _________________ Danth’s or Parker’s Law:
andk5591 wrote: |
Hotrodvw Samba Member
Posted: Thu Jan 01, 2009 6:54 pm Post subject: |
Oh hell yeah..........I gotta see this! _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
Posted: Thu Jan 01, 2009 7:57 pm Post subject: Re: So it begins... Type 4 Twin Screw |
Eric_S wrote: |
miniman82 wrote: |
Or on both sides of it...
Everything has already been done. |
Ah, but that's not a twin screw 'charger. I've seen that pic before on another forum. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
Posted: Thu Jan 01, 2009 8:04 pm Post subject: |
Alexander_Monday wrote: |
I don't know if he is still using this, however Moggy's solution to the head sealing problem was to do this:<snip> |
I thought about doing that, does it work very well? _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
I look forward to seeing your results! Any interesting, outside the box build is good for the TIV.
When I have supercharged TIV engines the biggest battle was cooling intake temperatures.
You'll have fun with this,its fun doing something that make people scratch their heads.. The only thing thats better is the compliment of being told that you have lost your mind.. _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
