BarryL Samba Member
Joined: November 01, 2004 Posts: 14257 Location: Casa de Oro, California
Posted: Mon Mar 07, 2011 4:11 pm Post subject: |
tnc19 wrote: |
...use lithium bearing grease instead of gear oil? |
John Deere Corn Head Grease, part number AN 102562, is a viable alternative. |
Culito 11010101
Joined: December 07, 2006 Posts: 5865 Location: Columbia Missourah
Posted: Mon Mar 07, 2011 4:39 pm Post subject: |
Aw, I got the rollin' eyes from Hazet.
Dern. _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
grey60 Samba Member
Posted: Wed Aug 27, 2014 6:33 am Post subject: |
Reviving this thread because I just encountered the same problem re oil leaking into (?) the horn ground's guide tube in a very recently-rebuilt ATE steering box.
I put Amsoil 80-90 synthetic oil in mine after sealing everything up (I thought) and within a day it was leaking from the center of the tube -- like I'd over-filled, except I only put 2-3 ounces in…
Is it consensus that gear lube alone is not viscous enough for the steering box, and that 'other additives' are necessary? Thanks _________________ 1960 grey panel |
jason Samba Member
Posted: Wed Aug 27, 2014 7:47 am Post subject: |
I mixed oil treatment with the gear oil to the consistency of syrup. This is what is recommended from Wolfgang when they rebuild. Mine is also an ATE, they rebuild them now. |
grey60 Samba Member
Posted: Wed Aug 27, 2014 9:52 am Post subject: |
jason wrote: |
Thanks.
STP, right? Is there a correct mix ratio?
The only catch for me might be that I'm using Amsoil/synthetic -- which I bought in bulk for my transmission --
Dunno how it will mix with STP… _________________ 1960 grey panel |
jason Samba Member
Posted: Wed Aug 27, 2014 1:35 pm Post subject: |
I believe it was STP. I think it also mixes with synthetic oil so it should work with synthetic gear oil. |
BarryL Samba Member
Posted: Wed Aug 27, 2014 6:57 pm Post subject: |
If you did every thing right, just wait it out and see if it stops dripping. Only opening to the inside is from the horn wire tube where it ends. |
