eurodub Samba Member
Posted: Sat Aug 31, 2013 6:53 am Post subject: |
hey guys!
are these square mats small standard rear mats or fronts?
http://www.thesamba.com/vw/classifieds/detail.php?id=1111838
i will be the future owner of a 1959 standard polizei beetle so i was searching for odds and ends _________________ 1960 1200 model 117 deluxe ragtop
1974 T2 Westfalia Campmobile
1976 MK1 Golf |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Sat Aug 31, 2013 2:38 pm Post subject: |
No, the standard model thru 64 and the 1965 "A" sedan and the 1965 Canadian 1200 Custom use the old type of mats that you would find on say a 1955 beetle. Those models above have pans that do not have seat tracks but do have two knobs welded to the pan ( two for each mat ) that the mats snap onto ( the mats (4) have two holes to push over the knobs to hold them in place. Remember those cars mentioned above have two studs welded in the pan for each ft seat instead of seat tracks and there is a claw and wing nut for each stud to fasten to the tube/frame of the seat. Mats look like these;
http://www.wolfsburgwest.com/img/wwpn/111863002.jpg |
Posted: Sun Sep 01, 2013 12:27 am Post subject: |
i was referring to the square ones, maybe for the tunnel... not the floor ones _________________ 1960 1200 model 117 deluxe ragtop
1976 MK1 Golf |
VW_RaF Samba Member
Posted: Sun Sep 01, 2013 5:18 am Post subject: |
Helfen wrote: |
Hi, I think standard floormats are shorter:
I bought it from Classiccult, thank you again. |
Helfen Samba Member
Posted: Sun Sep 01, 2013 7:58 am Post subject: |
eurodub wrote: |
i was referring to the square ones, maybe for the tunnel... not the floor ones |
The tunnel mat for a standard (1938-1964) or a 1965 "A" sedan or a 65 1200 Custom are two piece, one one for the front which stops short of the gear shift lever and only covers the tunnel stopping on the sides at the pan the rear piece which covers the tunnel and part of the reinforcement of the pan. Those models also get the rubber cover for the heater control in the 65 model. You can see some of this in the picture of my 65 "A" sedan. I should note that this interior and paint in specific areas and the chrome door handles/oil pressure gauge have since benn returned to stock. Anyroad, check out the tunnel covers;
http://www.pismoderelicts.com/photogallery/new%20format%20834/images/img_0136_edited_1.jpg
https://www.thesamba.com/vw/gallery/pix/516079.jpg |
Helfen Samba Member
Posted: Sun Sep 01, 2013 8:02 am Post subject: |
VW_RaF wrote: |
Helfen wrote: |
Actually I have my original mats for my 65 "A" sedan and when I bought the new mats from W/West they were the same length. |
VW_RaF Samba Member
Posted: Sun Sep 01, 2013 10:30 am Post subject: |
Helfen wrote: |
Ok, I mean they are shorter than those that come under the battery in the previous models without under seat panel. |
Posted: Sun Sep 01, 2013 12:32 pm Post subject: |
what about these 2? they look square to me at least, so... are they for what?
on a side note, i just got my 59 military standard today. will add pics and a thread shortly , i need some hints about what was original or not, maybe someone has had some interaction with military beetles before.
Mihai. _________________ 1960 1200 model 117 deluxe ragtop
1976 MK1 Golf |
VW_RaF Samba Member
Posted: Tue Sep 03, 2013 12:12 pm Post subject: |
I think that this is not part from VW. |
Helfen Samba Member
Posted: Tue Sep 03, 2013 2:38 pm Post subject: |
VW_RaF wrote: |
I think you are right. I should have mentioned in my last post that my original mats have the VW logo and the VW part number embossed in the mats. |
dropped65 Samba Member
Posted: Sat Mar 29, 2014 5:48 am Post subject: |
this is my 59 semiphore ragtop
i am picking it up this week along with a us market 59 hardtop that was a baja at one time
from a quick look over the car is on a 66 pan and has 66 doors |
avw1973 Samba Member
Joined: September 14, 2012 Posts: 51 Location: Winston-Salem
Posted: Tue Dec 23, 2014 11:57 am Post subject: 1962 European Standard |
I am still gathering parts for my car. I did find the dash pieces in a pile at the Pomona Swap Meet. I couldn't believe it! I purchased a 36hp fresh air muffler. I am going to take the air outlets from a newer fan housing any thoughts? I am going to use a non serial number engine, I have not been to find a correct one for the year. I found bolt down seats at a local meet. The body work is done and to find time to finish it. |
Helfen Samba Member
Posted: Tue Dec 23, 2014 1:43 pm Post subject: Re: 1962 European Standard |
avw1973 wrote: |
Just a FYI, the 36hp fresh air car (1963-1965 ) uses the 40hp fresh air muffler and heat exchangers which are easily obtainable. The thing to remember about the 36hp fresh air parts that are different from old 36hp engines and 40hp engines is the special intake manifold, some engine tin like the breast plate, a exhaust port spacer to makes the heads the same length as the 40hp heads. These are the things that are different. |
Posted: Tue Dec 23, 2014 1:53 pm Post subject: |
Oops! I forgot to mention that my car is 1962. The inside was covered spray glued foam carpet - what a pain. It had wide fibreglass fenders and a weird deck lid, no engine, seats. The guy thought it was a real custom. I saw no body holes etc. and paid the price. I think I saved it from becoming a real mess. |
bandet Samba Member
Joined: May 21, 2011 Posts: 95 Location: pingree I.D.
Posted: Wed Jan 14, 2015 11:06 am Post subject: |
On the left side of the steering colom half way down there are some wires hooked to the colom in one of your pic what's that for??????? _________________ Thanks
Marvin Lewis
[email protected] |
Helfen Samba Member
LHG Samba Moderator
Joined: April 13, 2000 Posts: 1855 Location: LostHillsGuy, CA
Posted: Wed Mar 04, 2015 9:33 am Post subject: |
Distributor Question.
The 1966 1200A is the first year for a 40hp engine in a "Standard".
Would it have had the wide cap 40hp distributor or the aluminum body 40hp distributor? _________________ Brian O'Kelly
Central Coast Chapter, CA - Vintage Volkswagen Club of America
www.centralcoastvwclub.com
www.facebook.com/groups/vintagevwclub/ |
Helfen Samba Member
Posted: Wed Mar 04, 2015 5:28 pm Post subject: |
LHG wrote: |
Would it have had the wide cap 40hp distributor or the aluminum body 40hp distributor? |
Hi Brian, I would say the small cap. How is the 66 project coming. Got any pictures? |
LHG Samba Moderator
pdowty68 Samba Member
Joined: April 07, 2014 Posts: 224 Location: Long Island, New York
Posted: Thu Mar 05, 2015 7:03 am Post subject: |
Germanpride wrote: |
brycetx wrote: |
I scanned some of a 66 standard brochure that I have
http://s132.photobucket.com/albums/q16/threespoke/standardkafer/literature/?start=20
along with other pics I've collected in the sub albums. I can scan the full brochure if you like.
Does it have the reserve lever still attached? And that decklid ! post 64 bugs had the center "W" ridges flare out for the wider licence light. But that one doesn't but has the later button lock, and that 1200 emblem! Strange. You would think it would cost more to produce these extra parts.
Does it have model 115 on the ID plate? |
Wow, friggin awesome! Is this seriously a fresh-air 36horse?!?!?
Wow thats awesome! I wonder if it has the cooling flaps or the ring. 40hp tin I bet. |
