didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Mon Mar 07, 2016 8:52 am Post subject: Re: CLKWRK's build |
I'm in the planning/build stages of my '71 KG, and have considered installing a BN2, but not too crazy about the idea of having a jet engine over the gas tank...
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
CLKWRK Samba Member
Joined: October 02, 2001 Posts: 566 Location: Toronto
CLKWRK Samba Member
CLKWRK Samba Member
Posted: Wed May 25, 2016 5:39 pm Post subject: Re: CLKWRK's build |
I finalized my BN2 install last weekend
- output ducting is routed to defog windows with heat
- extra relay added to defog windows with no heat blower only, fresh air from the nostrils still works
- my engine heater boxes are still connected but only supply heat to the back seat and floor vents
- so far no failed starts when I have been testing it and no overheat condition, so it seems to be working as designed
- It hogs up about 1/3rd of my trunk space, which sucks but hey, I live in Canada heat is a must have
_________________ 1971 ghia build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=336744&start=0
Type 4 upright build:
http://shoptalkforums.com/viewtopic.php?f=1&t=134056
Instagram:
https://www.instagram.com/vantageaircooled/ |
Posted: Wed May 25, 2016 7:23 pm Post subject: Re: CLKWRK's build |
Very nice work!
Bryan _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
CLKWRK Samba Member
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Sun Aug 14, 2016 11:13 am Post subject: Re: CLKWRK's build |
CLKWRK wrote: |
Your install looks nice. I also have a BN2 installed in my Ghia. Question - what size fuse do you use in the unit - the one that is under the plastic cover? I am using an 8 amp. It has gone out on me every now and then. Seems like it should be a 16 amp. Thanks. _________________ Ghia Owner Emeritus |
CLKWRK Samba Member
CLKWRK Samba Member
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
Posted: Fri Oct 27, 2017 8:36 pm Post subject: Re: CLKWRK's build |
I love type lV engines for it was my first foray into VW's , and long thought of doing a basic conversion in my Ghia .This is way over my head ,but intrigued by your passion . please post more as you progress, Cause i have no idea how this comes together |
CLKWRK Samba Member
CLKWRK Samba Member
Posted: Thu Jul 05, 2018 6:41 am Post subject: QUEST FOR A/C |
So I have started a new air conditioning project for the ghia.
QUEST FOR A/C
The goal is to have the a/c work with my T4 turbo setup and the vintage DPD dash unit I picked up on the samba, this rules out buying one of the modern aftermarket kits that are available online ... I will have to make my own
here is a shot of it installed in my parts car, its missing some parts but seems to work
So here is what I am starting with:
- beat up dpd a/c underdash evaporator unit I picked up from the Samba classifieds
- China made Sanden SD508 style compressor from ebay
- universal A/C barrier hose/drier/binary switch kit from ebay
- couple of 12x14 parallel flow condensers from ebay
- couple of 12" fans from ebay
- red tek R12a refrigerant
- A/C service kit from Amazon - has manifold gages and vacum pump
My plan of attack
1. clean up dash unit, replace TXV, make it complete and mount it in my black ghia
2. tear down engine to long block and fabricate mounts for the compressor
3. fabricate brackets and mount condensers/fans under car
4. run and connect the hoses/drier/binary switch
5. check for leaks and fill with refrigerant _________________ 1971 ghia build:
Instagram:
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Thu Jul 05, 2018 9:04 am Post subject: Re: CLKWRK's build |
It sounds as though you aready have everything you need parts wise to install working A/C in your Ghia project so this is likely a mute question, but have you considered going with an all electric automotive A/C system?
Perhaps you could even mix-and-match and utilize just an electric compressor with the rest of your other "standard" A/C components?
That would save you the effort of fabricating a compressor mount for your engine, and would also eliminate the parasitic horsepower losses associated with the belt driven compressor.
Just a thought. |
CLKWRK Samba Member
Posted: Thu Jul 05, 2018 10:31 am Post subject: Re: CLKWRK's build |
I actually did look into that! ... Infact that was my first choice, I looked at the masterflux (SHM) and the chinese boyard compressors.
A nice feature is that I could mount it in the ghia's nose and put some weight there to improve the handling, however I found the cost too high (like 1000 bucks for just the compressor vs 150 for a standard one)
Maybe in the future when the cost of these pumps drop I will switch over to electric
I don't mind fabricating stuff like brackets and hp parasite compressors dont bother me as long as I am frosty cool in my 200+hp black ghia _________________ 1971 ghia build:
Instagram:
crocteau Samba Member
Joined: March 31, 2005 Posts: 1204 Location: Philaburbia
Posted: Thu Jul 05, 2018 11:08 am Post subject: Re: CLKWRK's build |
CLKWRK wrote: |
... as long as I am frosty cool in my 200+hp black ghia |
You already are! Nice work! |
CLKWRK Samba Member
Posted: Fri Jul 06, 2018 7:34 am Post subject: Re: CLKWRK's build |
I took apart the evaporator unit to check it out, there are plenty of issues with it ...
Its made out abs plastic which is pretty brittle, so there are lots of cracks and large missing chunks
I was able to melt small chunks of plumbing pipe with a soldering iron and add material by “welding” plastic back onto it. It was a super nasty smelling process that required special ventilation but it worked
Also finding parts like the fan cover for this thing is pretty difficult ... but I have a 3-d printer, so I printed it
The vents needed love too, I was able to fix them by gluing vanagon a\c vents to the dpd frames _________________ 1971 ghia build:
Instagram:
DORIGTT Samba Member
Joined: October 01, 2003 Posts: 257 Location: Forest Grove, OR
Posted: Sat Jul 07, 2018 12:00 am Post subject: Re: CLKWRK's build |
Did you scan that part, or have to 'build it' in sketchup or something like that? _________________ To err is human, but if the eraser wears out before the pencil does you're a major screw-up. |
CLKWRK Samba Member
CLKWRK Samba Member
Posted: Sat Jul 14, 2018 12:56 pm Post subject: Re: CLKWRK's build |
Today I made the frame for the condensers, they are 12x14 parallel flow universal ones from ebay and a couple if 12" fans. I will be using a horn relay to switch them on/off
underneath my ghia I had a few problems as there is no room to mount this.
- my oil thermostat needs to be moved
- my bugpack sway bar no longer fits, I will be switching to the empi style one that is shorter and will need to make a custom mount
- mt mid engine mount needs to be modified to allow more room for the condenser assembly _________________ 1971 ghia build:
Instagram:
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1047 Location: Jacksonville, FL
Posted: Sat Jul 14, 2018 1:17 pm Post subject: Re: CLKWRK's build |
My wife had a 74 Ghia that had a complete dealer installed A/C unit. The condenser was mounted on the beam between the beam mounting brackets. I bet you could build a standoff bracket to mount the condensers and provide better air flow then add a discrete scoop under the nose to direct air to the condensers. Another option, one I am considering, is mounting the condensers in each wheel well and using either a scoop or the turn signal opening to route air to them. I
am also considering placing the radiators there as well (Subaru conversion.) I got the idea from a Porsche Boxter. You would need to build a crossover line to join the two but you already need to do that anyway.
Watching with interest,
Emil _________________ “…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
