EMPIFLAKE Samba Member
Posted: Sat Jan 24, 2009 6:25 pm Post subject: VW cylinder head temp gauge - any info? |
Hello I just recently got a gauge thats vintage I would say around mid 60s. I have an issue of volkswagen owners guige 1964 and its their in a little generic add.
I havent figured out how to post pics yet. Anyway it says vw cyl head temp if your interested in seeing it you can at ebay item #200298030277.
Please any info or make or is it rare? would be awsome I know its made in usa I took it apart to restore it and it came out great.
Thanks Mike |
Posted: Sat Jan 24, 2009 6:41 pm Post subject: |
Richard Roth Samba Member
Posted: Sun Jan 25, 2009 9:00 am Post subject: |
It's a RADATRON
 _________________ The problem with reality is that there's no background music !
1966 Empi GTV MKIV
1954 Kabriolett Beetle
1953 Porsche 356 1500S
1957 Cable brake standard model
1962 cable brake standard model
1956 23 window Samba
1960 Austin Healey 3000
1961 Corvair Greenbrier |
Posted: Sun Jan 25, 2009 1:04 pm Post subject: radatron head temp |
Thanks Rich
Do you know its year I think around 64 also is it rare or its worth anything of value?
Thanks Mike |
green61bug Samba Member
Joined: January 28, 2005 Posts: 76 Location: Greensboro, NC
Posted: Sun Jan 25, 2009 9:28 pm Post subject: |
that is pretty bad ass... I'd like to have one. _________________ 1963 OG Beryl Green Beetle Bug
1955 Ragtop Beetle |
Posted: Mon Jan 25, 2010 7:02 am Post subject: |
Hello
Does anyone know what kinda sensor would be used to hook this gauge up? And where the sensor would hook up at the head!
Thanks Mike |
xilly Samba Member
Posted: Mon Jan 25, 2010 12:38 pm Post subject: |
I'll say in the 70's for your gauge
There is a great EMPI one also that is rare
I had one few years ago and i sell it for 175$
william
www.oldspeed.net |
Posted: Mon Jan 25, 2010 12:58 pm Post subject: |
I have that one with the sender! Heres mine in my 62!
xilly Samba Member
Posted: Mon Jan 25, 2010 1:05 pm Post subject: |
lucky one
I have the VW one, not installed, but I only love the empi gauge
What kind of sender you are using? |
Harris Samba Member
Posted: Tue Jan 26, 2010 12:56 pm Post subject: VW Cylinder Head Temp Gauge |
While you are on the subject what is the normal cylinder head temperature? When is it too high and how would you tell without a gauge?
Thanks |
Dangermouse Samba Member
Joined: November 23, 2005 Posts: 904 Location: Beautiful New Zealand
Posted: Tue Jan 26, 2010 1:35 pm Post subject: |
VDO currently do a CHT gauge and senders are available new for those. They have a similar range and may well work with your gauge (well, it mightn't be entirely accurate but then it doesn't need to be accurate if it's functional - if it signals a deviation from 'normal' then it's doing its job). The sender is a simple thermocouple which replaces the seal on the sparkplug where it takes its reading from. Change in temperature generates a proportional current which operates the gauge, no external power is required (but for illumination if necessary). I know the VDO gauges and senders are available from nhspeedometer.com.
Here's a pic of some gauges I have in my car, you can see the CHT sender.
Under normal loads, the needle on my gauge sits at about 250.
HTH,
- DM _________________ Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you. |
xilly Samba Member
Posted: Tue Jan 26, 2010 1:40 pm Post subject: |
| If I remember correctly, it should be installed on cylinder 3 |
Posted: Tue Jan 26, 2010 1:58 pm Post subject: |
| xilly wrote: | | If I remember correctly, it should be installed on cylinder 3 | Thats correct!! |
Posted: Tue Jan 26, 2010 4:56 pm Post subject: |
Getting back to the original post.
The Radatron gauge was pretty special.
It cam with a rotary switch and four senders !
You could dial the switch and get seperate readings for all four cylinders.
I have an nos in the box one and will post some pictures when I dig it out.
P.S. I also have an EMPI cylinder head temp. gauge in my 66 GTV.
1966 Empi GTV MKIV
xilly Samba Member
Posted: Tue Jan 26, 2010 6:46 pm Post subject: |
but you forget the carpet Richard
William
www.oldspeed.net |
Posted: Tue Jan 26, 2010 8:02 pm Post subject: |
[quote] What a surprize  |
xilly Samba Member
Posted: Tue Jan 26, 2010 9:25 pm Post subject: |
Damn it I miss an empi cylinde head temp..
William |
Posted: Wed Jan 27, 2010 5:38 am Post subject: |
| xilly wrote: | Damn it I miss an empi cylinde head temp..
William | Dont worry bro all it takes is time ! and have the check book open at the time But ya its a cool gauge I scored mine about 2 years ago! It was funny I wasent really lookin for one and my buddy Al says you need a empi cyl head temp gauge in that car! Kinda got me thinken went home that day went to ebay and I couldent believe one was there Bam 2 bones later and it was mine . Now all I want left is Richard's empi 8 track and Im done !!
xilly Samba Member
Posted: Wed Jan 27, 2010 8:15 am Post subject: |
You are missing the "corners" protection
(I'm trying not to be jealous of your beetle )
william |
VWDruid Samba Member
Joined: June 14, 2008 Posts: 1094 Location: San Francisco, CA
Posted: Mon Mar 29, 2010 10:20 am Post subject: |
hi I scored one of these gauges at a garage sale and was wondering if mine is busted the needle is on the 500 side and if the OP got his working.
 _________________ 70 Westy, 2027cc "dual DRLA 40 m130 i55 wjdoc a165 p33 v30 "w100 straight cut 040 polished heads 1.25 rockers 1.5 A1sidewinder supertrapp muffler trans 091 coil SUM-850500 CDI universal svda Pertronix
http://www.storyofstuff.com/
It's not the straight cut gears It's the T.A.R.D.I.S. engine.
wanted Chameleon Circuit |
